Author Topic: Do old alps feel 'mushy' compared to newer alps?  (Read 4979 times)
Offline snarfarlarkus
« on: Fri, 18 September 2015, 21:24:41 »
Just bought an old alps from ebay and wondering if that applies
Re: Do old alps feel 'mushy' compared to newer alps?
« Reply #1 on: Fri, 18 September 2015, 21:27:28 »
They won't feel mushy. You will have to be careful about the condition though. Alps are more suspectible to feeling different when dust and other dirty-ness gets into the switch.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Fri, 18 September 2015, 21:32:29 »
No. All should feel clean and crisp. Damped ones might, of course.
« Reply #3 on: Fri, 18 September 2015, 21:35:55 »
Thank you so much guys. Is there a way to clean the inside of the alps switch?
« Reply #4 on: Fri, 18 September 2015, 21:43:30 »
XMIT developed a technique for flushing them out with 90% isopropyl alcohol that he swears by.
I don't remember where he posted it, however.
- D Trump 2026-10-24
« Reply #5 on: Fri, 18 September 2015, 21:46:22 »
Disassemble the switch as shown in the video. Then dunk all the components in isopropyl alcohol. Maybe an ultrasonic cleaner if you have one. If you want to be thorough, desolder the bottom half of the case too and throw those in to clean. Shoutouts to Chyros for the great video.
Offline platypus
  • dongerino adventures
« Reply #6 on: Fri, 18 September 2015, 21:57:03 »
q-tips doused in iso work pretty well too! I like to take a matias click/tactile leaf and swap it into a complicated ALPS switch, pinks/oranges are my favourites :]
« Reply #7 on: Fri, 18 September 2015, 22:06:12 »
Thank you so much for the help everyone! That video is very useful!
Offline njbair
    • nickbair.net
« Reply #8 on: Fri, 18 September 2015, 22:31:54 »
I never realized you can open Alps switches in the plate. I've been meaning to clean the orange Alps in my hasu 60% but I thought I was going to have to desolder them first. I'm glad I stumbled on this!
My boards:
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Fri, 18 September 2015, 23:33:13 »
Glad the video is proving useful :) . Note: some older Alps switches like blues came with lubricant on them; using iPrOH will dissolve this, and that might affect the keyfeel.
« Reply #10 on: Sat, 19 September 2015, 00:23:53 »
Thanks for the heads-up, should I lube them again? Will WD-40 work? Or should I just not wash the components in iPrOH? Cheers
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Sat, 19 September 2015, 03:52:47 »
If XMIT swears by it I'm sure it has merit, I'm just throwing this out because cleaning the sliders off a board that later turned out to be lubed ruined the keyfeel for me once, so I'm not doing it anymore myself. Maybe re-lube them afterwards? Not sure what would make for the best lube though.
« Reply #12 on: Sat, 19 September 2015, 07:52:17 »
Will WD-40 work?
Never use WD40! It is a solvent and bad news for plastic.
Make sure to use Krytox or something formulated to be absolutely plastic-safe in the long-term.
Offline njbair
    • nickbair.net
« Reply #13 on: Sat, 19 September 2015, 08:05:26 »
I'd have to think Krytox would work similarly for Alps as it does for MX.
My boards:
« Reply #14 on: Sat, 19 September 2015, 18:30:34 »
Oh thank you. The only lube I have is WD-40 so I guess I will have to pick up from Krytox. How do I relube alps anyway? Just spray the lube over all the components?
Offline njbair
    • nickbair.net
« Reply #15 on: Sat, 19 September 2015, 18:57:11 »
Krytox is not a spray, but a grease which you apply sparingly at the contact points.
You can buy it from a lot of small enthusiast-run sites, I've gotten mine from TechKeys.us
My boards:
« Reply #16 on: Sat, 19 September 2015, 22:24:05 »
Thanks for the link! I am guessing I use the thick lube for alps switches as it it tactile and the spring lube for the alps springs? Where are the contact points in an alps switch?
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #17 on: Sat, 19 September 2015, 22:37:02 »
I have the strange feeling this person has sliders over domes. Just a feeling.
I wonder what is the make and model number of the keyboard?  I am sure that can help too.
« Last Edit: Sat, 19 September 2015, 22:39:11 by Snowdog993 »
Offline njbair
    • nickbair.net
« Reply #18 on: Sat, 19 September 2015, 22:42:18 »
Nah, he just bought a board but hasn't gotten it yet. Just being paranoid.
I would get the thick lube & spring lube. Then I would actually apply the lube to the metal leaf inside the switch housing, rather than on the slider itself. That's where most of the contact is happening. I'm not an Alps lube expert, though.
My boards:
Offline Snowdog993
« Reply #19 on: Sat, 19 September 2015, 23:07:02 »
That makes sense.  Nevermind.
« Reply #20 on: Sat, 19 September 2015, 23:12:22 »
What is sliders over domes? I bought a Northgate Omnikey 102 with blue alps.
Offline sean
  • Mechanical newb
« Reply #21 on: Sun, 20 September 2015, 00:31:39 »
Me too! I just won the auction today :>
I think I'm going to have to do a full iso bath for all the switches since there are a few sticky keys, so I'll need to know exactly how to reapply the lube. If anyone has some actual information on that I'd appreciate it. Then they're going right on Hasu's Alps64 like they belong!
« Reply #22 on: Sun, 20 September 2015, 01:09:47 »
Nice!!! How much did yours go for if I may ask? Mine seemed to be in above average overall condition but just with a lot of dust and debris under the keycaps. How do you put them onto Hasu's 60% PCB?
Offline Magna224
« Reply #23 on: Sun, 20 September 2015, 04:34:41 »
The majority of bad alps I have felt was due to grittyness or sticking. Never felt 'mushy' ALPS.
« Reply #24 on: Sun, 20 September 2015, 06:02:46 »
How did you fix the sticking or grittyness?
Offline sean
  • Mechanical newb
« Reply #25 on: Sun, 20 September 2015, 10:51:40 »
Grittyness and sticking would definitely be from crap getting into the switch. An isopropyl alcohol wash should fix that like the guys were talking about before.
Offline chyros
  • a.k.a. Thomas
« Reply #26 on: Mon, 21 September 2015, 07:06:52 »
Neither am I, but I can definitely say with certainty it's not just the teeth on the leaf springs that are the biggest contact points, but the sides of the slider (where it is retained by the housing). Lubing that would be a first, I'd say, after that, the teeth on the tactile/clicky leaf, and finally the teeth on the contact leaf.
Offline njbair
    • nickbair.net
« Reply #27 on: Mon, 21 September 2015, 07:11:30 »
Seems like that could get messy real fast, and attract dust since that part of the slider is exposed above the switch housing.
Maybe some kind of dry live would be better here?
My boards:
Offline chyros
  • a.k.a. Thomas
« Reply #28 on: Mon, 21 September 2015, 07:59:27 »
No not that bit, the sides of the slider where it's at its broadest. There is a track in the inside of the housing that guides the slider along it.
Alps factory lube appears to be smeared all over the slider though, including the bit you are talking about.
