Author Topic: Are O-Rings worth it?  (Read 40279 times)
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
Re: Are O-Rings worth it?
« Reply #50 on: Mon, 04 January 2016, 07:01:53 »
I'm on the fence. Only tried 0.4mm o-rings and to be honest I didn't enjoy it one bit, but I will still give 0.2 and 0.1 a shot before I throw in the towel.
Here are a few highlights to help you decide which size fits you better :
- A thicker O-ring will reduce key travel more than a thinner one.
- A softer O-ring will make a switch quiet more effectively than a harder one.
- The more material the O-ring has, the more it can dampen shocks and noise.
From that, your choice mainly depends on which keycaps you are using.
Offline gain
« Reply #51 on: Mon, 04 January 2016, 08:25:48 »
Yeah I'm still fairly new to it, and have some experimenting to do. Thanks for the summary though, I guess I never really took into consideration softer/harder o-rings.
I can already tell though softer o-rings aren't my jam
Offline derb2k2
  • Something of a Topre ****..
« Reply #52 on: Mon, 04 January 2016, 08:49:08 »
i know that landing pads were mentioned here, but I think it was in the context of Topre switch.  You might also consider using EliteKeyboard's landing pads on your MX board. I've tried both o-rings and pads and prefer the pads, just because it seems the keypress impact is softer, albeit "mushier".
I have some laying around and can send you some if you'd like so you can test. I have the "soft" black landing pads from EK, not the "firm" white ones.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
