Author Topic: [IC] Artisan Boxes  (Read 34813 times)
Offline ghostjuggernaut
Re: [IC] Artisan Boxes
« Reply #50 on: Sat, 15 August 2015, 07:37:11 »
Once mine arrives, I am going to look into getting an acrylic lid cut. If there is interest, I can have multiple cut to go along with Seth's orders.
I'll check with him before I do, and see how things are looking.
They come with lids though....
Are you sure?
Yes most definalty I can take a picture when I get home if you want but, its the same one as I bought a month or two ago although I got the largest size one which take like 100+ keys it came with a lid as I can mount it on my wall and the keys stand up correctly!
Oh thats great.  From all the photos, it looked like it didn't come with one.
« Last Edit: Sat, 15 August 2015, 07:47:22 by ghostjuggernaut »
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #51 on: Sat, 15 August 2015, 07:44:38 »
Are you sure?
Oh thats great.  From all the photos, it looked like it didn't came with one.
Yeah again if it is the same as what I got which looks the exact same it came with a lid, the body and base of the case was frosty, while the lid is clear acrylic
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #52 on: Sat, 15 August 2015, 08:39:48 »
I would be interested in several. They don't look as nice as Martin's acrylic cases do, but he said he's not making any more anytime soon, so this looks like a good substitute.
Offline tigersharkdude
« Reply #53 on: Sun, 16 August 2015, 20:31:40 »
OP, any update?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #54 on: Sun, 16 August 2015, 21:37:56 »
OP, any update?
I am waiting until ghost juggernaut gets his and we will decide on what to do from there. Depending on quality, it could be possible to have them made on the U.S. If it is around the same price, I hope people don't mind waiting for them to be made in the U.S. I just want to see quality / how well packaged they are. And as far as cost go, I will invoice for case price + domestic shipping first, then once I get the bill for the international shipping I will calculate your percent, and once you pay the second invoice I will ship it out. If you end up not paying the 2nd one I will just refund.
« Reply #55 on: Mon, 17 August 2015, 06:07:08 »
OP, any update?
sounds good with me, Im in no rush at all. Ive seen a lot of ICs go nowhere, so I was just wondering if you were still here basically
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #56 on: Mon, 17 August 2015, 09:15:52 »
OP, any update?
Yep! Just waiting to see quality/shipping quality. I would hate to order them and have half of them come broken or have them be cheap plastic
Offline Fire Brand
  • BISCUITS!
« Reply #57 on: Mon, 17 August 2015, 09:35:15 »
OP, any update?
If your not too fussed its coming from me, they are good quality, the acrylic is around 7mm thick, the sides use a frosted acyclic while the base and lid use a clear acrylic the lid opens super smoothly without much problems, the only part required to build are the inserts inside the box which all just slot together I would advice using a little glue and you might need to heat them up as they come somewhat warped but fit very well overall the case is good, I suspect the one I ordered is only damaged due to the size but if possible I would recommend getting these cut in the US rather than ordering for overseas as you will get a lot with cracks just due to the cheaper acrylic used and its super hard to stop it cracking, just worried as if you plan to sell these you may end up with a lot coming back, I would recommend getting them made and using a thick acrylic like what Martinyeah used for his box, as that is almost impossible to break! also pictures!
Thats the damage that mine came with just as a fyi to you.
Showing how the keys stand up when the lid is on, I would recommend mounting this to a wall in a picture frame type move as it will look rather nice.
Just showing how they lean against the lid to stand
The lid
Has a little frosted bit glue to it to use as a handle.
Also the cracks are not all the way through just internal to the parts
Keyboards owned
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #58 on: Mon, 17 August 2015, 09:36:46 »
OP, any update?
The lid
Offline krbuck
« Reply #59 on: Mon, 17 August 2015, 11:43:12 »
I'm interested in getting a few of these. I'm in the U.S. btw.
POK3R - Brown Cherry MX
Offline Fire Brand
  • BISCUITS!
« Reply #60 on: Mon, 17 August 2015, 12:31:42 »
OP, any update?
The lid
No problem, also thats from it being super well packaged as well, it came in a large cardboard box and in like three layers of bubblewrap
Keyboards owned
« Reply #61 on: Mon, 17 August 2015, 12:40:32 »
I'm potentially interested if we can be reasonably assured that they will survive transit. Still not sure why they don't make these out of a less brittle plastic.
« Reply #62 on: Mon, 17 August 2015, 13:07:02 »
Im still interested. I really think the damage is due to a packaging. BUT if you order a number of them and get a proxy to ship you can ask them to add extra packing material
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #63 on: Tue, 18 August 2015, 15:02:26 »
They are out of stock, even though they show that they are not. We will look into having them made over here :)
« Reply #64 on: Tue, 18 August 2015, 15:03:08 »
Offline pr0ximity
« Reply #65 on: Wed, 19 August 2015, 21:15:20 »
Don't have enough artisans for one of those beasts
« Reply #66 on: Thu, 20 August 2015, 00:22:21 »
Don't have enough artisans yet for one of those beasts
« Reply #67 on: Thu, 20 August 2015, 08:05:58 »
I am going to work on a design this weekend. I just wanted to know what people would prefer in a box. I personally felt like 3x5 trays would be nice, and have a drawer system to hold multiple. If not that, then possibly a flat tray to display them all, similar to the ones this was originally started for.
Let me know what everyone thinks. I will most likely make the box for myself, but I can design something else for the IC if people don't like that setup.
« Reply #68 on: Thu, 20 August 2015, 08:32:30 »
I'm interested in the original IC design, but also interested in checking out the other layout.
Offline azhdar
  • Praise the AZERTY god
« Reply #69 on: Thu, 20 August 2015, 08:35:14 »
Don't forget this :
Ohh also to note, they do not fit keycaps such as zombro's due to the size and other keycaps around that size, but fit most everything else
so you can make a slight improvment of the design :)
Azerty Propagandiste
« Reply #70 on: Thu, 20 August 2015, 08:55:36 »
I would personally like something larger than 3x5, like 5x5 or larger. Just so I don't have to worry about buying another box anytime soon
Offline Fire Brand
  • BISCUITS!
« Reply #71 on: Thu, 20 August 2015, 17:50:46 »
Could you make it possibly wallmountable like a picture frame maybe like 4 holes in the corners to put screws into ? :x
Keyboards owned
Offline Blackehart
« Reply #72 on: Thu, 20 August 2015, 18:04:52 »
interested in one
« Reply #73 on: Thu, 20 August 2015, 18:59:06 »
I'm sure I could figure something out.
« Reply #74 on: Thu, 20 August 2015, 19:00:19 »
I was thinking more along the lines of a storage case of sorts, with slide out trays. It would be less of a display case though. If people don't want it, I'd be happy to make one similar to the one from taobao.
« Reply #75 on: Mon, 07 September 2015, 20:58:26 »
Updates?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #76 on: Mon, 07 September 2015, 21:38:54 »
Updates?
No big ones, gotta think through some stuff first. They are out of stock, not sure if I mentioned that. I will look at having them made.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #77 on: Mon, 07 September 2015, 21:45:19 »
Okay, I know a way to do it. I will make some autocad drawings, take it to a few different places, and have them cut. I will then make it a DIY pack w/ acrylic cement.
Offline Dorothy
« Reply #78 on: Tue, 08 September 2015, 01:40:08 »
I'd buy one
Poker2 MX Clears   Poker 2 MX Blues
« Reply #79 on: Fri, 18 September 2015, 21:13:24 »
Acrylic cement? To, like, put the slots where we want them?
I was using switch testers as displays for the few artisans I have, but would prefer acrylic boxes so as to use the keycap stems as little as possible.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #80 on: Fri, 18 September 2015, 21:14:05 »
Nope, I know a way to do it so you only need to cement the walls
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #81 on: Sat, 19 September 2015, 14:18:53 »
I have the dxf file ready, now I am just waiting on a few quotes.
Offline temporal
  • gear for the gear god
« Reply #82 on: Sat, 26 September 2015, 21:26:48 »
any word on this? my artisans are piling up...
Offline Pdub
« Reply #83 on: Sun, 27 September 2015, 22:18:10 »
I would be interested depending on the cost!
« Reply #84 on: Tue, 06 October 2015, 15:11:49 »
This. Today marks the day I've run out of room on my switch testers for artisans.
Offline linkshine
  • If you wanna b my lover, u gotta get w/ my friends
« Reply #85 on: Tue, 06 October 2015, 15:14:33 »
Ghost I'm all over one if you start something
« Reply #86 on: Tue, 06 October 2015, 15:21:21 »
In terms of slide-out drawers, are you talking about something similar to the old GasMask/HKP acrylic displays?
« Reply #87 on: Tue, 06 October 2015, 15:24:07 »
Exactly that. I have a thread about what I'm making. I should have a sample here soon.
« Reply #88 on: Tue, 06 October 2015, 15:26:31 »
Didn't know that. Checking it now.
Seth, still interested in your progress and any updates!
Offline Pdub
« Reply #89 on: Sun, 25 October 2015, 19:01:38 »
Any update on this.
« Reply #90 on: Sun, 25 October 2015, 19:49:05 »
Any update on this.
I'm eager to get one.
Offline happyturtlee
« Reply #91 on: Mon, 26 October 2015, 14:08:10 »
I like this! Would prefer a smaller one though because I don't have that many artisans.
Offline mobbo
  • u fk
« Reply #92 on: Mon, 26 October 2015, 14:28:16 »
I've been looking for this :) bought a switch tester/numpad to house my artisans in the meantime.
Quote from: Binge
« Reply #93 on: Mon, 26 October 2015, 14:48:22 »
I know how to make this for a large capacity and accommodate your situation:
Buy more artisans!
Offline temporal
« Reply #94 on: Mon, 26 October 2015, 16:15:00 »
For those that just can't wait for this GB to happen:
http://www.amazon.com/gp/product/B00FZ35MDW
Offline Bigpock
« Reply #95 on: Mon, 26 October 2015, 17:04:17 »
Will a keycap fit in there snug, if so.. PERFECT!  :)
Offline ika
« Reply #96 on: Mon, 26 October 2015, 17:06:59 »
If people are looking for storage solutions I use these from Harbor Freight: http://www.harborfreight.com/18-divider-storage-container-94456.html
$3, grab a bag of cotton balls, stick a few into the bottom of every well, boom - instant artisan portable transportation. Obviously not as nice as these acrylic ones but it cost me $3 and has a lid.
« Reply #97 on: Mon, 26 October 2015, 17:24:38 »
It looks like a good one, but it's too high and the caps will move around.
« Reply #98 on: Mon, 26 October 2015, 21:49:56 »
Buy more artisans!
Working on it!!! I love all the variety but I'm poor. T_T
« Reply #99 on: Mon, 26 October 2015, 21:59:11 »
Someone asked about these before, and I finally got around to grabbing the link.
http://www.containerstore.com/s/gift-packaging/containers/boxes/small-clear-amac-boxes/123d?productId=11000251&green=5F5F5FDC-8C06-5BBE-0018-C5505D78F1C5
I have the #60140 boxes, and they are the perfect size for single keycaps. I'd still rather have something better,  but they work really well and aren't too pricey.
