Author Topic: White Acrylic Plastic vs Clear Acrylic Plastic  (Read 2740 times)
Offline Vozella
« on: Mon, 28 September 2015, 20:36:09 »
https://www.bigbluesaw.com/big-blue-saw/big-blue-saw-special-info/waterjet-and-laser-cut-keyboard-plates.html
https://geekhack.org/index.php?topic=75641.0
So in my previous thread, people told me to make my keyboard cheaper by making some parts acrylic. But on BigBlueSaw's website, they have two kinds of acrylic. White and Clear. Clear seems to be a little bit cheaper. Why?
Is one better thatn the other? Stronger? Squishier?
Can I spray paint if I don't like the color of the white/clear acrylic?
How clear is Clear acrylic?
Offline njbair
    • nickbair.net
Re: White Acrylic Plastic vs Clear Acrylic Plastic
« Reply #1 on: Mon, 28 September 2015, 20:50:17 »
Clear is clear. Here's an example:
My boards:
Offline Vozella
« Reply #2 on: Mon, 28 September 2015, 21:27:33 »
Woah. That's really clear. Thank you. I think I'll go with Clear.
Offline njbair
    • nickbair.net
« Reply #3 on: Mon, 28 September 2015, 22:18:30 »
It's a cool look, and if you have any backlighting it can make for a neat effect.
My boards:
