Poll
What should happen with the payment discrepancy?
Refund money to participants
9 (25%)
Send participants extra switches
8 (22.2%)
Send participants silly things and donate money
19 (52.8%)
Total Members Voted: 36
Voting closed: Mon, 26 October 2015, 15:35:50
Author Topic: [GB] Alps Party 60% - Hannibal at the Gates  (Read 605136 times)
Offline swimmingbird
  • keyset hoarder
Re: [GB] Alps Party 60% - Hannibal at the Gates
« Reply #150 on: Tue, 29 September 2015, 10:50:18 »
+1 to Punic War references
Offline trees
  • I like bagels.
« Reply #151 on: Tue, 29 September 2015, 11:01:31 »
In for this and Alpine Winter as my first ever GB  ;D
B.Face HHKB - B.mini - Black/Purple Custom
Offline sean
  • Mechanical newb
« Reply #152 on: Tue, 29 September 2015, 11:06:30 »
Should I use any method to my madness with regards to selecting which switches to harvest from my AEK?  Just do the 60%? pick ones that probably have less use? Should I keep the locking switch somewhere?
To much time to wait without thinking and planning things if you know what I mean  :eek:
TMK supports locking switch if you want to use it
Offline tominabox1
« Reply #153 on: Tue, 29 September 2015, 11:08:43 »
I know, I have adb-usb on a teensy right now but I'm thinking about moving the switch to a layer toggle maybe instead.  Just curious if anybody else has ideas for that.
Offline cheddarbek
« Reply #154 on: Tue, 29 September 2015, 11:52:39 »
I kept my lock switch on caps lock, and I use another on RGUI as a function switch.
The Alps cover 65% of Switzerland's surface area (41,285 km²), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 km²),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline tofgerl
« Reply #155 on: Tue, 29 September 2015, 12:58:17 »
There are locking Alps switches?
Offline tominabox1
Offline tofgerl
« Reply #157 on: Tue, 29 September 2015, 13:04:30 »
... I want it...
Offline cheddarbek
« Reply #158 on: Tue, 29 September 2015, 15:15:26 »
... I want it...
They're glorious. Locking switches, whether Alps or Cherry ought to be more common.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #159 on: Tue, 29 September 2015, 20:58:57 »
Just trying to decided between Quiet Click and Clicky and whether or not to jump in for the anodizing. I think it would look pretty slick on the HHKB plate!
Offline njbair
    • nickbair.net
« Reply #160 on: Tue, 29 September 2015, 21:02:36 »
I ordered clicks for one of mine and quiets for the other. I already have an Infinity with quiets and I love them. I'm sure the clicks will be great, and I don't think you'll have any regrets one way or the other.
My boards:
« Reply #161 on: Tue, 29 September 2015, 21:14:13 »
So what I think you are saying is "why not both?"... classic wallethack  ;D
Offline njbair
    • nickbair.net
« Reply #162 on: Tue, 29 September 2015, 21:19:29 »
Well it would have made sense to order all the same, since they come by the 10's and each board has just over 60 keys. But I want to try Matias Clicks, but not enough to risk two boards' worth. So I'll stick with Quiets for one, which I know I like, and take the plunge for the other board.
As to why I ordered two of these boards when I already have two Alps 60%'s that's just wallethack.
My boards:
« Reply #163 on: Tue, 29 September 2015, 21:25:56 »
Seeing as 70 switches are going to cos me about the same as a case of beer I might end up getting a set of both. The only Alps I can remember trying in real life was a Dell with Black Alps and I wasn't really blown away, so I guess I'm just trying to hedge my bets a bit.
Offline njbair
    • nickbair.net
« Reply #164 on: Tue, 29 September 2015, 21:33:13 »
Black Alps are the worst. That's not even really an opinion. I've seen people recommend buying a Dell AT101 with Black Alps just for the chassis, then getting another Alps board to harvest the switches from (AEKII, IIGS, etc). They're throwaway switches, really. No comparison to Orange/Salmon Alps or Matias.
My boards:
Offline sean
  • Mechanical newb
« Reply #165 on: Tue, 29 September 2015, 22:15:58 »
I'm kinda curious about this too now, has anybody used a locking switch as a function layer, or something even crazier?
Offline Yoe
  • Alps & ISO <3
« Reply #166 on: Wed, 30 September 2015, 03:54:38 »
Hmm... guys.. is there more than one version of the AT102W? I replicated the alpha part of the plate in my AT102W in CAD and it ended up like this:
112269-0
And this is what the plate in the OP looks like:
Difference is the stepped caps lock... thoughts on this?
Edit: Oh, never mind! I just read through the entire thread and realised it had been discussed before.
« Last Edit: Wed, 30 September 2015, 06:18:02 by Yoe »
Offline E3E
« Reply #167 on: Wed, 30 September 2015, 04:13:45 »
I bought a bunch of MX locks thinking I'd use them for precisely this and have only ended up using two for boards that dd not have toggle functions built into the firmware. On my Infinity, I considered using the Alps latching switch from my AEK but felt that letting the firmware handle it was a better choice. The only drawback I can see is forgetting if you've toggled a layer or not, which a latching switch would easily be able to display.
Offline tofgerl
« Reply #168 on: Wed, 30 September 2015, 05:33:21 »
I am planning to use my keyboard in two modes. Each mode would have different layers,  so like layer 1,2 and 3 for work and 4,2 and 5 for gaming for example. Instead of using multiple key combos, a locking switch would select mode, and buttons would select layers.
« Reply #169 on: Wed, 30 September 2015, 08:27:15 »
I know you edited your post already, but honestly, I wasn't looking at a real life example when I designed that plate. I wasn't aware that the Dells had a stepped caps lock position. Depending on which caps people are planning on using for their builds, I can change it easily to the stepped version.
@njbair, what is Alpine Winter doing for a Caps Lock key...stepped or centered? Do you know offhand which Badwrench's mods included?
Offline njbair
    • nickbair.net
« Reply #170 on: Wed, 30 September 2015, 08:28:44 »
On-center in both cases. And FWIW, the Tai Hao sets on Massdrop are also on center.
My boards:
« Reply #171 on: Wed, 30 September 2015, 08:32:15 »
Thanks for the quick response! I suppose we should keep the centered position then, for compatibility with current and future GB sets. This would really only hurt anyone who is planning on salvaging keycaps from a vintage AT101(W).
I know i3oilermaker had SP make molds for center-stemmed, stepped caps lock keys for MX, and I'm pretty sure they can swap in an Alps mount stem if requested...
« Reply #172 on: Wed, 30 September 2015, 08:37:22 »
You've apparently never tried good condition Black Alps. They're actually not bad. They're not my favorite but I like them better than White Alps. Seems like Black Alps are the most susceptible to dust, grime, wear, etc. I've found that their feeling really varies between even switch to switch.
Yes. I have a Alps Cream Lock Switch on the function layer button for my Siig Minitouch. I find lock keys as a toggle on function layers makes a lot of sense.
« Last Edit: Wed, 30 September 2015, 08:44:25 by CPTBadAss »
Offline njbair
    • nickbair.net
« Reply #173 on: Wed, 30 September 2015, 08:42:58 »
This would be the best solution.
Maybe at the end of the buy, BlueNalgene can track down everyone who ordered the affected plate, and ask them whether they want on-center or stepped. In fact, he may have already mentioned this...
My boards:
Offline Yoe
  • Alps & ISO <3
« Reply #174 on: Wed, 30 September 2015, 10:23:52 »
I see. The are both relevant as options then. Just got a bit confusing :)
Also, though the ISO AEKII may not be of interest to anyone as it won't work with Hasu's PCB, the plate design should perhaps be verified. The ISO AEKII layout is tweaked to the right making the enter key a bit narrower, and it looks like this:
http://www.keyboard-layout-editor.com/#/gists/3aff9552b4b657d7e216
http://www.finestcomputers.co.uk/FinC/Apple/hardware/ExtendedKeyboard-II/No.3/EK2-1.JPG
A quick glance at the plate in the op, and it seems a bit off compared to that. Actually, putting the ISO AEKII from above into Swill's KB with Poker hole option on puts the holes half-way into some switches…
Offline cheddarbek
« Reply #175 on: Wed, 30 September 2015, 10:38:21 »
I run a lock switch as function on my 60% alps with hasu's PCB.
TMK doesn't explicitly support locking switches as function (but it does support locking caps and such) - the key with a lock switch is that if the firmware isn't set up to support it, what the board will see is a press and release when first locked, then another press and release when unlocked.
I just modified fn in TMK to act as a toggle I believe. I'd have to go back and look at the file to see exactly how I implemented it.
Offline BlueNalgene
« Reply #176 on: Wed, 30 September 2015, 10:46:57 »
I think I sent you a PM about this at the time when it was originally noticed.
I already have the Alps plates with the stepped caps lock key modification made.  I put them together when people originally brought up this issue.  I'll send you the files by email when I find a free moment.
Yes, that is the plan.  To reiterate here, I will send a small question along with the invoice to every participant who ordered a Dell plate asking which version they want.  I will make it clear in the email that I am asking what caps source they will use, since some newer users aren't aware they are about to run into an issue.  The order will be made after this info with the invoice is returned.  I chose to do it this way to prevent further complicating the order form.  I want it nice and simple.
Offline VinnyCordeiro
« Reply #177 on: Wed, 30 September 2015, 13:11:09 »
I wish the deadline were 1 week later, so I would be able to join the GB. :(
Well, you can't always get what you want, as someone wiser already said.
« Reply #178 on: Wed, 30 September 2015, 13:31:38 »
I can't speak for anyone, of course, but you might PM BlueNalgene and ask if he might be able to extend it for you for a few days. Some organizers are able to do that once in a while in certain circumstances. That is the advantage of having a community-organized group buy.
Offline braidn
« Reply #179 on: Wed, 30 September 2015, 17:18:25 »
Speaking of extending this, does anyone have a timetable on the shipping of plates/pcbs?
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #180 on: Wed, 30 September 2015, 17:41:05 »
Will these stabs work? From an Apple M0116
Offline tominabox1
« Reply #181 on: Wed, 30 September 2015, 17:44:20 »
I believe so.
Offline BlueNalgene
« Reply #182 on: Wed, 30 September 2015, 17:45:23 »
Things ship when I get everything.
I expect most everything will be quick except for the PCB, since hasu will be hand-soldering them all, and they have to ship from Japan.
Offline digi
  • elite af tbh
« Reply #183 on: Wed, 30 September 2015, 18:23:51 »
nothing like de-soldering some 30 year old switchies
« Reply #184 on: Wed, 30 September 2015, 18:35:32 »
I'm literally the opposite of digi. Just joined the buy for those delicious Matias Quiets. One day I'll be as cool as him.
Offline njbair
    • nickbair.net
« Reply #185 on: Wed, 30 September 2015, 18:36:21 »
Opposite of Digi... So you're not a 49ers fan?
My boards:
Offline digi
  • elite af tbh
« Reply #186 on: Wed, 30 September 2015, 18:46:24 »
Matias MUSH Quiets?!?!
Fired!! Wait, you're doing that Alpine Alps GB, nevermind...re-hired!
« Last Edit: Wed, 30 September 2015, 19:08:26 by digi »
Offline digi
  • elite af tbh
« Reply #187 on: Wed, 30 September 2015, 19:02:40 »
I believe so.
I'm definitely going to need a longer space bar stab wire, hopefully the rest of em will work..
« Last Edit: Wed, 30 September 2015, 19:09:03 by digi »
Offline Yoe
  • Alps & ISO <3
« Reply #188 on: Thu, 01 October 2015, 02:04:28 »
I believe so.
Stab wires are no biggie to make from piano wire if the ones you've got are the wrong size. What's harder to come by is the plastic thingamajigs.. especially the cylindrical ones for space bar (and sometimes enter.) You often need two of those, and depending on donor kb you may only get just one.
Offline Våtdräktsman
« Reply #189 on: Thu, 01 October 2015, 03:11:32 »
https://www.massdrop.com/buy/tex-metal-case
Anyone wanna join? Just need three more people to reach MOQ.
Also note the issue with some diode shorting on this particular case.
  • keyset hoarder
« Reply #190 on: Thu, 01 October 2015, 07:14:16 »
Was thinking about joining but I'll leave it to the last day
Offline BlueNalgene
« Reply #191 on: Thu, 01 October 2015, 13:59:03 »
All you need is a little dielectric to separate the metals.  Electrical tape will work fine.  If you want to make it look cleaner, you could try vinyl wrapping that you can get for cars.
« Reply #192 on: Thu, 01 October 2015, 14:00:14 »
See? Still the opposite. I was pleasant and paid you a compliment. You're just rude.
Offline digi
  • elite af tbh
« Reply #193 on: Thu, 01 October 2015, 14:01:20 »
You're right, I went too far...Send me your Kingsaver with Blues and we can be friends again...
I won't be nasty like Hoff anymore. Sorry.
« Reply #194 on: Thu, 01 October 2015, 14:09:18 »
Yeah I've checked around on how to prevent it, not a big deal.
Offline BlueNalgene
« Reply #195 on: Thu, 01 October 2015, 19:47:12 »
Updated OP
If you haven't filled it out already, I have a form for an IC on Matias Stabilizers.  Please indicate interest using the simple form.
Offline braidn
« Reply #196 on: Thu, 01 October 2015, 22:34:04 »
I know it was a little up in the air but, have we confirmed that the plates will work with Costar inserts?
Offline stoic-lemon
« Reply #197 on: Thu, 01 October 2015, 22:59:52 »
What constitutes a set of stabs in this case? Enough for a 60% keyboard?
« Reply #198 on: Thu, 01 October 2015, 23:24:24 »
The Costar inserts that snap into the plate? No, the plate will definitely NOT work with those.
Offline BlueNalgene
« Reply #199 on: Fri, 02 October 2015, 00:45:58 »
That sort of depends on what layout you are doing.  E.g. the sets won't have one for an Infinity spacebar.
The sets are what Matias defines as a set.
Would you like to know more?
