Author Topic: Anyone seen a KPP24U?  (Read 2560 times)
Offline Xichekolas
« on: Thu, 15 October 2009, 01:03:56 »
Anyone ever owned one of these?
http://www.fentek-ind.com/gen_keypads.htm#kpp24ps
I know Ms Keyboard lurks here, so maybe she can be of assistance. I'm curious what kind of switch they have, and what they look like in profile.
Considering an interesting project to put one under each hand and program them. Figure if they each come with 3 double caps it would cover my space/enter/etc needs.
Offline Xichekolas
« Reply #1 on: Thu, 15 October 2009, 01:45:37 »
Nice. You can pull that link up faster than I can google stuff. ;)
From the pics of the programming software it looks like you can't assign things like alt/ctrl to keys. Can anyone comment on that? Would definitely torpedo the idea of using two of them as a split keyboard.
Offline lowpoly
« Reply #2 on: Thu, 15 October 2009, 07:51:10 »
Quote from: Xichekolas;125512
AI know Ms Keyboard lurks here, so maybe she can be of assistance.
She has a forum here in the vendor section.
Offline rdjack21
« Reply #3 on: Thu, 15 October 2009, 10:09:42 »
Quote from: ripster;125591
It's not hard.  Geekhack has a search function.
Be nice ripster you forgot to tell the poor new user where the search function is at.
Look at the top of the page and you will see this really nice menu item called Search!
EDIT: Forgot to add no need to use Google when most of the results point here anyways.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdh
« Reply #4 on: Thu, 15 October 2009, 10:50:33 »
Quote from: rdjack21;125613
When you know what you're looking for is on Geekhack, and Geekhack's built-in search isn't sufficient, you can restrict Google to look only at Geekhack by adding 'site:geekhack.org' as a search term.
at home: IBM "Space Saving" Model M
at work: Topre Realforce 87UKB55
Offline Xichekolas
« Reply #5 on: Thu, 15 October 2009, 12:16:33 »
I used the search, honest! But only thing I could figure to search for were the codes on the fentek site (kpp24ps and kpp24u) which didn't return anything.
Offline Xichekolas
« Reply #6 on: Thu, 15 October 2009, 12:32:14 »
Ah, I just now noticed the 'Genovation' at the top of that page.
I clicked on 'Programmable Keypads', then '24 Key Programmable...' which took me straight to the bottom of that page. Somehow missed the whole brand name.
/me is lazy :P
Offline talis
« Reply #7 on: Thu, 15 October 2009, 12:43:19 »
Just for the record, I think the dark gray is the 5.x version, while the light gray version in the review is the 4.x or less version.   The newer ones support media keys, more keys in general, and a few extra locking modifiers (windows key for example, previously you couldn't do a win-e macro for example).
