Author Topic: Pok3r Plate Trouble  (Read 11260 times)
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Pok3r Plate Trouble
« on: Sat, 12 September 2015, 22:27:52 »
So, I just tried to put my Pok3r in a Vortex aluminum case. What I found was that it won't fit because the plate is longer than the PCB. It actually physically can't fit in the case. The PCB is fine. One side of the plate and PCB line up perfectly and then there is this (sorry for the potato, it's late, and I'm annoyed):
Does anyone else have this issue. I am not happy!  :mad:
Offline merlin64
    • MechMerlin
Re: Pok3r Plate Trouble
« Reply #1 on: Sat, 12 September 2015, 22:58:09 »
You may have to take better photos, from the photos it looks like its smaller than the vortex case
Offline inanis
    • SEALWoodworking
« Reply #2 on: Sat, 12 September 2015, 23:17:07 »
Okay, take two:
One side of the case (fine):
Other side of the case (NOT FINE):
The plate on that side clearly extends beyond the PCB:
Offline Thumper_
  • Spend all my money.
« Reply #3 on: Sun, 13 September 2015, 05:59:42 »
It looks like the plate is a bit off, you might can sand it down a bit, but I doubt it'll look perfect then, as the corners would be a bit sharp.
How does it fit in the original case?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4 on: Sun, 13 September 2015, 09:38:54 »
If you are willing to mail me you plate and case I will fix that for you.
Offline inanis
    • SEALWoodworking
« Reply #5 on: Sun, 13 September 2015, 09:51:22 »
It fits fine in the original case, which certainly has more wiggle room than any of the aftermarket cases I have. My question is, are all Pok3rs like this, or did I just manage to get a defective one? One on side the plate and the PCB line up perfectly, on the other side, the plate is a little too long. It isn't off center or anything, it is cut to the wrong size.
You are too nice! I actually have the tools to fix it here (I live with a millwright), I'm just pretty annoyed that it is even happening in the first place. And then I wondered if I'm the only one that has this problem.
Offline Melvang
« Reply #6 on: Sun, 13 September 2015, 14:49:20 »
Quote from: inanis link=topic=75191.msg1863905#msg1863905 date=1442155882
[quote author=Melvang link=topic=75191.msg1863901#msg1863901 date=1442155134
[/quote]
It's funny you mention that as I am aa Union millwright myself.  Local 2158
Offline file_id
« Reply #7 on: Sun, 13 September 2015, 18:07:23 »
Your pok3r plate is bent. Been seeing alot of Pok3r with various defects. I myself have gone through of them with a case defect, keycap defect, and usb female plug broken. Here is what a Pok3r in a Tex case should look like.
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline inanis
    • SEALWoodworking
« Reply #8 on: Sun, 13 September 2015, 18:39:12 »
It's not bent, it is too long. Mine also fits in my TEX case, however the Vortex case has tighter tolerances and it will not fit in either of the two I have. All my other 60% boards fit in the Vortex case no problem.
Does the plate on your Pok3r match up to the PCB or does it run a bit longer on one side as mine does?
Offline KHAANNN
« Reply #9 on: Tue, 15 September 2015, 12:54:25 »
vortex case is very challenging, here's a possible solution:
Drill the PCB-holes
Some PCB's come with wide holes so you can center the plate easily, yet obviously that's not the case with the pok3r you have, if you drill the pcb-holes/enlarge them, you can move your plate a bit to the left so it barely fits
Offline inanis
    • SEALWoodworking
« Reply #10 on: Tue, 15 September 2015, 12:58:22 »
Drill the PCB-holes
Thank you for the suggestion!
Here is the thing...I'm making a case for this, and I need to know if just my Poker3 has this issue, or if all Poker3's have this issue. If it is just mine, then I'm fine, I'll fix it and get it in there. However, if it is ALL of them, then I need to adjust my jig for the case I'm making.
Offline maroder
« Reply #11 on: Fri, 18 September 2015, 09:42:14 »
That doesn't look right. I have the same case with a Poker III with MX-Clears and it fits near perfect.
Offline inanis
    • SEALWoodworking
« Reply #12 on: Fri, 18 September 2015, 09:44:16 »
This is what I needed to know. Thank you very much. :) I will fix up the plate to fit appropriate. I love that the Vortex case fits so tightly compared to others. The QC on the Pok3r is not exactly up to what I was expecting.  :rolleyes:
Offline maroder
« Reply #13 on: Fri, 18 September 2015, 09:46:38 »
Great! Glad I could help. BTW how are the greens on the Pok3r? I am feeling the itch again - haven't tried the greens yet  :-X
Offline inanis
    • SEALWoodworking
« Reply #14 on: Fri, 18 September 2015, 10:36:34 »
I LOVE Greens. I am used to typing on Buckling Spring, and while it is not exactly the same, it does remind me of that a bit. I find it super satisfying. People say they are heavy, but I don't notice any inconvenience caused by it. In fact, after typing on Blues for a long time I actually like the Greens better because of the weight.
Offline KHAANNN
« Reply #15 on: Fri, 18 September 2015, 10:41:47 »
Hate to be a buzzkill, but yours also doesn't fit, the plate should be flush with the case (sit below the case by 0.1mm)
But I guess 0.2mm above could also work
Offline Hypersphere
« Reply #16 on: Fri, 18 September 2015, 10:46:41 »
My Pok3r has a defect as well. The case is "warped". That is, it does not sit flat on the desk -- the keyboard wobbles. Fortunately, I don't notice this when the keyboard is placed on my wide mouse/keyboard rubber mat.
Offline inanis
    • SEALWoodworking
« Reply #17 on: Fri, 18 September 2015, 12:06:22 »
Yeah, mine had other issues too beyond the ****ty plate. In the stock case there was a stuck screw with the head snapped off, and there was orange grease pencil all over the white plate. Overall this was not an impressive buy.  :rolleyes:
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #18 on: Fri, 18 September 2015, 12:20:36 »
My pok3r was a joke.
This straight out the box and the second one had bubble on the pcb that once scratched revealed yet more rust. Instead of trying to give people a solid case and cut corners elsewhere they should have just stuck with solid plastic. Pretty poor show.
Offline KHAANNN
« Reply #19 on: Fri, 18 September 2015, 12:28:29 »
I have alu vortex cases, they wobble too, my solution was to re-attach the rubber adhesive, slightly above the slot so it stresses the surface unevenly
This is why I like the cases that use dome adhesives, the circle shape of the rubber prevents wobbling, both the TEX cases and the slim vortex cases use those adhesives
Once again, another easy solution is to just buy and stick some dome adhesives, even if your case is warped, they might be able to offset that (they are soft, soft enough to absorb 1-2mm of unevenness)
Offline inanis
    • SEALWoodworking
« Reply #20 on: Fri, 18 September 2015, 12:51:38 »
Yikes! That is completely unacceptable. I hope they do some better QC going forward. I loved my Poker2, so this is pretty disappointing.
It is true, those hemisphere bumpons are like magic.  :thumb:
Offline Hypersphere
« Reply #21 on: Fri, 18 September 2015, 13:30:54 »
These reports make one wonder if Vortex is dumping their irregulars on Group Buys. Alternatively, quality control at Vortex in general is quite poor.
BTW, I was disappointed in the quality of the legends on a recent purchase of Vortex double-shot PBT keycaps, and the fit of the stems was inconsistent across the keyboard.
Offline KHAANNN
« Reply #22 on: Fri, 18 September 2015, 14:23:56 »
I suspect GB's, certain companies, do everything they can to get lower prices and either given rejects, or get rejects and just don't care, for some extra bucks
I got this impression in general from the excessiveness of issues and the quality of products I receive in general
It's always better to just pay for immediately available items whenever you can, from places with good support and well defined return/replacement policies
Offline therivenman
« Reply #23 on: Fri, 18 September 2015, 19:42:19 »
I thought that I had this same when I got my Pok3r, but then I noticed that one of the rubber feet was sitting slightly outside of it's indentation.  I peeled if off and reapplied it, and now the keyboard sits perfectly flat on a desk.  Might be worth looking at.
Offline maroder
« Reply #24 on: Sat, 19 September 2015, 04:29:56 »
No worries. I uploaded an old picture by mistake in which I used to long screws for the case, so the case couldn't sit flat.  :))
Here an actual more recent picture where the plate sits near perfect on the case.
« Last Edit: Sat, 19 September 2015, 05:06:54 by maroder »
Offline jcoffin1981
« Reply #25 on: Mon, 21 September 2015, 20:05:30 »
It looks like the plate is not flush on the left side.  Could there be some little nub or defect in-between?  It's possible that if you got it farther to the left that it would clear the case on the right side.
As an aside, I have not disassembled this board, so I may be talking out of my *$#.
