Author Topic: Best business full-sized to get with Cherry Browns?  (Read 2118 times)
Offline keyjay
« on: Sat, 05 September 2015, 00:02:56 »
I've been using a full-sized Leopold with Browns from EK for years and love it. Black with white lettering.
I have as similar one that I had made for me a few years ago by WASD that I use at home, but the lettering has worn off (again) and now the keyboard is intermittently acting up. I need to replace it.
I was hoping to find something quieter that feels similar. I tried a Type Heaven but it just doesn't let me type as fast and accurately as the Browns. I tried a Quite Pro but it has an activation force that's way above my comfort zone. (It's 65g.)
I like 45g (which is what Browns and the Type Heaven have).
I like a black keyboard, and I need to see the lettering (white) -- preferably laser-etched.
I've seen various offerings but most of them are "gaming" styles and I don't want any of that nonsense on my keyboard. I want a business-grade styling and build with Cherry Browns.
I will be adding o-ring dampeners.
I'm buying in the US.
I'd greatly appreciate suggestions on the best keyboard to get for my purposes.
Offline keyjay
Re: Best business full-sized to get with Cherry Browns?
« Reply #1 on: Sat, 05 September 2015, 02:59:38 »
Best bet WASD?
Offline saturnotaku
« Reply #2 on: Sat, 05 September 2015, 06:43:05 »
You could just replace the keycaps on one of the boards you already have. A nice set of thick dye-sub PBT caps will feel great and never wear out.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3 on: Sat, 05 September 2015, 07:45:31 »
For a full size board, I would check offerings from Ducky or Filco.
Offline samhwang
« Reply #4 on: Sun, 06 September 2015, 01:50:02 »
I would recommend Filco Majestouch 2 or the Rosewill RK-9000 (must be this explicit series), or even one same Leopold like the one you are using.
Offline daerid
    • Rossipedia
« Reply #5 on: Sun, 06 September 2015, 23:17:06 »
WASD V2
or even a DasKeyboard 4 Pro
Offline Oobly
« Reply #6 on: Mon, 07 September 2015, 08:40:50 »
If you love the Leopold, why not get another Leopold (the FC900R comes in a version with top or front printed PBT keycaps that are very nice).
If the WASD weren't acting up, I'd recommend getting a nice set of doubleshot caps for it, so the legends will never wear out and they improve the feel of a board.
I know these aren't White on Black, but they're very smart and businesslike and if the colourway appeals to you, they're really top quality caps: https://www.massdrop.com/buy/originative-gmk-dolch
Thick doubleshot keycaps in Cherry profile made by GMK, with a consistent underside gap which suits thin orings. Your fingers will appreciate them :)
Or if you don't mind getting just a little more colour in your life, there's SkiData+, also going to be made by GMK: https://geekhack.org/index.php?topic=74079.0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
