Author Topic: [GB] Alpine Winter (Shipping Replacements)  (Read 2826573 times)
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [GB] Alpine Winter (Shipping Replacements)
« Reply #1200 on: Tue, 08 May 2018, 14:47:04 »
Does anyone have a few R4 blanks in blue they could spare?
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline kinglukas38
  • Do you even tactile?
« Reply #1201 on: Wed, 09 May 2018, 00:38:57 »
if you don't have any luck here you could try sending SP an email. I know they carry blank keys in packs of 10, but it looks like they don't have blue r4 in alps listed.
I've never done it before, but I'm pretty sure I'm good at it
« Reply #1202 on: Tue, 02 October 2018, 14:38:17 »
If anyone happens to be interested, I am running an interested check right now for a 65% Alpine Winter add-on kit with arrow keys.
https://geekhack.org/index.php?topic=97570.msg2665323#msg2665323
Offline bit-shifter
« Reply #1203 on: Sat, 20 February 2021, 08:32:38 »
Wishful thinking after all this time, but if you don't ask...
Hoping that someone has an MX mount ISO enter key that they've never found a use for?
This key was sent with either the original kit, or as a replacement - can't recall.
I've a build that's near complete, with the exception of this MX ISO enter.
It's needed as the PCB/plate has the enter switch rotated 90º, so it's using a slider to provide the MX stem - and patiently waiting for a cap to cover it.
I'm located in the UK, and would be very grateful if anyone could oblige.
All the best!
Offline U47
« Reply #1204 on: Tue, 02 March 2021, 15:51:36 »
All the best!
Is this the one you're looking for?
« Last Edit: Tue, 02 March 2021, 15:53:33 by U47 »
Offline bit-shifter
« Reply #1205 on: Wed, 03 March 2021, 13:12:41 »
It certainly is! Would you be willing to let it go?
All the very best!
All the best!
Offline U47
« Reply #1206 on: Tue, 09 March 2021, 13:22:56 »
PM'd.
All the very best!
« Last Edit: Tue, 09 March 2021, 13:24:31 by U47 »
Offline U47
« Reply #1207 on: Fri, 09 July 2021, 16:55:41 »
Had someone else reach out, so in case anyone else is missing something or needs a replacement from this buy, let me know. I have lots and lots sadly unused.
Offline aznairjordan
« Reply #1208 on: Tue, 09 November 2021, 23:24:28 »
Hi! I’m looking for a replacement Alt cap, I think it’s the 1.5u one. Do you happen to have any of those?
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline U47
« Reply #1209 on: Fri, 21 January 2022, 15:54:19 »
I've got both the 1.25u and 1.5u.
281396-0
