Author Topic: Virtually unknown 1st-gen Model M, p/n 1391240  (Read 4460 times)
Offline ander
  • I type, therefore I am
« on: Fri, 28 August 2015, 16:24:58 »
IBM 1391240 RARE VINTAGE CLICKY MODEL M KEYBOARD WITH PS/2 CABLE WITH WARRANTY (eBay)
109736-0
109738-1
It's $275 BIN/OBO, so I'm not suggesting anyone rush over to buy this—but it is sufficiently unusual that I thought I'd post about it.
This p/n isn't in Wikipedia's or Deskthority's Model M lists. There are no references to it on DT or the general Web (that I could find). There's only one brief reference to it here on GH: Someone found one last year and no one knew anything about it.
It looks like a 1390131, except that:
  • The Esc key says Esc / Reset.
  • The silver logo badge has a small "T" in its lower right corner. (For "terminal"? Anyone ever see that?)
What's more, it looks either unused or restored. (The feet aren't even dirty; I don't know about you, but that's the first thing I check... If it's the same board the GH member posted, I'd assume they knew how to clean it up.)
Isn't it remarkable that unseen Model M p/n's can still be appearing? (I'm adding it to WP now, so the entry you see will be a new one.)
« Last Edit: Fri, 28 August 2015, 16:28:23 by ander »
  • Live long and prosper
Re: Virtually unknown 1st-gen Model M, p/n 1391240
« Reply #1 on: Fri, 28 August 2015, 16:28:02 »
interesting...
tp thread is tp thread
Offline ander
« Reply #2 on: Fri, 28 August 2015, 16:38:57 »
Now that I'm not in such a hurry, I realize that interior photos are included. There's a bit of discoloration on the bottom plate—which could be found on an unused unit too, of course—but everything else is indeed quite clean. So this is someone with a 5.5mm thin-wall hex driver.  :?)  The description also says, "All of our items are clean". So I'm guessing it's been restored. Pretty nice, in any case!
Does it belong to someone here?
« Last Edit: Fri, 28 August 2015, 16:41:33 by ander »
Offline esoomenona
  • Gnillort?
« Reply #3 on: Fri, 28 August 2015, 16:47:37 »
« Last Edit: Mon, 31 August 2015, 08:23:40 by esoomenona »
Offline ander
« Reply #4 on: Fri, 28 August 2015, 16:50:24 »
[double post, sorry]
« Last Edit: Wed, 09 September 2015, 19:01:37 by ander »
Offline ander
« Reply #5 on: Fri, 28 August 2015, 16:52:51 »
There is a picture of SDL to PS/2 cable, so the T likely doesn't stand for terminal, right?
Well, the 1390120, from the same period, is considered a terminal board, and it's PC-compatible... What else could "T" stand for? Toaster?
Also, the corner is pretty badly damaged.
You're right, I didn't even notice. So obviously restored, then.
Offline fanpeople
« Reply #6 on: Fri, 28 August 2015, 16:54:46 »
Terminator  :eek: or possibly TRANSFORMER  :eek: Autobots, roll out
« Reply #7 on: Fri, 28 August 2015, 17:22:08 »
Maybe email thus guy and see what he has to say about the part number:
https://linuxious.com/2015/08/04/my-mechanical-keyboard-collection/
Offline E TwentyNine
    • Some of My Keyboards
« Reply #8 on: Sat, 29 August 2015, 06:17:48 »
Used.  I don't see anything restored about it.
The staining on the backplate looks like potential water/moisture damage, and there's rivets missing on numpad side.
Offline ander
« Reply #9 on: Wed, 09 September 2015, 19:04:31 »
Used.  I don't see anything restored about it...
Well, "cleaned", I should've said. Again, when I posted this, I'd seen only the photos that were visible by default, and from those it looked like it could've been unused or restored. Prithee cuttest thou me some slack, dude.
