Author Topic: [GB] Out of the Vault - Series III: By Fans, For Fans (Cancelled)  (Read 124706 times)
Offline harlw
Re: [GB] Out of the Vault - Series III: Lucky 38 and Vault 111 (New Prices!)
« Reply #100 on: Fri, 04 September 2015, 14:44:14 »
OP updated with new banner generously provided by harlw!
Thanks a whole bunch... :thumb:
*nods*
Killer job on the graphics.
Thanks! OP just updated again with a newer version :D
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #101 on: Sat, 05 September 2015, 14:05:35 »
Ordered!
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #102 on: Sat, 05 September 2015, 19:21:38 »
Updated the numbers...looking great!
Thank you for all your support and participation already!
 :eek:
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline harlw
« Reply #103 on: Sat, 05 September 2015, 19:31:29 »
 :o
Nice! We're rockin and rollin.
I will keep getting the word out - I want every set in my mailbox!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #104 on: Sat, 05 September 2015, 20:36:22 »
 :o
Same! Numbers are looking nice. C'mon Wasteland Wares  ;D
Offline 00zeRO
« Reply #105 on: Sat, 05 September 2015, 22:51:41 »
Actual numbers have been updated...we had a few order changes and this caused some of the numbers to go up, and others to go down. All in all, we are still looking nice for less than one week into this thing... :cool:
Offline 00zeRO
« Reply #106 on: Sun, 06 September 2015, 00:15:41 »
To those interested in seeing each individual keycap ordering box and to see the color codes for the keys check this out:
I did not realize this Group Buy contained so many keys... ;D
Offline Cameron
« Reply #107 on: Sun, 06 September 2015, 07:52:23 »
the ones i thought were the same as Carbon SA aren't quite the same after all :(
Offline dutC4
« Reply #108 on: Sun, 06 September 2015, 08:16:09 »
Yes but at least OAS and OBC are very close
« Reply #109 on: Sun, 06 September 2015, 10:35:05 »
Sadly they are the colors from the Hack'd By Geeks set: https://ctrlalt.io/buys/hack-d-by-geeks
EDIT: Sad for you, great for me  ;)
Offline 00zeRO
« Reply #110 on: Sun, 06 September 2015, 16:24:50 »
Does Carbon even exist yet?
« Reply #111 on: Sun, 06 September 2015, 16:25:56 »
Nope. The MassDrop GB ended, but I doubt any sets will be produced for a while.
Offline 00zeRO
« Reply #112 on: Sun, 06 September 2015, 16:53:16 »
What I thought. I only try to match colors of what is done and in production now...as in SA Retro
Offline BrainFlush
  • I type using my knuckles, 30 years running.
    • http://steamcommunity.com/id/BrainFlush
« Reply #113 on: Sun, 06 September 2015, 18:29:30 »
Bought them! Thank you!
Offline E3E
« Reply #114 on: Sun, 06 September 2015, 19:35:26 »
I'm really glad the six pack set has colors that match the jukebox set. :thumb: I plan on using a Row 3 Nuka Cola for a number pad key. I originally planned on slotting it to use as the missing row three key needed for a 75% layout (not included in Jukebox), but it kind of threw off the feng shui. I'm going to use the 1976 Vault key from the wasteland set, though I know it's a slightly off shade, it's close enough to use for now until the 75% set releases on Jukebox Round 2 (from what I've heard).
Aww yeah! I'm so looking forward to this.
This is a mockup of what I have planned until the 75% drop is released.
The only thing that won't exactly match is the Nuka Cola esc and the glow in the dark top row on the pad, but I don't care much about that. :P It'll be fine. I can always switch them out if it bothers me.
Strangely enough, Jukebox was missing a R3 key on both the base set and the number pad. It has the option for a 1u key to replace the long + key, but gives no option to fulfil the second half of that + key, haha. Also no options for filling the long enter key, but I've got that covered.  :thumb: I pretty much want as many keys as possible on my Lightpad.  ^-^
« Last Edit: Sun, 06 September 2015, 19:57:50 by E3E »
Offline Cameron
« Reply #115 on: Sun, 06 September 2015, 20:14:03 »
GX is a fair bit darker than GQM though
Offline E3E
« Reply #116 on: Sun, 06 September 2015, 20:22:07 »
By fair, you must mean really fair, because they are close enough in my opinion for things to work with the Carbon set.
Offline 00zeRO
« Reply #117 on: Sun, 06 September 2015, 20:45:19 »
I thought for sure the Wasteland Wares set would be doing better than this...
Offline E3E
« Reply #118 on: Sun, 06 September 2015, 20:53:25 »
Considering it matches popular Row 3 sets like Nuclear Data and 1976, it is kind of strange that it's not getting much love. Where are the Nuke lovers and 76 fans? Do they know about this drop?
Offline fabian101
  • Cardbox
« Reply #119 on: Sun, 06 September 2015, 22:40:06 »
Ordered some since I'm planning on using some Junktown Novelties caps with Carbon.  :D
[WTB] Nothing For Now
Ducky Legend + Invisible FC660C
Offline Oobly
« Reply #120 on: Mon, 07 September 2015, 02:21:40 »
Carbon was mentioned in the IC and had finished running on Massdrop before this GB started. It also sold more than 600 base sets, so it's a pity this doesn't have matching colours as I think this would sell more sets if it did. It's behind schedule on production, though, due to the massive number of SA sets SP is producing right now.
Oddly enough, none of these caps perfectly match either of my two favourite sets (Penumbra and Carbon), but the orange is close enough, so I may use the orange Nuka Cola on Carbon.
Well, won't stop me ordering them anyway, since I do own Nuclear Data, 1976, Jukebox, Hack'd by Geeks, Retro, etc...
You can't please everyone. If you try too hard, you end up running round in circles.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline zaarx
« Reply #121 on: Mon, 07 September 2015, 07:08:01 »
I'll take the gamble anyday that these will match Carbon  :)
Offline Cameron
« Reply #122 on: Mon, 07 September 2015, 08:43:54 »
Its much darker, its not close enough for me. I'll notice the difference and it'll make me angry if it's on my board
Offline E3E
« Reply #123 on: Mon, 07 September 2015, 14:31:33 »
Haha, damn. Fair enough! Yeah, I wasn't sure if the novelties were for HBG or Carbon when saw those colorways. Obviously, with Carbon happening, I figured it'd be for Carbon, but I also remembered HBG too.
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #124 on: Mon, 07 September 2015, 15:21:04 »
Why not to add just two additional keys to junktown kit in Carbon Colors? So everyone is going to be happy. I am ok with paying more. It will just make the kit approx 6$ more expensive :).
Offline 00zeRO
« Reply #125 on: Mon, 07 September 2015, 18:32:09 »
edit: No more color changes...I will put it up for IC Series IV
« Last Edit: Mon, 07 September 2015, 19:39:08 by 00zeRO »
Offline 00zeRO
« Reply #126 on: Mon, 07 September 2015, 19:40:09 »
I may be late with invoicing so I will likely extend this Group Buy an extra week for payments due by October 14th.
The numbers are looking good.
Offline BlueTirrick
« Reply #127 on: Tue, 08 September 2015, 12:22:45 »
How would these fit on a poker 2?
Offline 00zeRO
« Reply #128 on: Tue, 08 September 2015, 12:31:04 »
Very carefully...
They may seem a bit out of place unless you have a set of SA profile keys to match key height.
Offline BlueTirrick
« Reply #129 on: Tue, 08 September 2015, 13:31:33 »
Very carefully...
Ahh not for me then :(
Offline zaarx
« Reply #130 on: Tue, 08 September 2015, 13:35:21 »
I reordered, had to get a couple more sets :)
Offline 00zeRO
« Reply #131 on: Tue, 08 September 2015, 17:19:02 »
PM'd
Offline Oobly
« Reply #132 on: Wed, 09 September 2015, 03:46:58 »
Ordered them all.
Offline apolotary
  • Кто-нибудь купите мои клавиатуры ;__;
« Reply #133 on: Wed, 09 September 2015, 06:50:14 »
Updated for the second time, threw in a couple more sets.
Offline LechnerDE
« Reply #134 on: Wed, 09 September 2015, 08:38:36 »
I'd like to combine orders with fellow Germans to split shipping costs. Message me if you are interested  :thumb:
Offline 00zeRO
« Reply #135 on: Wed, 09 September 2015, 10:35:25 »
PM'd  :p
Offline 00zeRO
« Reply #136 on: Thu, 10 September 2015, 09:41:56 »
Calling on all Fallout Fans...it has come to my attention that I will need to provide SP with a letter of permission from Bethesda/ZeniMax in order to proceed with the Nuka Cola keycap legend. SP notified me that the DSA GB will be the last Nuka Cola use until they receive a letter stating that I have the Creator's permission to use the design.
I am going to contact Bethsoft/ZeniMax and plead with them for this Fan Art use. I will do my very best to state our case and goal here, and that I am not intending to make money off of this and that I am willing to either give them all profits, or donate them to a charity of Bethesda's choice. My hope is that they will give us a nod for this to go on. I would even be willing to grant them full rights to all the keycap designs if only they can be made for all to enjoy.
I plan to provide to Bethesda full disclosure, laying all cards on the table in hopes that they will be receiving of what we aim to do here.
What I need from you all is either some form of electronic petition, maybe I can concoct a google form for this, or for you to reach out to them on behalf of this Group Buy.
By the way, the only legend currently being disputed by SP is the Nuka Cola one, but I intend to gain full support from ZeniMax to use the Lucky 38 as well.
Thoughts?
Offline 9jack9
« Reply #137 on: Thu, 10 September 2015, 09:49:38 »
Thoughts?
Well, I can definitely give a shout out on twitter, if you tweet at them, post a link to it here.
Offline 00zeRO
« Reply #138 on: Thu, 10 September 2015, 09:51:18 »
Thanks
Offline Data
« Reply #139 on: Thu, 10 September 2015, 10:01:06 »
Approach Bethesda first. They're more likely to be interested in supporting something like this, especially if it ties into Fallout 4.  I don't think they'll have a problem with it.
Offline 00zeRO
« Reply #140 on: Thu, 10 September 2015, 12:10:53 »
I will try to email them a letter sometime today...busy atm, though.
Offline 00zeRO
« Reply #141 on: Thu, 10 September 2015, 14:52:17 »
Email'd.  :thumb:
« Reply #142 on: Thu, 10 September 2015, 17:58:34 »
Email'd.  :thumb:
Fingers crossed :D
Offline 00zeRO
« Reply #143 on: Thu, 10 September 2015, 20:40:39 »
Email'd.  :thumb:
Fingers crossed :D
Well, I got a partial verdict and I am waiting to appeal. I am thinking of requesting from Brian Fargo...
Offline 00zeRO
« Reply #144 on: Thu, 10 September 2015, 20:50:20 »
I am not feeling good about this...and if Nuka Cola falls, I might as well hang it up with a hearty and heartfelt "I'm sorry to all those who placed their orders." I hate to say it, but I cannot win against this should I ever be sued over anything having to do with any of the likeness issue. Still waiting to see what they say as I try to find someone who can issue permission, but I will say it is not looking good...
« Reply #145 on: Thu, 10 September 2015, 21:56:56 »
Gah, understandable. I posted something over on the /r/fallout subreddit.
Offline harlw
« Reply #146 on: Thu, 10 September 2015, 22:52:18 »
Oh man :(
Would you consider seeing if massdrop could help you actually connect with real decision makers over there if they ran it?
I can ask some of the guys over there if you want. I've worked with them some on key sets.
« Last Edit: Fri, 11 September 2015, 08:35:07 by harlw »
Offline 00zeRO
« Reply #147 on: Thu, 10 September 2015, 22:58:56 »
Thanks. The shock is almost too much.
Offline 00zeRO
« Reply #148 on: Thu, 10 September 2015, 23:01:19 »
Oh man :(
I can ask some of the guys over there if you want. I'm supposed to be working on them with future key sets.
That will be to only thing to save this
Offline apolotary
« Reply #149 on: Fri, 11 September 2015, 04:18:36 »
Might as well repost it to /r/mechanicalkeyboards, 80k users is quite a lot. Posted it on /r/mk
Did Bethesda not approve it after all? I thought they would love it, especially with shipping time coinciding with Fallout 4 launch dates.
« Last Edit: Fri, 11 September 2015, 04:32:07 by apolotary »
