Author Topic: How do I go about making a keyboard for less money?  (Read 5263 times)
Offline Vozella
« on: Mon, 28 September 2015, 15:31:09 »
I just got my quote from BigBlueSaw. It's $482.46.
My custom keyboard is going to cost about $500 for just the metal.
There must be another way.
Is there any way I can make a keyboard that doesn't cost my whole paycheck for the month?
Offline joey
Re: How do I go about making a keyboard for less money?
« Reply #1 on: Mon, 28 September 2015, 15:33:07 »
Offline Data
« Reply #2 on: Mon, 28 September 2015, 15:34:48 »
Shop around.  Big Blue Saw is rarely the cheapest option for laser cut metal.
You could also consider acrylic for your case.  Without knowing what you're trying to build it will be very difficult to make recommendations...
Offline Vozella
« Reply #3 on: Mon, 28 September 2015, 15:50:03 »
That sounds very expensive.
From here they should be ~$100: https://www.bigbluesaw.com/big-blue-saw/big-blue-saw-special-info/waterjet-and-laser-cut-keyboard-plates.html
It's not just the plate. It's the other parts that go under it.
Offline Vozella
« Reply #4 on: Mon, 28 September 2015, 15:51:32 »
I basically sent what builder.swillkb.com showed me.
« Reply #5 on: Mon, 28 September 2015, 15:53:51 »
But what is it?  A fullsize with a layered case or a 60% skeleton, or a pair of split angled boards like an ergodox or ???
Offline Vozella
« Reply #6 on: Mon, 28 September 2015, 15:58:56 »
Well, here's the layout. www.keyboard-layout-editor.com/#/gists/7cfe1bf4a04af1be6414 I chose the sandwich option on builder.swillkb.com.
« Reply #7 on: Mon, 28 September 2015, 16:14:02 »
There's a simple question/answer about that:
https://geekhack.org/index.php?topic=40501.0#post_GGGG
« Reply #8 on: Mon, 28 September 2015, 16:18:46 »
The keyboard is 15×5 units, which is the same as any 60% keyboard. That means that you could probably take any case for a 60% keyboard and modify it to support your keyboard.
The layout is otherwise quite close to an Atomic for which there are relatively affordable parts already. If you use their PCB then you won't need any plate, really.
Edit: Hey, look, I have already plugged the Atomic for you (in your very first thread here even), but I have yet to see you post a response about it.
« Last Edit: Mon, 28 September 2015, 16:23:43 by Findecanor »
« Reply #9 on: Mon, 28 September 2015, 16:30:18 »
It's not a standard stagger so there are switches where the poker screws go, not going to fit in a standard case.
Good call on the Atomic though, much cheaper than $500 :)
Offline Vozella
« Reply #10 on: Mon, 28 September 2015, 17:09:57 »
Sorry I haven't responded. I probably didn't understand. I'll look in to it right now.
Offline BigBlueSaw
    • Big Blue Saw
« Reply #11 on: Mon, 28 September 2015, 19:02:19 »
Did you combine all the designs into a single file, or did you try to quote each piece separately when quoting with Big Blue Saw?
See this page on how to combine designs to save money:
http://www.bigbluesaw.com/saw/big-blue-saw-blog/general-updates/the-best-tip-for-saving-money-with-big-blue-saw.html
Also, you don't have to use the same material for the top as for the other pieces. This may allow you to e.g. use stainless steel for the top, but much cheaper acrylic for the bottom and sides.
Offline ideus
  • Björkö.
« Reply #12 on: Mon, 28 September 2015, 19:05:39 »
Offline Vozella
« Reply #13 on: Mon, 28 September 2015, 19:35:10 »
Wow. I didn't know you had an account here.
Thank you, but how do I put the pieces together? I don't have a program to edit it.
Also, how different would the price be from stainless steel to acrylic? Nevermind. I can see it on your site.
« Last Edit: Mon, 28 September 2015, 19:59:26 by Vozella »
Offline jd29
« Reply #14 on: Mon, 28 September 2015, 19:49:43 »
The cheapest way to make a keyboard is in layers. Unibody is most elegant, but also most expensive. If economics are a big concern, this is probably how you make your money go the furthest:
112181-0
That said, $500 is very expensive for metal, even if you're doing unibody, I think. The best prices I found are from online metals.
Offline BigBlueSaw
    • Big Blue Saw
« Reply #15 on: Tue, 29 September 2015, 09:38:16 »
For those who didn't spot it, the list of recommended CAD is here:
http://www.bigbluesaw.com/saw/faqs/files/what-software-can-i-use-to-make-files-for-big-blue-saw.html
How thick are cases typically?  I could put some more cases on the examples page.
« Reply #16 on: Tue, 29 September 2015, 13:04:14 »
The JD40 is 12mm between the two plates, this is enough room for the PCB with a Teensy attached under it, so that sounds like a good minimum thickness :)
« Reply #18 on: Tue, 29 September 2015, 15:13:05 »
Good work but the USB hole is near the side not in the middle, using a ruler I'd say it's about 22mm in (allowing for a chunky connector)  Don't think that will change the quote though!
As a rough estimate how much would I be looking at to ship two of those with acrylic bottoms to the UK?  I like that you're involved in the site so would like to support you, but have always assumed between shipping and customs it wouldn't be feasible.
Offline BigBlueSaw
    • Big Blue Saw
« Reply #19 on: Wed, 30 September 2015, 09:45:53 »
I just used the shapes as they came off of builder.swillkb.com. Of course everybody's keyboard case is going to be a little different, with varying margins, hole locations, and so forth.
International shipping is typically US$40 to US$80. If you've got your design ready, e-mail us and we can give you an exact quote.
