Author Topic: Best cheap cherry red keyboard for counterstrike ?  (Read 2441 times)
Offline LifeIsGooD2
« on: Fri, 11 September 2015, 08:51:55 »
Already have a cherry brown filco if I need it so Im just looking for a nice board with reds mainly for gaming.
Was thinking of the CM Storm QuickFire Rapid - Tenkeyless Mechanical Gaming Keyboard with CHERRY MX Red Switches
that a good choice ? Or should I go something more expensive? It doesn't absolutely need to be that cheap but it would be nice if thats all I had to pay. I would like for it to be fairly nice.
Offline merlin64
    • MechMerlin
Re: Best cheap cherry red keyboard for counterstrike ?
« Reply #1 on: Fri, 11 September 2015, 09:05:11 »
The CM Storm is a good choice though to be honest, I'm barely able to tell the difference between red and brown switches, except on switch testers.
I would say to go for either a slightly heavier linear switch or stick with what you got.
Offline saturnotaku
« Reply #2 on: Fri, 11 September 2015, 09:23:29 »
Agreed.
However, if you're really desperate for something with reds, go through the classifieds here and on reddit's mechmarket. You're virtually guaranteed to find something for much less than you would pay at retail.
« Last Edit: Fri, 11 September 2015, 09:29:36 by saturnotaku »
Offline osi
« Reply #3 on: Fri, 11 September 2015, 09:28:46 »
I think a quickfire rapid will do you well. Good luck with your search!
« Reply #4 on: Sun, 13 September 2015, 04:41:46 »
QFR is a good solid leyboard, but do they still sell them?  I thought they'd been phased out in favour of the QFR-I.
Offline ADFX_Pixy
« Reply #5 on: Mon, 14 September 2015, 14:44:46 »
Looking on Amazon, the Quickfire Rapid is at a good price at $83.22. If you want a numpad but want to keep the ten keyless form factor, the Quickfire TK is a few cents more expensive at $83.99. If you don't mind a full size format and abnormally large enter key, the Steelseries 6GV2 is at $79.99.
CM Storm Quickfire Stealth Cherry MX Brown
Mechanicalkeyboards.com MK 2016 Cherry MX Brown
Offline Doctah
  • FROM THE ALPS
« Reply #6 on: Mon, 14 September 2015, 19:08:02 »
You're perfectly fine with going with the QuickFire Rapid. It's one of my planned future buys simply because it's cheap, TKL, and has Cherry switches. Don't worry about going more expensive unless you really want to. It's an entry-level board, but a good one at that.
Offline trenzafeeds
  • **** off
« Reply #7 on: Mon, 14 September 2015, 19:40:42 »
but but non-standard bottom row...  :(
demik will never leave.
Unless he gets banned.
Offline BADBADNOTGOOD
« Reply #8 on: Tue, 15 September 2015, 18:02:11 »
You already have browns I doubt it would make much of a difference.  WarOwl is GE and if you listen to him play you can hear him using MX blues.  But if you still want a cheap mx red board the noppoo spyder is like $60 and looks pretty nice.  QFR was my first mechanical keyboard and I highly recommend it so you can't go wrong with it either.
