Author Topic: [IC] GREEN SCREEN SA Keycaps == Your Computer in the 1980s  (Read 189861 times)
Offline Oobly
Re: [IC] GREEN SCREEN SA Keycaps == Your Computer in the 1980s
« Reply #150 on: Mon, 19 October 2015, 07:20:48 »
Its also probably wise for all designers to start taking HHKB/660c boards into consideration as well with the MX Compatible sliders right around the corner. Could add them to the non-standard adapter kit.
I know this is totally off topic but do you know if there are SA spacebars in 6u that would fit the HHKB/Topre boards with the replacement sliders?
DCS has a 6x size spacebar possible, but I don't know about the stem positions. For the other profiles:
If I had a HHKB with MX sliders, I'd probably use a standard 6.25x spacebar and 1.25x caps on the mods next to it. Leaves small gaps to the 1x keys, but should fit at least. If you grind the case you can fit 1.25x caps on the outside caps, too. No gaps and standard caps will fit.
The FC660C can be done with 1x, 1.5x, 1x, 6.25x, 1x, 1.5x, 1x. Leaves a small gap on the outside ends of the row, but no gaps between caps.
Realforce can use: 1.25x, 1.25x, 1.25x, 6.25x, 1.25x, 1x, 1x, 1.5x. Leaves a gap at the left end and between the right hand 1.25x and 1x.. Could use 1.5x, 1x, 1.25 on the left side to make the gaps consistent instead if you prefer.
So all three boards can be "supported" with standard base and Winkeyless kits, assuming the stems are in the right places. Only other options are:
1. get SP to make a 6x spacebar for the other profiles.
2. use stock spacebar on stock slider.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Oobly
« Reply #151 on: Mon, 19 October 2015, 07:51:30 »
Here you can see the "D" and "K" homing keys clearly:
Offline Vellicle
« Reply #152 on: Tue, 20 October 2015, 06:48:43 »
Gorgeous set ensconced in that OP.
Offline Oobly
« Reply #153 on: Tue, 20 October 2015, 07:00:44 »
I like the GNU reference in the DNA kit :)
Offline tofgerl
« Reply #154 on: Tue, 20 October 2015, 08:15:56 »
And I appreciate the effort put in to displaying the kits in the correct keyboard position on the images. Makes it SO much easier to take in, not just at a glance, but when actually checking which kits you need.
Offline tangkims
« Reply #155 on: Tue, 20 October 2015, 09:46:08 »
I'd definitely buy v1.2. Count me in for base + amber screen!
Offline derezzed
« Reply #156 on: Thu, 22 October 2015, 20:38:48 »
Updated original post with an "Amber Screen" Kit, per derezzed's idea. Thanks again, derezzed!
I did nothing more than a simple color swap on your already excellent design.  But, if I can make another suggestion, the legend on the floppy key should be 1:1 scale.
Recursion makes DNA tied with Danger Zone for the best name for a keycap set.
Offline Oobly
« Reply #157 on: Fri, 23 October 2015, 02:16:19 »
... the legend on the floppy key should be 1:1 scale.
I don't think SP has molds for 51/4" caps...  :p
Offline Jhonan
  • Chicks love duck pics...
« Reply #158 on: Sat, 24 October 2015, 16:12:22 »
Those renders look pretty awesome, now the decision of green or amber....
Offline njbair
    • nickbair.net
« Reply #159 on: Sat, 24 October 2015, 16:29:45 »
Danger Zone also had awesome child pack names.
My boards:
Offline MikeTheTiger
« Reply #160 on: Sat, 24 October 2015, 19:22:06 »
Why choose? I'm down for both colors.
"all the numbers or none of them cmon man" -Kokaloo
Offline Jhonan
« Reply #161 on: Sat, 24 October 2015, 19:43:37 »
I might just end up doing that... maybe mix em a bit
because I'm a monster...
Offline njbair
    • nickbair.net
« Reply #162 on: Sat, 24 October 2015, 19:50:55 »
With the orange and green being so different, this buy might be better served by offering the mods and alphas as separate packs.
My boards:
Offline profet
« Reply #163 on: Sat, 24 October 2015, 20:05:17 »
Ergodox kit?
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
« Reply #164 on: Sun, 25 October 2015, 00:41:40 »
Sounds like a plan!
That's what I was thinking. That way you buy what you need/want.
Offline HesterDW
« Reply #165 on: Sun, 25 October 2015, 01:42:20 »
Sounds like a plan!
So kinda like Elemento PBT. The base kit could be the beige mods, then you choose your alphas. But how might having two alpha colors complicate the numpad/alt layouts? Would there be amber versions of every layout?
« Reply #166 on: Sun, 25 October 2015, 02:40:49 »
Sounds like a plan!
I guess this thinking would lead to a ton of child packs...and potentially over complicate things.
Offline Jhonan
« Reply #167 on: Sun, 25 October 2015, 04:50:00 »
Sounds like a plan!
Then the added worry of not meeting the minimum order for price... (unless I'm not understanding the whole gb thing :P)
Offline DrCr4nK
  • Yeah, man. I dig that.
« Reply #168 on: Sun, 25 October 2015, 08:11:45 »
These look so nice.  Green and black kill color combo gets me every time.  :D
Offline Pdub
« Reply #169 on: Sun, 25 October 2015, 12:52:55 »
If you came up with some awesome novelty keys I would buy this. Maybe some keys that have error message words on it. or some keys that say "blue screen" or "green screen" for the esc key. I think my forvorite nov keys are ones with cleaver words for specific keys. Like "Destroy" for delete or "super" for Windows key.
You can figure this out. Good Luck!  :thumb:
« Reply #170 on: Sun, 25 October 2015, 14:06:45 »
I think the novelties so far fit the aesthetics of the set. Maybe a few more to add some variety.
Offline braidn
« Reply #171 on: Sun, 25 October 2015, 22:26:54 »
Love the color way and Workman support. Wish more deals would try and add this newish layout. Definitely in for enough to cover an ErgoDox and Planck
Offline Kola93
« Reply #172 on: Mon, 26 October 2015, 02:38:28 »
I really like both the Green and Orange.
Will I like SA profile? It seems ridiculously tall.
Offline Kirfloof
« Reply #173 on: Mon, 26 October 2015, 11:08:18 »
I rather like SA's, but I've yet to try a full contoured board with them. I also type with wrists above the board, so the extra height has never been an issue much.
I don't have a board for this set, but I can't see a good reason not to jump in for a v1.2, it's the only dark alpha/ light mod theme I've liked.
Not a fan of 'distracting' mods, but this one really works well for me.
Offline Steezus
  • Keeper of Facts
« Reply #174 on: Mon, 26 October 2015, 11:16:04 »
Nobody will be able to tell you if you'll like SA or not, it's all personal preference. People will be able to give you some insight on their opinion but you won't really know until you try it for yourself.
Offline jerue
  • (Whenever that happens :P)
« Reply #175 on: Mon, 26 October 2015, 16:41:22 »
It works really well on the right switches. I would recommend heavy/linears, ergo clears/zealios or Topre (Novatouch). Did not like my Modern Selectric set on my MX Green board, which is a shame because it replicated a typewriter so well. They are a little wobbly, but to me that is a retro feel because my Selectric I typewriter is also wobbly.
Offline gabba-gool
« Reply #176 on: Mon, 26 October 2015, 17:09:27 »
Definitely into version 1.2 green screen.
Offline jaffers
« Reply #177 on: Wed, 28 October 2015, 06:11:56 »
This looks sick
Offline tangkims
« Reply #178 on: Thu, 29 October 2015, 00:56:20 »
I hope this set comes after some SA sets i won't be buying so I won't feel so guilty spending so much money so soon lol
Offline heedpantsnow
  • Old enough to know better
« Reply #179 on: Fri, 30 October 2015, 22:58:23 »
Aw man I really dislike SA but this keyset is looking so awesome.
I'm back.
Offline mrgoldenzombie
  • Topre is cool I guess....
« Reply #180 on: Sat, 31 October 2015, 00:34:56 »
Overview
Hi Everyone, I'm designing keycaps inspired by the first computer I owned, a hand-me-down Apple IIe. It was old by the time I got it, but it started me off well enough. Assuming you were old enough to type in the late 80s, you probably used an Apple II at some point, or at least a computer with a green phosphor CRT.
My original idea was to do alternating light/dark green rows in alphas and mods. After some good feedback over on /r/keycapdesigners/ I moved that concept out to a child kit to make the base kit appealing to the biggest audience am probably going to nix that idea.
I think that there's potential for some really great novelty keys in a set like this, but I need your input and ideas!
Images
Version 1.2 (Updated 2015-10-15)
Version 1.1 (Posted 2015-09-27)
Imgur Album: Green Screen Keycaps Set
Inspiration
This.
And these.
"Green Screen" Details
  • Signature Plastics ABS SA keys
  • MX compatible stems
  • Profile Rows 1-1-2-3-4-4
  • Doubleshot legends
  • Semi-Matte Finish (Standard)
Kits
  • Base Kit
  • Numpad Kit
  • Not ANSI Kit
  • Alt Layouts Kit
  • ISO 9995 (UK) Kit
  • Amber Screen Alphas Kit
  • German/Nordic/S.Slavic Kit (?)
  • Novelties (?)
Group Buy Plans
I won't be presumptuous. I'll update this if there's enough interest.
I will mention that as a new member of the community, I don't intend to run a group buy myself nor collect any money; we'll go through PMK store or Massdrop if there's enough interest.
Work Log
Incorporate feedback on colorway from harlw, data, others.
Numpad Kit v1.2
Alt Layouts Kit v1.2
ISO 9995 Kit v1.2
"Amber Screen" Alphas Kit
Images for terminal novelty
Not ANSI Kit v1.2
Thanks everyone!
Looks dandy... Take my monies
O-Ringed Black RealForce 87u  | O-Ringed Novatouch with Miami PBT
Offline hnaeht
« Reply #181 on: Sat, 31 October 2015, 11:29:49 »
Amber screen kittttt? no wayyy :eek: it's like GMK Orange or Ski data, but I think the color will be brighter. It looks awesome.  take my moneyy plsss
« Last Edit: Sat, 31 October 2015, 11:57:15 by hnaeht »
Offline braidn
« Reply #182 on: Sat, 31 October 2015, 11:57:14 »
I honestly think people just like more plastic which equates to so many folks liking SA sets. Honestly, this in PBT DCS/DSA would be awesome and IMHO just as novel as SA or even a complete R3 SA
Offline Steezus
  • Keeper of Facts
« Reply #183 on: Sat, 31 October 2015, 16:32:00 »
Just a heads up, try to avoid quoting long posts so it doesn't fill up the thread. :thumb:
I'm very excited for this set still, looks like I'll need to buy another board so this set can have a home. :D
Offline CannabisWeekly
    • Tech Nerd / Cannabis Weekly
« Reply #184 on: Mon, 02 November 2015, 23:27:23 »
This set really needs to happen. Most unique set i have seen yet!
Offline keyboardia1
« Reply #185 on: Tue, 03 November 2015, 01:41:52 »
i know that feel
Offline hitlu
  • [LF] Ogres and Colonel
« Reply #186 on: Tue, 03 November 2015, 05:27:19 »
 :)i like all green set。。。
Colonel or Ogre
Offline braidn
« Reply #187 on: Tue, 03 November 2015, 07:06:25 »
Even though the world is flooded with SA at the moment there is no way I will be missing this
« Reply #188 on: Tue, 03 November 2015, 07:26:07 »
There can never be enough SA options!
Offline Dernubenfrieken
« Reply #189 on: Tue, 03 November 2015, 07:32:48 »
Until we end up having to wait 2 years for a keyset to be made.
Offline Data
« Reply #190 on: Tue, 03 November 2015, 11:44:45 »
Hopefully a competitor will appear before we get to that point.
Offline jaffers
« Reply #191 on: Tue, 03 November 2015, 13:20:41 »
I would be very interested in grabbing a set of this
Offline chromatically
« Reply #192 on: Tue, 03 November 2015, 13:41:37 »
Overview
Images
Inspiration
This.
And these.
Kits
  • Base Kit
  • Numpad Kit
  • Not ANSI Kit
  • Alt Layouts Kit
  • ISO 9995 (UK) Kit
  • Novelties (?)
Group Buy Plans
Work Log
Numpad Kit v1.2
ISO 9995 Kit v1.2
Not ANSI Kit v1.2
Thanks everyone!
oooo definitely interested in this set. more SA the better.
Offline Steezus
  • Keeper of Facts
« Reply #193 on: Tue, 03 November 2015, 16:30:14 »
Please refrain from quoting the main post, it clutters up the thread's pages.
Have there been any updates recently tho the set or are we just waiting in line for SP?
Offline xorian
  • A nondescript lurker
« Reply #194 on: Thu, 05 November 2015, 09:46:53 »
I really like the colors on 1.2, and I'd definitely be interested in buying a set.
It would be really great to have an ErgoDox kit and a Planck kit.  For the novelties, I'd prefer "Terminal B" and/or the floppy disk.
Offline My_Thoughts
« Reply #195 on: Fri, 06 November 2015, 05:51:43 »
With the size of some of the SP drops on massdrop I fear to think how long the queue might be now
« Reply #196 on: Fri, 06 November 2015, 06:45:43 »
And it seems like almost every new GB decides on SA at this point, or at least has it as a main option. Dasher/Dancer, Green Screen, Troubled minds, Nantucket Selectric, Ground Control, Mint Chocolate, Earfbound, Rebel, Yuri, etc.
Offline Oobly
« Reply #197 on: Fri, 06 November 2015, 07:06:38 »
I blame Elrick... ;)
They've all just finally realised how awesome SA is. It's thick and solid, high quality and chunky, with lots and lots of options available. All the other SP profiles are too thin, all the other manufacturers don't offer enough options (colours, materials, finishes, legend types, custom legends, etc). Now that we have Row 4 Shifts the only thing it's missing is more font options... hoping to fix that soon  ;D
Offline zabuza1997
« Reply #198 on: Sun, 08 November 2015, 07:00:59 »
Bump! When will this horse be ready for market???
Offline tangkims
« Reply #199 on: Mon, 16 November 2015, 14:19:54 »
hopefully it's right after troubled minds.
