Author Topic: WTS Apple Extended Keyboard 2 - $25 - both sold  (Read 3801 times)
Offline cmadrid
  • Trade Count: (0)
« on: Mon, 28 September 2015, 10:34:38 »
Looking to sell two AEK2s for $25 plus shipping each.
« Last Edit: Mon, 28 September 2015, 19:00:40 by cmadrid »
Offline Lurch
  • Trade Count: (0)
Re: WTS Apple Extended Keyboard 2 - $25
« Reply #1 on: Mon, 28 September 2015, 12:54:42 »
What switches?
Quote from: Flyersfan1
Offline tjweir
  • Trade Count: (0)
« Reply #2 on: Mon, 28 September 2015, 13:33:59 »
Tested and working?
Offline cmadrid
  • Trade Count: (0)
« Reply #3 on: Mon, 28 September 2015, 13:36:03 »
What switches?
Didn't know there were different kinds.. lol
Will post some pictures of the switches in a few minutes
Offline cmadrid
  • Trade Count: (0)
« Reply #4 on: Mon, 28 September 2015, 13:39:11 »
Offline Lurch
  • Trade Count: (0)
« Reply #5 on: Mon, 28 September 2015, 13:44:24 »
I'll take the one with the pink/salmon switches!
Offline jbondeson
  • Trade Count: (0)
« Reply #6 on: Mon, 28 September 2015, 13:45:15 »
So the top picture are Salmon Alps, the bottom are Cream Damped Alps.
On the whole the salmon are usually more prized than cream.
Offline sth
  • 2 girls 1 cuprubber
  • Trade Count: (0)
« Reply #7 on: Mon, 28 September 2015, 13:48:32 »
Is anyone interested in JUST the switches from this board? i want the caps but its very expensive to ship a whole board to europe.
alternatively, cmadrid would you be interested in just parting out the caps and stabilizers? :D
Offline sth
  • Trade Count: (0)
« Reply #8 on: Mon, 28 September 2015, 13:56:31 »
actually YGPM!
Offline cmadrid
  • Trade Count: (0)
« Reply #9 on: Mon, 28 September 2015, 13:57:10 »
Not sure how I would get the stabilizers off the board without taking the whole thing apart.. do they just come off?
Offline sth
  • Trade Count: (0)
« Reply #10 on: Mon, 28 September 2015, 13:58:01 »
they should unclip from the plate. don't have one here to confirm, can anyone else? or can you pop the space and enter keys off so we can take a look?
Offline cmadrid
  • Trade Count: (0)
« Reply #11 on: Mon, 28 September 2015, 14:00:05 »
I'll take a look ;)
Offline sth
  • Trade Count: (0)
« Reply #12 on: Mon, 28 September 2015, 14:02:57 »
you rule and are the best, thanks :D
Offline jbondeson
  • Trade Count: (0)
« Reply #13 on: Mon, 28 September 2015, 14:04:01 »
They pop of the plate. You should be able to use a small screwdriver or plastic piece to get them off.
I would recommend popping the stabilizer wires off the plate hooks before pulling the caps. That will allow the wire to come up with the cap and cause less problems in the long run.
Offline jacobolus
  • Trade Count: (0)
« Reply #14 on: Mon, 28 September 2015, 14:06:43 »
The stabilizer bars are easy, just pop them off, but the plastic stabilizer clips can be difficult to remove from the top without breaking; they’re much easier to remove from the bottom of the plate, after desoldering all the switches and pulling off the PCB.
There’s no reason to do anything with the stabilizers before popping the keycaps off. Just take all the 1u keycaps off first (I recommend prying up from right and left sides with a pair of butter knives), and then pull the stabilized keycaps off afterward. Unlike MX/Costar style stabilizers, on these keyboards the plastic pieces which hold the stabilizers to the keycap are open on one end, so the stabilizer bar will naturally slide out the side when you pull the keycap off the board.
Do make sure you want to do this before pulling the stabilized keycaps off however, as they can be difficult to put back on without taking the case apart.
« Last Edit: Mon, 28 September 2015, 14:10:45 by jacobolus »
Offline sth
  • Trade Count: (0)
« Reply #15 on: Mon, 28 September 2015, 14:08:38 »
if anything breaks its not a HUGE deal because i have another set. they're just currently on a working board and i feel bad about cannibalizing a nice old fella like my m0116. but REALLY all i absolutely need, stab wise, is the spacebar wire and the lil insert that goes in the spacebar.
Offline cmadrid
  • Trade Count: (0)
« Reply #16 on: Mon, 28 September 2015, 14:16:35 »
I've gotten most of the stab parts out already.. should have pretty much all of them in a couple minutes
Offline sth
  • Trade Count: (0)
« Reply #17 on: Mon, 28 September 2015, 14:17:23 »
hot dog!!
dude of the year right here
Offline Lurch
  • Trade Count: (0)
« Reply #18 on: Mon, 28 September 2015, 14:17:40 »
hot dog!!
+1
  • Trade Count: (1)
« Reply #19 on: Mon, 28 September 2015, 15:02:57 »
Will you post a photo of the label of the one with salmon Alps?
Questions come up about that fairly often.
My theory is that some/most but not all 1989 copyright AEK2s have salmon, all 1990 copyrights have cream, and some/most and maybe all 1995 copyrights have white.
- Franklin Roosevelt 1933
Offline cmadrid
  • Trade Count: (0)
« Reply #20 on: Mon, 28 September 2015, 15:10:16 »
It is a 1990!  Both were 1990s
