Author Topic: [Postoned] FingerSK/UP (75%) + Finger (65%) Cases in development  (Read 23753 times)
Offline 64rky
Re: [GB] FingerSK (75%) + FingerUp (65%) + AEK2 (Alps) PCB's
« Reply #50 on: Wed, 26 August 2015, 19:33:25 »
Would love that FingerSK, with a plate, and in an Alu case... or Poly, with the led's shining through...
Offline cwils0n
  • twiggletwaggle
« Reply #51 on: Fri, 28 August 2015, 09:26:25 »
I'd also buy a FingerSK if the case was available as well.
Offline tjweir
« Reply #52 on: Fri, 28 August 2015, 09:40:29 »
I'd like to cancel my order please.
Offline Cameron
« Reply #53 on: Sat, 29 August 2015, 11:02:46 »
its a mistake
Offline blai5000
« Reply #54 on: Sun, 30 August 2015, 14:35:00 »
Any idea what cases the FingerSK would fit into, and what bottom row layouts are supported?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #55 on: Sun, 30 August 2015, 14:45:14 »
MX-Mini compatible cases, and I believe I linked the layout info earlier
Offline blai5000
« Reply #56 on: Sun, 30 August 2015, 18:47:33 »
Thanks, just read through that link.  It's looking more and more enticing!
Offline meiosis
  • Time
« Reply #57 on: Sun, 30 August 2015, 19:23:38 »
LZ has mentioned the acrylic cases will be prepared "at another time/shortly"
That said this GB will be extended one more week till September 7th.
Keyboards:
Aripeko TKL
Offline Cameron
« Reply #58 on: Sun, 30 August 2015, 21:05:42 »
Does that mean the case will not be offered as a part of this group buy and will be separate? Or will it be ready in time for this group buy.
Also isn't 7th of September reducing the GB? It was previously stated that it ended on the 12th of September
« Last Edit: Sun, 30 August 2015, 21:49:37 by Cameron »
Offline Norman_the_Owl
« Reply #59 on: Wed, 02 September 2015, 12:01:13 »
Can i just get a confirmation that the FingerSK supports the same split spacebar bottom row as the FingerUP/L3?
Offline meiosis
  • Time
« Reply #60 on: Wed, 02 September 2015, 23:48:04 »
Yes,
Also for an update, LifeZone will be selling an acrylic case for this shortly.
Payment/Invoices will be sent out next week, Due on Sept 15th
Keyboards:
Aripeko TKL
Offline tofgerl
« Reply #61 on: Sun, 06 September 2015, 09:07:09 »
Honestly, this thread is a bit of a mess. Could you update the OP to include more details on the PCBs and options?
Edit: No offense meant, it's just hard to find the information needed for an informed purchase.
« Last Edit: Sun, 06 September 2015, 09:10:16 by tofgerl »
Offline ika
« Reply #62 on: Sun, 06 September 2015, 11:03:34 »
So the official end date is the 7th, not the 12th as stated in the OP? Will the case be made available before the buy closes, or at least pictures?
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #63 on: Mon, 07 September 2015, 09:23:18 »
Submitted order for 2x FingerSK RGB + 2 assemblies from Seth.
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline effectiveduck
« Reply #64 on: Mon, 07 September 2015, 09:35:17 »
What would it cost for a FingerUp PCB (65%) with diodes and resistors pre-soldered (everything needed bar switches and leds) shipped to Australia?
Also is there any plates being made?
I have to say I've found this gb a little confusing, but still very interested in a 65% keyboard.
Offline blai5000
« Reply #65 on: Mon, 07 September 2015, 10:30:26 »
Placed an order for the FingerSK (75%) with sethk_ soldering.  Now to wait for the case to become available...is it going to be sandwich-style?
« Reply #66 on: Mon, 07 September 2015, 14:54:49 »
Placed the same order as above
If they were through hole i'd have done it myself, but i'm not so sure about all the SMD...
Offline Freetail
« Reply #67 on: Mon, 07 September 2015, 23:57:34 »
Does anyone know what plate would work with the FingerUp?
Offline nmur
  • ಠ_ಠ
« Reply #68 on: Tue, 08 September 2015, 01:19:34 »
I just caught up with the thread. is this actually ended? The date in the OP is different than what's been stated in the comments.
Offline E3E
« Reply #69 on: Tue, 08 September 2015, 01:28:56 »
Question: Will there be custom AEK2 cases available for the PCB, or is this just intended to be a swap into AEK2 cases?
Unfortunately, I only have an AEKI, so it might not be compatible even though I think they would be similar enough, but the angles are different. I would like something to put my Orange Alps into.
Offline hippo008
« Reply #70 on: Tue, 08 September 2015, 21:21:52 »
So im a little confused. Its the 8th and i havent received an invoice even though I put in my order? is the invoice date still the 7th?
Offline meiosis
  • Time
Re: [GB] FingerSK/UP (75%) + Finger (65%) + AEK2 (Alps) PCB's
« Reply #71 on: Tue, 08 September 2015, 21:42:32 »
First off, sorry for the delayed responses, I've been on a business trip, Leeku (Eric) will be invoicing everyone when production is ready. Currently the expected date is by the 19th.
First off I messed up a bit, FingerUP is the original 75% name, it's the same thing but in this variation it will say FingerSK, Finger is the 65%. I will update all orders and confirm before invoices go out.
Now around the 15th- last day would be 19th
Yeah sorry I forgot to update OP. It's retroactive depending on when I can actually get a better idea of the cases, since I imagine it would be nicer for some people to be able to get a case at the same time, or at least more information, I'm glad a lot of people have gone ahead and ordered!
It's made to be put into an old AEK2 case, and would be programmable, sadly no custom will be made for it in the meantime..
I messed up a bit on the name, all the plates from the previous 65% GB have been bought out, there is a chance there might be another run soon, but in the meanwhile I don't have an answer for it
Keyboards:
Aripeko TKL
Offline meiosis
  • Time
« Reply #72 on: Thu, 10 September 2015, 20:13:16 »
UPDATE:
ORDERS WILL BE POSTPONED FOR A WHILE, acrylic cases are in development for both the 75% and 65%! (no ETA but it will happen)
IF YOU REALLY WANT YOUR ORDER OF JUST PCBS PLEASE SUBMIT AGAIN
MESSAGE ME IF YOU WANT YOUR ORDER.
Sorry everyone, But I think this is better, and we can see a case+plate+pcb in the future too!
Keyboards:
Aripeko TKL
