Author Topic: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Complete)  (Read 932943 times)
Offline ccc24
  • HHKB , Ergodox
Re: [GB] PURPLE/CLEAR ZEALIO SWITCHES NOW LIVE!!!
« Reply #300 on: Wed, 09 September 2015, 15:04:21 »
ordered 70 67g purples...lezzz gooo. Forgot to check the box for the binge raffle before i paid but not a big deal I guess.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #301 on: Wed, 09 September 2015, 23:56:19 »
YES, the Purple Tactile 67g's are very nice  ;D .
Offline Oobly
« Reply #302 on: Thu, 10 September 2015, 01:45:14 »
Ordered 190x 65g. Enough for 3x 60% boards.
And 10x 67g so I can see how they feel. I can always order more springs if I want to change them :D
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Elrick
  • Hype Master
« Reply #303 on: Thu, 10 September 2015, 03:25:23 »
Oobly old stick, I though you were are hard individual wanting some extra pressure to be applied upon your digits?
The 67s should be sublime with any small keyboard because Korean spring strength isn't as strong as the original Cherry's.
« Reply #304 on: Thu, 10 September 2015, 03:33:32 »
Glad I checked on this, was planning to sort out a build to order some for at the end of the month but I need to get on with it!
Offline kekstee
« Reply #305 on: Thu, 10 September 2015, 04:32:49 »
So, I read a couple more reviews comparing the weights and I'm leaning more towards 67g now, except that I fear they might be too heavy. Especially that Topre (45 or 55g?) comparison with resistance on top, then not much kind of got me.
The new stock Clear I have for testing is far too strong towards the bottom for my taste, while an unlubed 62g Clear feels nice since it retains the bump without the strong cushion. But it's a bit gritty and not snappy at all somehow. So.. meh. I don't know.
Offline patchythepirate2
« Reply #306 on: Thu, 10 September 2015, 08:46:29 »
Can I change my order to 67g switches instead of 65g?
Offline eeymiel
« Reply #307 on: Thu, 10 September 2015, 09:35:09 »
Hey Zeal,
I'd like to add a cable and lube to my order. How should I do this? Should I cancel my order and reorder everything, or make a new order for only cable and lube and pm you the orders to merge?
Asking it here instead of PM so others know too how you prefer a change in an order.
I can't modify orders on my end once it has been paid. The only way for me to properly keep track of inventory & order count is to cancel your current order & issue a full refund. Please PM me your order # and first name if you'd like to make modifications to your order.
Offline Zeal
    • Zeal Generation Inc.
« Reply #308 on: Thu, 10 September 2015, 10:54:47 »
I don't have 55g Topre, so I can't comment on it. I can only say the first half of the travel (including bump) on 67g Zealios reminded me of Topre. The latter half still had that ergo clear-like bottom out with a bit more resistance than 65g Zealios. 65g Zealios are supposed to mimic the "62g ergo clear" feel, without the grittiness and a smoother one fluid motion travel. Please remember that stock MX Clears have a bottom out of 90ish grams, which is a lot heavier than any of the offered spring weight options.
Offline Orgell_Evaan
« Reply #309 on: Thu, 10 September 2015, 13:59:17 »
In for 110x65g.
Offline rainb1ood
  • so pretty so plastic
« Reply #310 on: Thu, 10 September 2015, 17:31:49 »
What is the 62g Zealios supposed to mimic?
Offline Zeal
« Reply #311 on: Thu, 10 September 2015, 18:39:52 »
It feels like a slightly bumpier brown that's a tiny bit heavier with a super smooth travel.
Offline rainb1ood
« Reply #312 on: Thu, 10 September 2015, 18:45:35 »
Time to order 65g then! I already have existing order for 62g, please add them together :)
Offline Zeal
« Reply #313 on: Thu, 10 September 2015, 18:48:14 »
I would actually prefer cancelling your current order so you can place a new updated order. It makes it easier for me when packing and going through the order list so I don't have to look at notes I write down under the order. Could you PM me your name & order #? Thanks.
Offline 64rky
« Reply #314 on: Thu, 10 September 2015, 18:52:34 »
Man,  I am looking forward to my 62g's!
Offline Data
« Reply #315 on: Thu, 10 September 2015, 19:05:51 »
oh, fa sho!
Offline Oobly
« Reply #316 on: Fri, 11 September 2015, 05:08:23 »
I'm just a big softy, really... :)
I like my 62g ErgoClears already and I have a bunch of 62g springs I can use if I need to, so I went with 65g. I got just a few 67g so I can try all the types and decide what to use on my actual builds. If 67g turns out to be my "goldilocks" version I'll order a bunch of springs from Zeal. Either of the other 2 weights, I've got what I need.
62g to 67g does seem to be the sweet spot for all MX types, at least for my tastes.
Offline Phirr
  • If you don't work you die.
« Reply #317 on: Fri, 11 September 2015, 09:11:37 »
Hey Zeal, I placed my order for switches, but I think I might want to add some more, as I have a new project coming in about a week. Is it possible to add to my order without paying shipping twice? Marked it in the comments section of the first order
Offline cheddarbek
« Reply #318 on: Fri, 11 September 2015, 09:43:13 »
Ordered 150 65g tactile switches this morning. I'm excited to use these on a couple of boards. Thank you for bringing this to the community Zeal!
The Alps cover 65% of Switzerland's surface area (41,285 km²), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 km²),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #319 on: Fri, 11 September 2015, 09:47:00 »
Everytime I look at this thread I wish I ordered more...I don't need more, but that isn't stopping me from wanting them.  :p
Offline Zeal
« Reply #320 on: Fri, 11 September 2015, 11:25:45 »
If you decide to add more later on, send me a PM/Email with your order # and name, and I'll cancel your previous order so you can make a new updated order. :)
Offline Zeal
« Reply #321 on: Fri, 11 September 2015, 12:50:10 »
Zealio themed bingecaps received. Pictures incoming.
Offline bcredbottle
« Reply #322 on: Fri, 11 September 2015, 13:09:48 »
When will we know who won the bingecaps?
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #323 on: Fri, 11 September 2015, 13:14:30 »
Show me what you got!
Offline ccc24
  • HHKB , Ergodox
« Reply #324 on: Fri, 11 September 2015, 13:18:00 »
anyway you can still get me into the raffle after I submitted my order and forgot to check the raffle box?
Offline Zeal
« Reply #325 on: Fri, 11 September 2015, 13:40:55 »
When the lucky winner unboxes their order of Zealios.
PM me your order #
Offline ccc24
  • HHKB , Ergodox
« Reply #326 on: Fri, 11 September 2015, 13:50:58 »
PM me your order #
[/quote]
sent thanks.
Offline Zeal
« Reply #327 on: Fri, 11 September 2015, 14:10:38 »
Individually numbered screen prints!  :eek: Can you spot the difference?
#10/10
Zeal's :3
Offline Zeal
« Reply #328 on: Fri, 11 September 2015, 14:29:20 »
Zealio themed Lion Keyng :3
The other Zealio themed Bingecaps will be a mystery. Even I don't know what caps were put inside of which envelope! ;)
Offline ccc24
  • HHKB , Ergodox
« Reply #329 on: Fri, 11 September 2015, 14:34:15 »
so purrrty
Offline bcredbottle
« Reply #330 on: Fri, 11 September 2015, 14:38:58 »
Offline Tyr
« Reply #331 on: Fri, 11 September 2015, 15:53:13 »
Holy crap that Lion Keyng looks nice  :eek:
Can't wait for these switches. Probably going to put them on a Planck I ordered from Massdrop with the brass plate. I've been thinking about getting some gold stickers as well. What do you guys think: gorgeous clear "au naturel" switches, or stickered ?
Offline Durvid
  • Thunk thunk thunk..
« Reply #332 on: Fri, 11 September 2015, 16:19:30 »
Hey Zeal, I'm looking to order some switches but for some reason the only options are 1-day shipping and it starts at $15, which is half the cost of my order O_o. Any way to get slower, cheaper shipping?
Offline Zeal
« Reply #333 on: Fri, 11 September 2015, 16:30:15 »
Sorry, it's the only option for USA. I explained the reasoning here:
To everyone asking for a cheaper USA shipping method: There's only Canada Post Tracked Packet USA (4-10 business days), and it costs a mere $1-2 less. Canada Post doesn't have the low prices you guys have in the states. Good thing is overnight shipping is well worth it, trust me. ;)
Offline Durvid
« Reply #334 on: Fri, 11 September 2015, 17:04:58 »
Dang. Sorry I missed that comment. Maybe I'll just get a few less. We shall see!  :D
Offline Sed8op8
  • Keyboard Padawan
« Reply #335 on: Fri, 11 September 2015, 17:13:42 »
Just put in an order for 90 (65g) tactile zealios
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #336 on: Fri, 11 September 2015, 17:38:09 »
Just bought 270 62g purples.  Thanks zeal!
Offline joey
« Reply #337 on: Fri, 11 September 2015, 17:47:27 »
Finally placed an order :cool: Can't wait for my Zealio-themed-bingecap!
Offline Sed8op8
  • Keyboard Padawan
« Reply #338 on: Fri, 11 September 2015, 17:57:28 »
Do you mean if you win one ? I was under the idea that there was 10 caps to be randomly decided to go to 10 of the purchasers who placed there order before this Saturday the 12th
Offline FreeChemicals
« Reply #339 on: Fri, 11 September 2015, 17:58:18 »
I believe this involves bribes.
Offline shoostep
« Reply #340 on: Fri, 11 September 2015, 18:04:21 »
This just makes me more excited to get my hands on those beautiful purple zealio switches!!  I went with the 65g :thumb:
Offline Zeal
« Reply #341 on: Fri, 11 September 2015, 18:47:02 »
Sorry, I don't accept bribes. :P
Offline Elrick
  • Hype Master
« Reply #342 on: Fri, 11 September 2015, 20:06:17 »
Finally placed an order 8) Can't wait for my Zealio-themed-bingecap!
Sorry, I don't accept bribes. :p
Only give it to the youngsters who really praise this type of key-cap  :thumb: .
Your caps are for those that love to embellish their keyboards with little pieces of sculpture, the youngsters will kill for it.
Just make sure you're not giving it away to any old geezers because we don't care one bit about such things plus we can't even see it without our bifocals.
Offline njbair
    • nickbair.net
« Reply #343 on: Fri, 11 September 2015, 20:12:28 »
I, however do accept bribes. Now accepting bids for all the Zealios I currently have (guaranteed to be greater than or equal to zero)!
My boards:
Offline StormyMonday
« Reply #344 on: Fri, 11 September 2015, 23:07:30 »
Sad, but true!  :(
Offline bocahgundul
  • a seal
« Reply #345 on: Sat, 12 September 2015, 09:06:22 »
I just want to ask whats the difference between zealios 67g and topre, I dont know if I want to join this gb or just saving for another topre.  :)
Offline Zeal
« Reply #346 on: Sat, 12 September 2015, 09:22:57 »
MX style switches will never be able to replicate the full Topre experience. I can only say that 67g Zealios has reminded a couple testers of it.
Offline asgeirtj
« Reply #347 on: Sat, 12 September 2015, 17:39:55 »
Just bought about 330 of these bad boys.  Hopefully helps a little bit to pay up for that initial investment.  Just want to say thanks for doing this amazing project.. Making one of GH's most favorite switches(if not THE #1 switch) even better!  Also thank you Zeal for your amazing customer/community interaction, you sir really are the whole package  :thumb:
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Elrick
  • Hype Master
« Reply #348 on: Sat, 12 September 2015, 19:56:02 »
Glad I went all 67g then  8) .
I knew that had to be the final choice because you need a little push back like a 55g Thorpie.
Offline Zeal
« Reply #349 on: Sat, 12 September 2015, 23:01:58 »
A bit under 3 hours left til Bingecap raffle closes!
