Author Topic: What's your favorite switches?  (Read 10475 times)
Offline Charizard
Re: What's your favorite switches?
« Reply #50 on: Sun, 27 September 2015, 21:46:10 »
Topre 55g > Cherry MX Browns
Offline ideus
  • Björkö.
« Reply #51 on: Sun, 27 September 2015, 21:48:48 »
What do you mean?
Welcome to GH.
Offline Bucake
« Reply #52 on: Mon, 28 September 2015, 08:41:24 »
right now i have a crush on my Model F, it has heavy-as-hell spacebar though.
unfortunately i damaged some of the foam padding while cleaning it. didn't think i'd be so clumsy :(
« Last Edit: Mon, 28 September 2015, 08:45:00 by Bucake »
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #53 on: Mon, 28 September 2015, 10:52:20 »
For gaming I like MX Browns. For typing I like topre or MX Blues.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #54 on: Mon, 28 September 2015, 11:36:06 »
replacing the complete foam is the best you can do. The foam has a major impact on the overall feel and the time needed to replace it, is totally worth it.
Offline SamirD
« Reply #55 on: Mon, 28 September 2015, 12:21:39 »
Why don't you try usb to bluetooth converter(aka usb2bt, you can find it on Amazon)? I know someone who makes keyboard wireless with it(sorry I don't know whether the keyboards include Model M) .
It will need an extra battery instead of usb power supply, but If what you want to do is just using Ms on phones, it will go.
I initially looked into these as I have two ps2-usb converters that always work fine to convert the M to usb when needed.  But then I read about the amp draw for an M being higher than normal and didn't think it was going to work.  Have you found anything that definitely works as that would be the ultimate solution?
« Last Edit: Mon, 28 September 2015, 12:25:22 by SamirD »
Offline Charizard
« Reply #56 on: Tue, 29 September 2015, 00:32:05 »
What do you mean?
Welcome to GH.
Yeah upon rereading that post it wasn't clear at all. I meant to say, that of the two boards I am currently using, I prefer the Topre switches tot the mx browns.
Thanks for the welcome, though I have been a member/lurker since 2012 :)
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #57 on: Tue, 29 September 2015, 00:50:57 »
There is Colossus/Bluetooth conversion.
http://deskthority.net/workshop-f7/universal-model-m-controller-t9820.html
You might have to have some patience for now.  From page 10 or so on the thread, it gets very interesting!
Let's just say....  soon.
How soon?  I have no idea.
« Last Edit: Tue, 29 September 2015, 00:53:49 by Snowdog993 »
Offline SamirD
« Reply #58 on: Tue, 29 September 2015, 14:20:42 »
I remember reading about this route, but didn't like the idea of opening the M.  I just want a plug and play solution, even if it costs a bit.
I found out about the Nulaxy adapter recently, but one reviewer on Amazon says it didn't work with an M.  But I know the usb adapter has a lot to do with if an M will work or not, and wonder if this guy's usb adapter wasn't up to the challenge.  This would be the ultimate solution as I do have a second M that I can dedicate to my phone.  Boy, I'd be able to really text back fast then!  lol!
