Author Topic: Sprit RGB LED  (Read 1627 times)
Offline dorf
  • divine creator
Sprit RGB LED
« on: Sun, 30 August 2015, 05:05:13 »
Hi
Got some rgb-leds from Sprit. It's the two pin led so I guess they change colour over time. Would there be a recommended resistor for them?
Offline Thumper_
  • Spend all my money.
Re: Sprit RGB LED
« Reply #1 on: Tue, 08 September 2015, 01:29:45 »
I used to have some of the, off eBay and noticed they won't work on my poker 2 with the stock resistor. Idk which ones those were, but those weren't high enough, the board started to lag as hell and only accept input when the colors weren't red(highest current).
Offline dorf
  • divine creator
Re: Sprit RGB LED
« Reply #2 on: Wed, 09 September 2015, 04:50:56 »
I'll just have to experiment on them then.
Offline dorf
  • divine creator
Re: Sprit RGB LED
« Reply #3 on: Mon, 19 October 2015, 13:44:30 »
I've found that 330ohms is a good choice.
