Author Topic: Tao Bao Proxy YoyBuy  (Read 3778 times)
Offline trenzafeeds
  • **** off
« on: Fri, 07 August 2015, 03:14:46 »
Is this proxy legit? Has anyone used it before?
demik will never leave.
Unless he gets banned.
Offline meiosis
  • Time
Re: Tao Bao Proxy YoyBuy
« Reply #1 on: Fri, 07 August 2015, 03:24:10 »
You should try taobaofocus if you are worried, my friends have used them and had good results
The s youbuy site is pretty new
Keyboards:
Aripeko TKL
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Fri, 07 August 2015, 03:25:56 »
+1 on taobaofocus, used once, very good service.
Azerty Propagandiste
« Reply #3 on: Fri, 07 August 2015, 06:37:42 »
I've had so so experiences with tabaofocus so I went back to bhiner with my most recent order.
Never heard of the proxy linked in OP.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Fri, 07 August 2015, 09:31:54 »
« Last Edit: Tue, 11 August 2015, 15:11:44 by esoomenona »
Offline azhdar
« Reply #5 on: Fri, 07 August 2015, 09:34:42 »
How exactly does using a Tao Bao proxy work? Do you have to find the item first? And how do you do that without understanding Chinese?
You have to find the item yourself, but on TaobaoFocus, the website was offering a basic translation to help you order the correct color or size for exemple. I suppose other sites do too.
You pay to get the item to them, they picture, confirm, and make you pay final shipping.
Offline esoomenona
  • Gnillort?
« Reply #6 on: Fri, 07 August 2015, 09:48:06 »
« Last Edit: Tue, 11 August 2015, 15:11:29 by esoomenona »
Offline trenzafeeds
  • **** off
« Reply #7 on: Fri, 07 August 2015, 10:01:32 »
Might someone be able to help me find these? I did try to use the basic translation as suggested above, but I just can't find them. The best I can find is a rainbow set of lasered caps.
https://www1.massdrop.com/buy/tai-hao-sunshine-pbt-keycaps?mode=guest_open
Do you know for certain that Tao Bao stocks them?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #8 on: Fri, 07 August 2015, 10:11:19 »
I am not sure, but this guy has them, so asking him might work https://geekhack.org/index.php?topic=74051.msg1816076#msg1816076
Offline esoomenona
  • Gnillort?
« Reply #9 on: Fri, 07 August 2015, 10:52:27 »
« Last Edit: Tue, 11 August 2015, 15:11:01 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #10 on: Fri, 07 August 2015, 11:07:16 »
« Last Edit: Tue, 11 August 2015, 15:11:17 by esoomenona »
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11 on: Fri, 07 August 2015, 11:08:10 »
Some people in the discussion on MD seem to indicate that they are listed there.
Thanks, seth. I PM'd that person to see if they can provide some assistance.
NP.
