Author Topic: Problem with AT F  (Read 1636 times)
Offline mougrim
Problem with AT F
« on: Thu, 13 August 2015, 13:33:42 »
Still using my ol' pal - AT F with external Soarer's
With Soarer's it sometimes stats throwin' repeated last pressed symbol, and to stop it I have to press any key  - but it's all OK when I plug it through Blue Cube. Any ideas?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Re: Problem with AT F
« Reply #1 on: Thu, 13 August 2015, 13:37:36 »
Is your grounding thing properly attached? Or is your keyboard's screws properly tightened? Overly tight screws holding the sandwich together can lead to that. So can lack of grounding.
I messed both things up with messing with my Kishsaver.
Offline mougrim
« Reply #2 on: Thu, 13 August 2015, 13:55:41 »
Hmm, worth checking, when I have time. You talking about internal grounding, right?
« Reply #3 on: Thu, 13 August 2015, 13:58:35 »
Yeah! There's a little grounding clip and a screw that was in my kishsaver. I didn't secure it properly so my board wasn't grounded properly. I would assume that your AT F has the same grounding. Worth checking that and the sandwiched plate/PCBs' screws.
Offline mougrim
« Reply #4 on: Thu, 13 August 2015, 14:11:36 »
Maaaaybe. Bought it already cleaned and ANSI-modded, so didn't bother looking inside :)
Damn. Kishsaver. Damn you good :)
