Author Topic: Keyboard spits out characters of column8.  (Read 3262 times)
Offline Eszett
« on: Sat, 12 September 2015, 13:04:59 »
Hi! I have the following problem: my custom build keyboard triggers all switches of column 8 ("6", "z", "g", and "b"), like this:
6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb............ and I dont know why. It irregularly stops somtimes, or starts flooding me with these characters again. The Teensy2.0 is well insolated, this can't be the problem. This suspect column 8 is connected on Teensy's pin PB2. When I deactivate PB2 in my firmware, the problem is gone. But why on earth does the pin PB2 detect all these switches pressed, when there is no switch pressed?
« Last Edit: Sat, 12 September 2015, 13:18:30 by Eszett »
Offline njbair
    • nickbair.net
Re: Keyboard spits out characters of column8.
« Reply #1 on: Sat, 12 September 2015, 13:17:41 »
6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb6zgb............ and I dont know why. Sometimes it stops, but most time it is flooding me with thes characters. The Teensy2.0 is well insolated, this can't be the problem. This suspect column 8 is connected on Teensy's pin PB2. When I deactivate PB2 in my firmware, the problem is gone. But why on earth does the pin PB2 detect all these switches pressed, when there is no switch pressed?
Sounds like a short circuit is making the firmware think a switch is being pressed. Do you have a multimeter? You can do a continuity test from the teensy pin to each of the switch solder points and find the one that is misbehaving.
My boards:
Offline Eszett
« Reply #2 on: Sat, 12 September 2015, 13:37:01 »
Hi njbair! Well, the column itself seems to be fine. For example when I try to press "g" nothing happens, because this character is in row3 and row3 I have not yet connected to a Teensy I/O pin. But the pin PB2, which scans column 8, scans "6zgb", which is the whole column. How can this be?
Offline njbair
    • nickbair.net
« Reply #3 on: Sat, 12 September 2015, 13:47:19 »
Have you ruled out a firmware issue? That is, are you running a known good default keymap, or something you've customized?
My boards:
Offline Eszett
« Reply #4 on: Sat, 12 September 2015, 13:56:54 »
Yes, I'm running TMK firmware. The thing is: sometimes the keyboard works without flooding me with characters. The flooding occurs when I reboot the PC with the USB cable plugged in. But when I reboot the PC first, and then plug the USB cable in, the keyboard works fine, without flooding me with characters.
Offline njbair
    • nickbair.net
« Reply #5 on: Sat, 12 September 2015, 14:02:38 »
You may want to ask about this in the TMK Firmware thread. I'm not an expert but I think there's a different HID protocol for boot mode, which may come into play when you're plugged in during boot. It's probably not the whole issue, but it may be a part of it.
My boards:
Offline Eszett
« Reply #6 on: Sat, 12 September 2015, 14:14:02 »
Yes, I will do that, thanks njbair.
Offline hasu
  • @tmk
« Reply #7 on: Mon, 21 September 2015, 03:00:53 »
If you still have the problem, post pics, schematic or codes of your keyboard as possible.
I'll help you and you'll get many help from the GH community. I beleive you need many eyes to resolve your problem shortly in the end.
