Author Topic: Any difference in 93 vs. 96 Lexmark Model M?  (Read 7869 times)
Offline ironcoder
« on: Tue, 13 October 2009, 08:01:08 »
Clicky has these for the same price. I'm thinking older is better but some of you guys probably know for sure.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ironcoder
« Reply #1 on: Tue, 13 October 2009, 12:08:45 »
Despite all the posts and PMs I got on this I couldn't wait so I ordered them both.
I used these kinds of boards when they first came out and loved them. Didn't know there was anything else. I hope I like these too, especially since it's 100 bucks to ship 2 keyboards.
Dammit who said we just make you feel less bad about your expenses? Doctor, doctor!
Offline ironcoder
« Reply #2 on: Tue, 13 October 2009, 12:38:25 »
Thanks for your awesome model M thread, I was going over it. Tremendous job.
Why did they go to a fixed cable and what was the connection on the 1391401?
I noticed one minor difference between the two I ordered, one has one piece key caps and the other has 2 piece, one is an insert of some kind.
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/9231/subcatid/0/id/426698
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/9231/subcatid/0/id/313634
« Last Edit: Tue, 13 October 2009, 12:50:49 by ironcoder »
Offline itlnstln
« Reply #3 on: Tue, 13 October 2009, 12:43:04 »
They probably went to a fixed cable due to cost cutting and fewer repairs/replacements due to people breaking tabs on the plug.  The interface for the cable was called SDL.  The connectors are still made by AMP.
Offline itlnstln
« Reply #4 on: Tue, 13 October 2009, 12:46:52 »
One thing to note, as well, with the removable cable models is that NIB models occasionally do not come with the cable as they were sold as field replacements.  That way a technician just replaced the broken keyboard with a new one and they could detach the cable from the keyboard side, thus saving time (not much, if you think about it).  That might be another reason they switched to a fixed cable.  Ms rarely had to be replaced and users were becoming more savvy and could replace their own keyboard if they needed to.
Offline ironcoder
« Reply #5 on: Tue, 13 October 2009, 12:50:05 »
That sounds like a good explanation, thanks.
Offline itlnstln
« Reply #6 on: Tue, 13 October 2009, 12:54:25 »
Quote from: ripster;125025
Could you show me how to replace my keyboard?
No, but at least you're in the right place.
Offline Rajagra
« Reply #7 on: Tue, 13 October 2009, 13:44:10 »
Quote from: ripster;125016
For some reason only the Greenock ones look a little different - I think they used a different kind of plastic.
They were probably deep-fried in batter.
Offline ch_123
« Reply #8 on: Tue, 13 October 2009, 14:56:11 »
I don't have a 52G - I'm sure they're fine though.  Looks like the outer shell didn't change from the 1391401.  For some reason only the Greenock ones look a little different - I think they used a different kind of plastic.
It wasn't just Greenock ones, it was the latter Lexmark ones... made from about 1995 on.
Offline ch_123
« Reply #9 on: Tue, 13 October 2009, 15:12:02 »
I assume that something may have changed around the time they changed the lock light label and straight cable.
Offline itlnstln
« Reply #10 on: Tue, 13 October 2009, 15:16:47 »
I like the lock light label after the change.  It didn't look so, well, old.
Offline ironcoder
« Reply #11 on: Tue, 13 October 2009, 15:37:28 »
Quote from: webwit;125053
Nonsense, I have 14 Greenocks and they look exactly the same.
And well they should, after being deep-fried in batter :bolt:
Offline ch_123
« Reply #12 on: Tue, 13 October 2009, 15:46:55 »
It just occured to me... what are the part numbers?
Offline ironcoder
« Reply #13 on: Tue, 13 October 2009, 15:54:26 »
Quote from: ch_123;125065
Is that a trick question?
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #14 on: Tue, 13 October 2009, 18:34:49 »
Quote from: ripster;125081
Now the grounded space bar.
That is bewildering to me from a safety point of view. Wouldn't a double-insulated space bar be better?
After all, if only the space bar has to be grounded, one of the other keys might develop a high voltage! And then, if the space bar is grounded, that forms a perfect path to ground, and your hand can get electrocuted!
If their standards called for grounding the whole keyboard - that is, a layer within the keyboard between its internals, that need to have electricity to work, and the outside - and then insulating the whole keyboard as well, so that users of the keyboard don't make electrical contact with ground, now that would be an electrical safety standard.
And it might even come in handy if a short circuit inside the computer sent a voltage into the keyboard that fried the keyboard - and, as well, it might be easier to have such a standard for a keyboard than to have standards for computers that prevent such things from happening.
Offline msiegel
« Reply #15 on: Tue, 13 October 2009, 19:06:12 »
that is *so* odd
webwit, do you have a multimeter, to check whether the space bar plastic is conductive?
Offline msiegel
« Reply #16 on: Tue, 13 October 2009, 19:15:48 »
XD
it don't make no sense!
Offline msiegel
« Reply #17 on: Tue, 13 October 2009, 19:23:01 »
it's just weird... can you imagine how it started:
"ow! ow, this space bar keeps shocking me!! the government should do something about this!"
*slow facepalm*
Offline msiegel
« Reply #18 on: Tue, 13 October 2009, 19:38:14 »
:O
ok, new rule: no polyester sweaters while typing on a model m
Offline ironcoder
« Reply #19 on: Wed, 14 October 2009, 02:42:45 »
Quote from: ripster;125136
Static electricity is never a problem.
Yeah it's the dynamic electricity that gets you every time.
Offline ch_123
« Reply #20 on: Wed, 14 October 2009, 03:03:52 »
Wonder why the EU would care whether ABS is used?  Think of all those little kids chewing on ABS Lego blocks.
Again, didn't Lexmark make their 42Hs out of PVC too?
Quote from: webwit;125069
Oh part numbers don't tell the whole story, to name just one example I have 1396790s with and without fixed cable. I have a 1993 without fixed and a 1994 with fixed if you want a date of change.
It's still a far more better gauge of what you're getting compared with the year it was made in.
It's conductive to EU monopoly fines.
Not necessarily, I've seen plenty of other keyboards made in the EU around the same time that had no such arrangement. I think it's just the Brits who have particularly stringent electrical safety arrangements. For example - Have you ever seen a British plug?
Unlike elsewhere, everything has a three pin plug (although the earth pin is often unwired). Sockets are designed to refuse plugs with missing earth pings (although there's 'hacks' to plug in European plugs into British sockets) and every plug has a fuse built into it, even it the device itself is already fused! I don't think any other design of plug is so over-engineered.
« Last Edit: Wed, 14 October 2009, 03:15:19 by ch_123 »
Offline itlnstln
« Reply #21 on: Wed, 14 October 2009, 10:01:46 »
How about if the plastic is different but lighter (or maybe I misunderstood something)?  Titanium is stronger than steel, but it's much lighter.
Offline itlnstln
« Reply #22 on: Wed, 14 October 2009, 10:08:28 »
Excellent deduction.
I was thinking in terms of this quote:
If it's lighter you can argue that quality declined.
Offline ironcoder
« Reply #23 on: Wed, 14 October 2009, 10:10:22 »
BTW I did receive a shipping confirmation this morning. Woo hoo, my first buckling springs since the 80s are on the way!
Offline itlnstln
« Reply #24 on: Wed, 14 October 2009, 10:45:39 »
Quote from: ripster;125270
I think most people think heavier is better (at least when it comes to keyboards). It's a perception thing though - the Unicomp Spacesaver is the lightest of my buckling springs (I'm talking overall weight) and yet feels the best to me.
I agree.  My Cherry is much lighter than my Filco, but I think the Cherry is the superior keyboard for several reasons (already beaten to death by me in other posts).  The only thing I might be able to agree with the heavy keyboard crowd on is that heavier keyboards don't slide as much, but then again, my Cherry doesn't slide around much, either, so YMMV, I guess.
Offline ch_123
« Reply #25 on: Wed, 14 October 2009, 11:58:50 »
I agree with the guy with the lego...
Offline ironcoder
« Reply #26 on: Thu, 15 October 2009, 02:39:16 »
I just ordered a 1996 Lexmark, so they were still being made by then.
Offline ch_123
« Reply #27 on: Thu, 15 October 2009, 02:42:24 »
Is it a terminal board? I have read that 1994 was the year they stopped manufacturing those.
Offline ironcoder
« Reply #28 on: Thu, 15 October 2009, 05:56:09 »
you're making me pine for the good old days :-(
Now if you only had a 370/168 to hook it up to!
Offline ch_123
« Reply #29 on: Thu, 15 October 2009, 08:54:55 »
Quote from: webwit;125543
Yeah, it's one of these:
The million dollar question is - is a Lexmark Model F as good as an IBM one?
Ironcoder: What sort of machine was that keyboard designed to be used with?
Offline ironcoder
« Reply #30 on: Thu, 15 October 2009, 09:18:53 »
I don't know what it designed to be used with, but it seems to me it must have been an early design, because ever since ISPF came out (and I don't remember what year) it was important to have 24 PF keys available. That board doesn't have any, so it may not have even been made for a mainframe. IBM also had a few series of minis.
Or that could be a trick question and it really was designed for the AT. Come to think of it that would make the most sense.
The mainframe boards needed special keys including SYSREQ, ATTN, PA1, PA2, Reset, and the PF keys. Later they came out with keyboards with only 12 PF keys, which could be function shifted to the 13-24.
« Last Edit: Thu, 15 October 2009, 09:22:15 by ironcoder »
Offline ironcoder
« Reply #31 on: Thu, 15 October 2009, 09:19:25 »
Also I can't see the detail very well in the small pic.
Offline ak_nala
« Reply #32 on: Fri, 16 October 2009, 11:31:14 »
Quote from: webwit;125999
Part nr 1397950, IBM 5291-2 keyboard. Interface:
Used in IBM System 36s.
So that's what this thing's for - I have one that dates from Oct. 1984.
Originally bought it as a donor board to try to mod my AT into something a bit more usable, but turned out to be too cool a form-factor to want to part out.
No matter where you go, there you are...
