Author Topic: [IC] Out of the Vault - Overseer Idea Generation Thread (All Done...)  (Read 191796 times)
Offline Oobly
Re: [IC] Out of the Vault - Overseers Edition: ABS SA Row 3/Row 1 Vault Pride
« Reply #50 on: Fri, 09 October 2015, 01:21:35 »
The Fat Man caps are awesome! I like the red one more and it would actually fulfil the role of the white on red NukaCola for my purposes. Good job. :D
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Dernubenfrieken
« Reply #51 on: Fri, 09 October 2015, 06:27:02 »
Added Red Ring of Death Nuke to OP...
Love it, don't even need to be a fallout fan for that novelty.
Offline Data
« Reply #52 on: Fri, 09 October 2015, 07:56:34 »
Fat Man is wicked good.
Suggestion for custom legend:
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: [IC] Out of the Vault - Overseers Edition: Vault Pride
« Reply #53 on: Fri, 09 October 2015, 08:57:55 »
How about Vault 12 as a GID legend on the normal blue blackground, like Vault 13. It's the home of the glowing ones...
Been thinking on this one...what if instead of the GID material we use the Toxic Green color for the Yellow portion of the legend, or maybe GID for the key, but BFK blue for the legend?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #54 on: Fri, 09 October 2015, 11:42:29 »
Really like the fat man legend  :thumb:
Blue on GID sounds awesome!
Offline zaarx
« Reply #55 on: Sun, 11 October 2015, 16:09:57 »
I like both the vault and fat man designs and I'll be all over this if it becomes a buy.
Offline 00zeRO
« Reply #56 on: Sun, 11 October 2015, 17:50:22 »
Thanks for the support.  I will likely come up with one more design and then get this ball a rollin
Offline Oobly
« Reply #57 on: Mon, 12 October 2015, 04:52:40 »
I like it! GID base (YCA) with blue legend (BFK) would be nice.
Offline TheMalacoda
« Reply #58 on: Mon, 12 October 2015, 12:13:06 »
This. Glowing stuff is what I need.
Offline 00zeRO
« Reply #59 on: Mon, 12 October 2015, 13:00:20 »
I will try to get a decent mock up done once I create the Vault 12 legend. Would you think the legend to be better with the new 111 style, or like the 13/101 from Series II?
Offline StarPupil
« Reply #60 on: Mon, 12 October 2015, 13:50:37 »
Any chance we could get some of the more iconic monsters? Like a deathclaw claw or Yao Guai head? Perhaps a BoS helmet? And hopefully in the Carbon colors?
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #61 on: Mon, 12 October 2015, 13:54:33 »
I think that the old design would be best. It really looks like it compliments the selectric and danger zone keysets.
Offline 00zeRO
« Reply #62 on: Mon, 12 October 2015, 14:34:04 »
Possibly, but the detail would need to be as little as possible. For example, it would need to be like the KeyPop Chocobo keycap:
Offline StarPupil
« Reply #63 on: Mon, 12 October 2015, 15:04:57 »
I thought there would be loads of minimalist wallpapers somewhere, but I can't find them at the moment. But I figure you could do something like the eyes and breather thing for the helmet. Or, if it were possible, the eyes and breather in the same bright color as the normal key with a darker color for the helmet. But both of those seem to be way more complex than the chocobo you linked.
Offline 00zeRO
« Reply #64 on: Mon, 12 October 2015, 15:09:21 »
This is certainly a cool idea.
Offline 00zeRO
« Reply #65 on: Mon, 12 October 2015, 21:42:47 »
Just added a Vault 12 mockup in the OP...
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #66 on: Mon, 12 October 2015, 21:44:33 »
Looks good. Super bright (which is the point)
Offline 00zeRO
« Reply #67 on: Mon, 12 October 2015, 21:51:23 »
It is supposed to show a rudimentary look of being glow-in-the-dark...
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #68 on: Mon, 12 October 2015, 21:53:21 »
Oh I know. My post wasn't meant to sound negative. I like it
Offline 00zeRO
« Reply #69 on: Mon, 12 October 2015, 22:22:57 »
Ok, so I couldn't resist trying to come up with my current Fallout 3 companion's vault, 87:
Just added Vault 87 mockup to OP.
Offline Pwner
  • soon™
« Reply #70 on: Tue, 13 October 2015, 01:41:44 »
I'm down for a couple of red mini nukes.  :thumb:
Offline Oobly
« Reply #71 on: Tue, 13 October 2015, 05:00:28 »
Looking great, 00Zero!
I'd like to have all them like this:
Row 3: All
Row 1: Vault 111, Red Nuke, Vault 12
Insta-buy.
Offline linkshine
  • If you wanna b my lover, u gotta get w/ my friends
« Reply #72 on: Tue, 13 October 2015, 09:34:28 »
Yeah i'ma be buyin deez right hur.
Offline TheMalacoda
« Reply #73 on: Tue, 13 October 2015, 09:47:14 »
Something is wrong here... I am throwing money at the screen but I have not received my caps. What gives?  :p I will dip a little fly in your ointment though and say I would love to have a Vault 13, cause it was in the first game but also because it's my lucky number. Honestly though, I'm in love with it just the way it is right now.
Row 3: All
Insta-buy.
Have any row decisions been made yet? Jukebox is in the mail to me right now and I'll get Carbon at some point, but I use 1976 everyday at work... Hmmm.
Offline 00zeRO
« Reply #74 on: Tue, 13 October 2015, 10:38:43 »
Row 3: All
Insta-buy.
This is the time for decisions. I am leaning toward just running one keycap for now: Vault 111. I will likely manage it just like this one, and similarly I will only offer two colors to choose from. So, two colors, and two Row heights (Row 1, Row 3) to choose from. It will be a la carte and so you only purchase the keycap(s) you want and get none you don't.
I am repurposing this IC to be for all Fallout ideas going forward, but each GB will be short, sweet, and most importantly simple. So, with Fallout 4 release imminent, Vault 111 keycap is top priority for this next GB. (Sorry Oobly)
Offline 00zeRO
Re: [IC] Out of the Vault - Overseer Idea Generation Thread (Ideas Welcome!)
« Reply #75 on: Tue, 13 October 2015, 10:42:11 »
This IC has been repurposed...see OP.
Offline TheMalacoda
« Reply #76 on: Tue, 13 October 2015, 13:24:04 »
Excellent idea! Also much easier to manage for you and less expensive for us. We can't lose with this!
Offline Oobly
« Reply #77 on: Tue, 13 October 2015, 13:52:28 »
Row 3: All
Insta-buy.
No worries, I'm happy however you want to run these. I'll order them as they come :) I do think the last buy got a bit.. out of hand, a simpler buy sounds great to me. Win-win for all.
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #78 on: Tue, 13 October 2015, 13:54:20 »
A Gasmask would be good.
Offline linkshine
« Reply #79 on: Tue, 13 October 2015, 14:00:20 »
Martin has the corner on gasmasks :P
Offline 00zeRO
« Reply #80 on: Tue, 13 October 2015, 14:02:09 »
That will come in another set unrelated set...
Offline 00zeRO
« Reply #81 on: Tue, 13 October 2015, 14:03:28 »
He certainly has it regarding artisan 3D Gasmasks, but I have plans for a 2D Doubleshot Gasmask of sorts...
Offline Steezus
  • Keeper of Facts
« Reply #82 on: Tue, 13 October 2015, 14:43:12 »
Glad to see a lot of interest with the red mini nuke! Another Idea I came up with is possibly a Garden of Eden Creation Kit (G.E.C.K.) key. I always like to have a a key assigned to open "My Computer" on my keyboard and I think a G.E.C.K. would be perfect for a key similar to that. I don't know really know how creative you could get with it but you could either do a picture of the G.E.C.K. box or just the letter G.E.C.K. itself. I also don't know how well of interest it will get depending on whether people get the reference or not.
Offline 00zeRO
« Reply #83 on: Tue, 13 October 2015, 15:39:21 »
Funny you should mention it...I was on the toilet today and this thought occurred to me. Funny how that happens.  :p
Offline linkshine
« Reply #84 on: Tue, 13 October 2015, 16:14:54 »
That would actually be awesome next to his gasmasks
Offline 00zeRO
« Reply #85 on: Tue, 13 October 2015, 16:24:07 »
My design will not resemble his in the slightest...but it will be in a completely separate series I am planning and will not be a Fallout-inspired set.
Offline linkshine
« Reply #86 on: Tue, 13 October 2015, 16:25:31 »
So would the right color Martin masks compliment the set you've got a vision for? I think that would be a good thing. Martin's such a nice guy I don't think he'd mind something that his caps would compliment
Offline 00zeRO
« Reply #87 on: Tue, 13 October 2015, 16:34:32 »
Perhaps...
Offline linkshine
« Reply #88 on: Tue, 13 October 2015, 16:36:48 »
Perhaps...
cool. eager to see it in the future
Offline Steezus
  • Keeper of Facts
« Reply #89 on: Tue, 13 October 2015, 17:01:45 »
Haha great minds think alike. ;)
Offline 00zeRO
« Reply #90 on: Fri, 16 October 2015, 08:55:56 »
On the subject of the vault 111 keycap, I want to possibly run two color variants: Grey w/Yellow legend and ?standard Vault colors? ...or would you rather see something else as alternate colors? Input please...
Offline Steezus
  • Keeper of Facts
« Reply #91 on: Fri, 16 October 2015, 09:10:32 »
I'm a fan of blue with yellow legends, when vault colors come to mind that's usually the two that I think of from the vault suits. The vaults in Fallout 4 are grey with yellow but in Fallout 3 they don't really have any color to them.
« Reply #92 on: Fri, 16 October 2015, 13:32:16 »
I would love the classic color vault 111 and vault 87 to go with the 101 and 13 vault caps from the previous series.
The means 4 matching color caps in row 3 SA so I can change one section of my function row to use them  :cool:
Offline 00zeRO
« Reply #93 on: Fri, 16 October 2015, 13:38:56 »
So you are saying the original Vault 111 legend from the cancelled Series III
« Reply #94 on: Fri, 16 October 2015, 13:44:52 »
If there was the option to have 111 with the 'classic' legend and colors, that would be great.
I still really like the new 111 legend! In no way do I want to replace that.
EDIT: Just to show how much of a fan I am, this on my desk at work and I always clacking on it when thinking about stuff
« Last Edit: Fri, 16 October 2015, 13:47:06 by nathanrosspowell »
Offline 00zeRO
« Reply #95 on: Fri, 16 October 2015, 13:54:17 »
Just wait until you see the Nuka Cola Quantum DSA keycaps. Shame it will never be in SA Row 3 (my dream)
Offline Xenocidal
  • Professional Lurker
« Reply #96 on: Fri, 16 October 2015, 23:37:41 »
I am liking everything so far, just hoping for any Row 1 options for my Fallout themed board "Radiation King".
I'd kill for anything in the Jukebox colorway!
Offline 00zeRO
« Reply #97 on: Sun, 18 October 2015, 11:08:15 »
I'm saving this colorway for a completely different set that will feature the mini nuke in it
Offline 00zeRO
« Reply #98 on: Wed, 21 October 2015, 09:52:41 »
Okay, I have a nutty idea:
What if I do a single colorway with the new Vault 111 legend, but run a GB with 3 options: SA Row 1, SA Row 3, and DSA? Anyone is free to purchase any one or more of each profile, mix and match; or whichever profile strikes the fancy. I will do my best to have renderings next to each key on the both the GB OP and in the order form to minimize confusion.
What do you all think? Good idea, or bad idea?
Offline 00zeRO
« Reply #99 on: Wed, 21 October 2015, 18:58:02 »
Gauging by lack of response, it must be a bad idea.
