Author Topic: first time using the model m what was it like  (Read 2970 times)
Offline ANightOnCloudNine
« on: Sat, 26 September 2015, 23:42:46 »
for me it sounded like
Re: first time using the model m what was it like
« Reply #1 on: Sun, 27 September 2015, 04:00:52 »
The first time was probably years ago and I have forgotten.
The first time recently felt like I was coming back home to keyboards again, it was everything that MX blue and green was trying to be.
« Reply #2 on: Sun, 27 September 2015, 04:10:43 »
Heh, I only used the keyboard once and it was like 3 years ago.
« Reply #3 on: Sun, 27 September 2015, 04:18:11 »
I have four of them here, I should use them more but I'm breaking in this CODE keyboard before I take it in to work.
I was using an SSK at work until someone complained quite bitterly about it.
« Reply #4 on: Sun, 27 September 2015, 04:22:33 »
Lol, do you know any good deals on where to get a model m? even if it's a low quality modern one, i could mod it.
« Reply #5 on: Sun, 27 September 2015, 05:22:28 »
The only source I know sold her business and retired (AFAIK).
You can have a look through classifieds, or maybe even eBay (two of mine came from eBay).
Offline njbair
    • nickbair.net
« Reply #6 on: Sun, 27 September 2015, 07:10:54 »
If you are willing to mod it, it's worth waiting for a good deal. Set up an eBay saved search for "IBM model m" or similar, and wait until you find one at the price you want to spend. I got mine for $40, but that seems to be on the low side for eBay.
If you can find a nearby computer recycling center, that might be a good place to look as well. If you can pick it up locally you'll save on shipping.
My boards:
Offline raymogi
« Reply #7 on: Sun, 27 September 2015, 07:13:29 »
My SSK should be arriving any minute now. Have mixed feelings on how it's going to feel like to type on it after typing on my buttery smooth 55g Topre.
I LOVE the sound it makes though.
Please feed my addiction.
« Reply #8 on: Sun, 27 September 2015, 08:22:37 »
Thanks, I'm gonna head to a bunch of thrift shops then and look for the keyboards. Wish me luck.
« Reply #9 on: Sun, 27 September 2015, 10:12:25 »
You will be supremely lucky if you find a Model M in a thrift shop.
I recommend buying a new Unicomp. While most people agree that quality control has slipped since the Reagan era, a Unicomp is a real true Model M built on the same equipment in the same factory as the vintage ones.
Plus, you can get colors, more compact layout, native USB, Windows keys, and - a warranty.
See how you like that before you move into vintage stuff.
- Oliver Willis 2026-08-01
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #10 on: Sun, 27 September 2015, 10:22:21 »
I agree with you here fohat.  Another thing is you can get the 103-key model with the Win/Menu keys as well.  Kinda nice to have if you need them.  I'd just recommend the Classic (not Ultra-Classic) so you know what you're getting yourself into as well.
« Reply #11 on: Sun, 27 September 2015, 10:58:59 »
See I would but a lot of people complain about the quality control like the plastic not being molded as good as the original or keys being crooked and stuff, plus I'm a gamer too so a PS/2 connector allows full n key rollover which is dear to my heart.
« Reply #12 on: Sun, 27 September 2015, 11:04:23 »
The QC issues are real but minor. I would not even blink at that particular issue, unless I was seriously into it.
Forget using a Model M for gaming if you need more than 2KRO.
Get a Model F for NKRO.
« Reply #13 on: Sun, 27 September 2015, 11:12:20 »
Hmmmm, looking at stuff about the model f makes me like it, they're both great keyboards.
Offline Snowdog993
« Reply #14 on: Sun, 27 September 2015, 11:12:29 »
Forget about N key rollover with a Model M keyboard.  It is just 2 key rollover.  That is just gamer hype to be honest.  You will understand once you start using a Model M.  Another thing, I did post a picture of my Unicomp PS/2 Model M.  You can zoom to full resolution with it and see the key characters for yourself.  It's not bad and the keyboard can be had for under $100.
This is an excellent deal for a buckling spring keyboard.
« Reply #15 on: Sun, 27 September 2015, 11:25:55 »
are there any ansi versions of the model f?
