Author Topic: Windows Key Quit Working Realforce 87  (Read 2673 times)
Offline jophde
« on: Mon, 10 August 2015, 23:12:31 »
Hey there,
I have a Realforce 87.  Out of the blue the windows (super) key quit working.  I have tried it on different computers, OSs, and USB ports.  Any thoughts on how to fix it or if Realforce has a warranty?
Thanks
Offline rf87
Re: Windows Key Quit Working Realforce 87
« Reply #1 on: Tue, 11 August 2015, 03:41:56 »
Did you try turning off the DIP switch 'SW2' that is underneath your keyboard? Doing so enables the window key.
Did you purchase your keyboard from EliteKeyboards by any chance? If you did, then they do have a 2-year warranty on the Realforce.
Realforce 87 UB Variable
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #2 on: Tue, 11 August 2015, 08:57:05 »
It's a sign from the above to ascend to Linux. :)
Anyways, try what rf87 said. If that doesn't work and it's not on warranty, post pics of the pcb around that key.
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline rf87
« Reply #3 on: Sat, 15 August 2015, 01:46:13 »
Hi jophde,
Did turning off the DIP switch 'SW2' work for you?
Offline jophde
« Reply #4 on: Sun, 16 August 2015, 16:43:37 »
I have tried toggling the dip switch on Mac, Windows, and Linux.  The Mac OS was a separate machine too.  The switches seem fried :(.  Is there anyway to fix?
Offline Polymer
« Reply #5 on: Mon, 17 August 2015, 03:29:15 »
Do any of them work?  Are you unplugging it first and then changing them?
