Author Topic: USB-cable defect?  (Read 1774 times)
Offline Eszett
USB-cable defect?
« on: Sat, 12 September 2015, 09:47:34 »
Hi! My custom USB cable show resistance between both shields, is it defect or still usable? 2.24 kilo ohm, which is the same value as if i measure nothing.
Re: USB-cable defect?
« Reply #1 on: Sat, 12 September 2015, 11:15:51 »
If it's the same as measuring nothing then that means they aren't connected at all.  USB only needs four wires and they are all connected to the pins inside the connector so I expect it will work just fine.
Actually I'll go one better - I've just checked a couple of cables here and those shields aren't connected either and they've never given me any problems so don't worry about it :)
Offline Eszett
« Reply #2 on: Sat, 12 September 2015, 12:10:05 »
Good, that helps me. Thanks you, orange!
