Author Topic: Topre dilemma  (Read 3544 times)
Offline raymogi
Topre dilemma
« on: Wed, 09 September 2015, 23:09:04 »
Ok so I've ordered Hypershere's silencing rings from eBay and thinking of doing my first keyboard mod, which is to silence my 55g 87U.
Then it got me thinking... since everyone is saying the endgame board is a HHKB with 55g domes, why not do that?
I already have all the necessary ingredients to perform this mod. Now the question is, should I just wait for the silencing rings to arrive and do the mod on the RF? Or should I just go ahead and move some of the 55g domes to my Type-S? I'm thinking of doing numbers, alphas, and spacebar only to keep it "uniform" both on the HHKB and the remainder of the RF board.
Not gonna do it to say my black HHKB though as I might be too lazy to do 2 mods to a black board at once, and plus, I bought a Type-S to get that baller logo in the case anyway :D
Please feed my addiction.
Re: Topre dilemma
« Reply #1 on: Thu, 10 September 2015, 05:49:15 »
Personally I wouldn't, because then there would be one less 55g 87U in the world :(
Unless you are in a rush, just enjoy both keyboards as they are for now.
Also dampening rings with non-Type S sliders will force the keys to be depressed by the thickness of the rings.  Type S gets around that by having slightly thinner bases on the sliders, to allow a little extra room for the silencing bits.
Offline bocahgundul
  • a seal
Re: Topre dilemma
« Reply #2 on: Thu, 10 September 2015, 06:46:01 »
Offline raymogi
Re: Topre dilemma
« Reply #3 on: Thu, 10 September 2015, 07:06:46 »
I just finished the transplant.
OMG this HHKB is so good right now. Don't worry I'm not throwing away the RF. Gonna wait for the silencing rings to arrive and I might put them there. But in the meantime, I'll just use that board if I feel like typing with that 45g feeling.
Offline bocahgundul
  • a seal
Re: Topre dilemma
« Reply #4 on: Thu, 10 September 2015, 08:45:50 »
is it really that good m8?
Offline Jokrik
Re: Topre dilemma
« Reply #5 on: Thu, 10 September 2015, 10:08:55 »
Impressive :) way to go
Offline jerue
  • (Whenever that happens :P)
Re: Topre dilemma
« Reply #6 on: Thu, 10 September 2015, 10:21:04 »
Need to buy another 55g RF before I make a 55g HHKB. Love my 55g RF too much to ruin it. #firstworldprobz
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Topre dilemma
« Reply #7 on: Thu, 10 September 2015, 10:29:47 »
55g HHKB for life.
ONE OF US, ONE OF US
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Topre dilemma
« Reply #8 on: Thu, 10 September 2015, 10:36:20 »
I don't get the whole silencing Topre thing, leave em alone people.. That's like putting spinners on a Ferrari. :D
Re: Topre dilemma
« Reply #9 on: Thu, 10 September 2015, 11:06:58 »
Seriously. It's stupid
Offline keshley
    • Blog n stuff
Re: Topre dilemma
« Reply #10 on: Thu, 10 September 2015, 12:40:32 »
But what if you're a ninja? Ninjas have to type too!
HHKB Pro 2       Pok3r
Offline Jokrik
Re: Topre dilemma
« Reply #11 on: Thu, 10 September 2015, 18:17:11 »
They use scroll?
Offline Hypersphere
Re: Topre dilemma
« Reply #12 on: Thu, 10 September 2015, 18:54:49 »
Everyone needs to decide for himself on such questions as whether or not to install Silencing Rings or to do a dome transplant. My own experience has been that both procedures are worth the expense and effort. My RF87UB55 went from refined to sublime by installing Silencing Rings. In addition, I have a Type-S HHKB Pro 2, but my black HHKB Pro 2 sounds and feels better than the Type-S after installing Silencing Rings. In comparison, I put both 55g domes and Silencing Rings in another black HHKB Pro 2, and I consider the Rings to have made more of a difference than the domes. I've not noticed any difference in key travel after installing the Rings in either a RF or HHKB.
Offline raymogi
Re: Topre dilemma
« Reply #13 on: Thu, 10 September 2015, 20:00:59 »
Yeah I'm looking forward to receiving the rings and install it in my now 45g RF.
Offline Macsmasher
Re: Topre dilemma
« Reply #14 on: Thu, 10 September 2015, 22:14:11 »
I thought that for a long time as well because the silent 87Us still maintained the same key travel as standard. In Realforce's case, they use a different switch housing (purple) to accommodate the silencing material. However, according to PFU, the HHKB Type-S has reduced key travel. 3.8mm vs 4mm for non-silenced. I suspect PFU uses the same case for both models. And since the HHKB uses case mounted switches, that would explain the reduced key travel. I'm not saying 3.8mm is bad. In fact, it may very well feel better than 4mm. The point is simply that the HHKB Type-S does in fact have reduced key travel.
https://www.pfu.fujitsu.com/hhkeyboard/type-s/spec.html#pro2_spec
https://www.pfu.fujitsu.com/hhkeyboard/hhkbpro2/spec.html
« Last Edit: Thu, 10 September 2015, 22:26:12 by Macsmasher »
