Author Topic: Do you switch the Ctrl & Caps Lock on your keyboard?  (Read 22441 times)
Offline mikes41720
    • Ranting & Rambling
« on: Fri, 18 September 2015, 02:02:04 »
Hello, friends. I have a Realforce 87U and I'm trying out the DIP switches. The only DIP switch function that particularly interests me is option 1, which switches the left Caps Lock with the left Ctrl. I'm not sure if it's better in terms of ergonomics, as I'm used to using my pinky for Ctrl. But I'll give it a shot. How many of you guys have this set-up with your boards?
On a side note, also flipping the spacebar. But I have a wrist rest, so I'm not sure if it's really necessary. Flipped Spacebar Master Race?
And as I copy paste this from Reddit, my Pinky goes to Ctrl+C but it does nothing, I only realize now that it's now Caps Lock.  :))
Offline sth
  • 2 girls 1 cuprubber
Re: Do you switch the Ctrl & Caps Lock on your keyboard?
« Reply #1 on: Fri, 18 September 2015, 02:06:12 »
i use ctrl to the left of a. i like it.
i dont flip my spacebar. it's not necessary if you maintain good typing posture. some people do it anyway. i don't understand why.
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Fri, 18 September 2015, 02:07:09 »
It takes time to get used to it, but Its better in terms of ergonomics and possibly hitting the caps lock by accident.
And flipped spacebar masterrace, everybody who tell you the opposite is wrong.
Azerty Propagandiste
Offline Durvid
  • Thunk thunk thunk..
« Reply #3 on: Fri, 18 September 2015, 02:07:43 »
Got used to it on the poker, but haven't tried it out on any of my topre boards. I don't have any mx anymore, so we'll see if I can even do that.
Offline sth
« Reply #4 on: Fri, 18 September 2015, 02:09:30 »
The master race (German: die Herrenrasse) is a concept in Nazi ideology in which the Nordic race—a branch of what in late-nineteenth and early-twentieth century taxonomy was called the Aryan race—represented an ideal and pure white race. In Nazi ideology, the Nordic race was the purest example of the original racial stock of those who were then called the Proto-Aryans,[whom the Nazis believed to have prehistorically dwelt on the North German Plain and to have ultimately originated from the lost continent of Atlantis. The Nazis declared that the Nordics (now referred to as the Germanic peoples), were the true Aryans (ethnically closest descendants of the Proto-Indo-Europeans) because they were much less racially mixed with peoples who were "non-native" to the European continent, than other Indo-European peoples, such as the Slavic peoples, the Romanic peoples, and the Indo-Iranian peoples. Based on this claim that the Nordic peoples were superior to all other races, the Nazis believed they were entitled to expand territorially. This concept is known as Nordicism. The actual policy that was implemented by the Nazis resulted in the Aryan certificate, the one form of the official document that was required by the law for all citizens of the Reich was the "Lesser Aryan certificate" (Kleiner Ariernachweis) which could be obtained through an Ahnenpass which required the owner to trace their lineage through baptism or birth certificates or certified proof thereof that all grandparents were of "Aryan descent".
Along with the Jews and Gypsies, the overwhelming majority of the Slavic population were defined as non-Aryan Untermenschen, and a danger to the "Aryan" or Germanic Übermenschen master race. According to the Nazi secret Hunger Plan and Generalplan Ost, the Slavic population were to be removed from East-Central Europe through expulsion, enslavement, starvation, and extermination. The Nazis eventually decided to exterminate the Poles and most other Slavic people, except for a small percentage of people living in Eastern Europe who were deemed to be non-Slavic descendants of Germanic settlers, and thus subjects for Germanisation.
Offline nmur
  • ಠ_ಠ
« Reply #5 on: Fri, 18 September 2015, 02:14:07 »
why Caps Lock is on the home row is beyond me. I guess it won't change now because everyone's too used to it.
flipping the space bar makes the surface perpendicular to your thumb's surface, but because you want to apply force to the switch vertically, if your spacebar is flipped then you'll also be applying force forward, which can cause friction.
Offline mikes41720
« Reply #6 on: Fri, 18 September 2015, 02:48:08 »
It's my first day using the new Ctrl and Caps Lock positioning. How long did it take you before you got used to the new lay-out?
Okay, I'll try to give it a try for a week. I don't really hit the caps lock by accident anyway. And as for the flipped spacebar, maybe I find it less impressive because I have a wrist rest to level me with the keyboard?
I believe it's an option on the Realforce. Not sure about the Novatouch, Leopold and HHKB though.
A period in mankind's history that screams utter stupidity.
Can I say I also don't like how the flipped spacebar looks? Also, I think because I have a wrist rest, it's less impressive to flip it.
Offline raymogi
« Reply #7 on: Fri, 18 September 2015, 05:19:45 »
Ever since I swear by HHKB, I have switched my Ctrl to CapsLock on all of my keyboards.
I went a step further by switching the Backspace to backslash too (I forgot remap it to backspace in this keyboard :p).
Please feed my addiction.
Offline keshley
    • Blog n stuff
« Reply #8 on: Fri, 18 September 2015, 07:40:04 »
HHKB doesn't have a layer 1 caps lock, its on the Fn layer on Tab IIRC. I don't remember the last time I used capslock, and I use TMK on my HHKB anyways now. Pretty sure I don't have it bound anywhere.
My Pok3r, nor my Varmilo TKL have a capslock key either. On my Pok3r its Function, and I've remapped it to Control on my Varmilo. Key chords are easier with Control in its proper location next to A.
Its probably more ergonomic as well. You have to move your hand to use Control in the corner. While you can maintain the same position when its next to A. Or at least, there's less movement.
If you do key chords often, it won't take long to adjust. The only chord that gave me problems was two handed ctrl+alt+delete, but that's probably because I tended to do that after I was already standing up. I fixed that by switching to Windows+L instead. On a TKL or full-sized, when sitting at the keyboard, I have always used ctrl+alt+delete one handed.
So, quirky stuff like that aside, it was a pretty easy transition. Control+letter chords became second nature within a few days.
HHKB Pro 2       Pok3r
Offline dgneo
  • Supervillain
« Reply #9 on: Fri, 18 September 2015, 07:47:56 »
Agreed on both fronts. Since using my HHKB, I find myself caps locking by accident on my 7G a ton at home.
I really wish I could modify the firmware on the 7G to fix all the wonkyness it has. Replace the big ass enter with a regular one, standard size delete, etc. One can dream!
Offline jd29
« Reply #10 on: Fri, 18 September 2015, 07:55:39 »
I switch Ctrl with Alt because I'd rather be able to hit it with my thumb than my pinky. If I change Caps to anything it's backspace.
Especially it you've got wide modifiers, I urge you to give it a shot. Alt is a wasted use of a thumb key.
Offline strict
  • TKL Zealot
« Reply #11 on: Fri, 18 September 2015, 07:57:19 »
Flipped master race checking in. Switchable Ctrl/Caps is one of my favorite things about Realforce keyboards. Pair that with a flipped spacebar and you're on the path to success in life!
Offline sth
« Reply #12 on: Fri, 18 September 2015, 08:17:55 »
not if you use it for tab switching/window switching :)
Offline jerue
  • (Whenever that happens :P)
« Reply #13 on: Fri, 18 September 2015, 08:29:17 »
We have the exact same setup! :D
Yes, I use Ctrl in place of caps lock. Flipped space bar is nice because I have bad typing skills and use my index finger to hit the spacebar, this way I only get shine on the very edge of the spacebar. It makes my transition to my HHKB (when I need to use my other station at my desk) easier. I almost never hit the caps lock, and do so when inadvertently trying to do ctrl+x/c/v/ whatever.
Offline mikes41720
« Reply #14 on: Fri, 18 September 2015, 09:43:57 »
I'm so used to having the backspace in the top most area. How does it feel having it in the backslash area? Is it more ergonomic?
Glad to hear it! I'm on my first day and I've already messed up some of the more usual functions like Ctrl + C, V, S, A, Z, X and the like. Hope it gets easier as time passes!
Or one can always sell it off and get a new keyboard.  :p
I don't think I can program my Realforce to do that though? Or do you mean use another third party program? So basically use the left alt as the Ctrl?
Well, I have that exact same set-up right now. Does that make me successful in life already?
Cheers to us having the exact same set-up! Still on my first day with the Ctrl/Caps Lock experiment. That's unique! I don't think I'd ever hit the spacebar with anything else than my thumb!
Offline raymogi
« Reply #15 on: Fri, 18 September 2015, 10:05:56 »
For more it is. But maybe because I'm just so used to HHKB layout. Even though I cycle the keyboards I use at home, I have HHKB in both of my offices so that layout sticks with me the whole time.
Offline mikes41720
« Reply #16 on: Fri, 18 September 2015, 10:20:06 »
My Realforce 87U with 55g domes are amazing, but I've always been curious to how the 45g domes from the HHKB feel like. I keep reading that people say it's more 'fun' and 'alive' to type on. Hmmm.  :))
Offline raymogi
« Reply #17 on: Fri, 18 September 2015, 10:23:48 »
It's lighter but not to the point it's not enjoyable to type on.
And sometimes after not hearing any noise from the silenced keyboards, it's refreshing to hear the Topre clacks.
Offline mikes41720
« Reply #18 on: Fri, 18 September 2015, 10:49:28 »
Well, I can still get a delicious amount of thock from the RF board! But I'm just curious to hear how the HHKB fares against it. But then again, I might be hard pressed to go down to 60% form factor.
Offline Shaussman
« Reply #19 on: Fri, 18 September 2015, 11:37:41 »
I leave my control+caps lock normal because I honestly find it to be more comfortable to hit control with my pinky, especially when playing games.
As for the spacebar thing, I leave mine normal. I think that flipping it just looks awful and is incredibly uncomfortable. My thumb doesn't hit the edge of my spacebar anyways...
MX Brown Quickfire XT | MX Clear WASD VP3 | MX Blue Ducky Zero
Offline Rayoui
« Reply #20 on: Fri, 18 September 2015, 11:46:28 »
I had reservations about the layout at first but after a couple of days it becomes second nature. You'll wonder why all other keyboards aren't the same.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline TopreFan333
« Reply #21 on: Fri, 18 September 2015, 14:07:58 »
My CTRL and Caps Lock are switched by default on the HHKB. I'm sure it's an advantage for some uses, but for the most part in OS X, the Command key (which sits where the ALT key is in Windows) does the heavy lifting. I could see maybe switching my work keyboard so that it matches and I don't have to keep readjusting -- but I'd still have to deal with the default placement on my Macbook.
Offline ctm
  • Hello, world!
« Reply #22 on: Fri, 18 September 2015, 15:40:27 »
I make the caps lock to be ctrl and totally get rid of caps lock in my keyboard. I hardly ever needs caps lock and caps lock is also dangerous in Vim.
Coming:
Ellipse Model F F62.
Offline AuRinBei
« Reply #23 on: Fri, 18 September 2015, 16:34:09 »
Yes because I'm a civilized adult and not a drooling Neanderthal. I also flip my spacebar, and I have perfect, godlike even, typing posture. Wrists straight and level at all times, like a champ. Don't bother using a wrist wrest because they would never touch it.
Also, you should be hitting Ctrl with pinky regardless of whether it's in its normal place or where capslock usually is.
87u || Poker 2
Offline daerid
    • Rossipedia
« Reply #24 on: Fri, 18 September 2015, 17:46:18 »
Tried it out a long time about when I was learning Vim, never looked back. Just feels natural now. Plus I don't think I've legitimately used CapsLock in years (my boards effectively have 3 control keys)
Offline ideus
  • Björkö.
« Reply #25 on: Fri, 18 September 2015, 17:48:05 »
Switched and flipped.
Offline Macsmasher
« Reply #26 on: Fri, 18 September 2015, 18:24:12 »
Swapping Control and Caps Lock is the best single layout mod you can do. If I could only pick one, that would be it. The second best is swapping Backspace and "\". I came to appreciate this on my HHKB which has a dip switch for it. But I liked it so much, I have an AHK script that swaps them for my other keyboards.
Offline mikes41720
« Reply #27 on: Sat, 19 September 2015, 05:43:24 »
The only thing I have noticed so far that was disadvantageous with the old lay-out is when you have to adjust your whole hand if you want to do Ctrl + A. Now it's much easier since the Ctrl + A are right next to each other. I'm trying it out flipped. But if I don't really notice anything in the change, I'll go back to the regular orientation.
Well, that's something for me to think about doing. Maybe in the future! But I use a lot of the F keys at work though.
I have no experience with anything Mac, but I'm glad it works out for you!
What is Vim? Are those the keyboard layouts? Like Dvorak and Colemak? I might be murdering those names as I totally haven't read about them.
I'll try to hit Ctrl with my Pinky finger. But I'm so used to using my ring finger already. Might be hard to unlearn that.
Caps Lock is useful when you just want to shout at the world.
I like that. Switched and flipped.
I'm liking it so far, but I'm still at that adjustment period. I don't think I'm going to go do the second best mod though.  :thumb:
Offline burn1nsun
    • My stupid YouTube Channel
« Reply #28 on: Sat, 19 September 2015, 06:12:46 »
Yup, but right now I don't have a caps lock key :c
HHKB Pro 2 l Pok3r Gateron Blacks
Offline ideus
  • Björkö.
« Reply #29 on: Sat, 19 September 2015, 13:34:01 »
VIM is a text editor, that has different modes for writing and for navigating, and it uses the home row keys for the arrows.
« Reply #30 on: Sat, 19 September 2015, 14:06:19 »
I don't swap Caps Lock and Left Control. I map Caps Lock as an additional Control key.
Only because of historical reasons. Typewriters had latching Shift Lock mechanisms where the latch latched to a lever next to it. The entire bottom row was occupied by the Space Bar so the space to the left of A was the most convenient spot.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #31 on: Sat, 19 September 2015, 14:58:09 »
I DON'T SWITCH CTRL AND CAPS LOCK ON MY KEYBOARD.
Offline Hypersphere
« Reply #32 on: Sat, 19 September 2015, 15:16:09 »
 Yes. In fact, I remap all my keyboards to something as close as possible to a HHKB/Mac layout. Most of the time, I simply use a HHKB Pro 2.
Offline linuxhermit
« Reply #33 on: Sat, 19 September 2015, 16:19:50 »
I'm a remapper as well I like my control close for vim and emacs
87UW45FC660C EW
Offline ideus
  • Björkö.
« Reply #34 on: Sat, 19 September 2015, 16:48:50 »
Interesting, the good part is that while the keyboard inherited something from mechanical type writers it has its own trades as a modern mechatronics system.
« Reply #35 on: Sun, 20 September 2015, 05:48:38 »
I enjoy my HHKB with Ctrl above the left Shift, and everything else with Ctrl under the left Shift.
Offline mikes41720
« Reply #36 on: Sun, 20 September 2015, 07:33:42 »
No love for Caps Lock. </3
Offline davkol
  •  Post Editing Timeout
Offline ideus
  • Björkö.
« Reply #38 on: Fri, 25 September 2015, 09:14:56 »
All the love is for caps lock, when it invokes control.
Offline Steezus
  • Keeper of Facts
« Reply #39 on: Fri, 25 September 2015, 09:24:40 »
I'm use to the position of LCTRL so I usually just prefer a stepped Caps Lock with a MX Lock switch on there.
Offline blahlicus
    • UniqueK | DIY keyboards, etc
« Reply #40 on: Fri, 25 September 2015, 09:29:59 »
i use vim so the ctrl key isnt used that much with intensive typing sessions, so the ctrl key stays at where it is
Offline MrRooks
  • Always be knolling
« Reply #41 on: Sat, 26 September 2015, 12:44:37 »
I used to have Fn where Caps is but switched to Ctrl recently and I love it. I've also switched it on all of my laptops on the OS level because I like it so much.
Offline ideus
  • Björkö.
« Reply #42 on: Sat, 26 September 2015, 14:38:47 »
I did the same; then, I can use the layout even with my laptop keyboard.
Offline pr0ximity
« Reply #43 on: Sun, 27 September 2015, 06:17:59 »
I map Esc to Caps Lock instead. Use it more than  Ctrl and it's farther away from the home row.
A colleague of mine sets his Caps Lock so that a short press = Esc but holding it down = Ctrl. I always thought that was very clever.
Offline mikes41720
« Reply #44 on: Sun, 27 September 2015, 07:53:57 »
What good timing considering that I'm trying to get into Colemak. My left Caps Lock key is now backspace!
Offline ideus
  • Björkö.
« Reply #45 on: Sun, 27 September 2015, 10:13:41 »
Is there a right caps lock in Colemak?
Offline Macsmasher
« Reply #46 on: Mon, 28 September 2015, 13:32:09 »
When I switched to Colemak two years ago, the only thing I didn't like about the layout was the right AltGr key. So I used Microsoft Keyboard Layout Creator to make a Colemak layout with the AltGr as a standard Alt key.
Offline swimmingbird
  • keyset hoarder
« Reply #47 on: Thu, 01 October 2015, 10:23:42 »
I switched maybe 4 or 5 months ago to using caps lock as control because I wanted to be one of the cool HHKB kids - don't think I'll ever go back to using the default layout
Also just recently changed \| to backspace and oh my god it is awesome
Offline tararais
  • Forum Justice Warrior
« Reply #48 on: Thu, 01 October 2015, 22:20:18 »
I wasn't really a believer in it before I got my HHKB, now I do actually prefer the layout, it's pretty comfortable not having to stretch to the bottom of the keyboard.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #49 on: Thu, 01 October 2015, 22:29:00 »
On Windows Caps Lock is Control and on Mac I map it to command. I'm a space-bar flipper as well, just feels weird using it any other way.
