Author Topic: Questions About Costar Stabilizers (& Diodes)  (Read 2047 times)
Offline Vozella
« on: Tue, 06 October 2015, 14:32:34 »
1) I heard they are pretty loud. Is there a way to make them quieter?
2) Where do you buy costar stabilizers? Also, where do you buy diodes?
Re: Questions About Costar Stabilizers (& Diodes)
« Reply #1 on: Tue, 06 October 2015, 14:34:29 »
There's a thread where you can ask simple questions instead of posting a thread for every single one. -> https://geekhack.org/index.php?topic=40501.0
Also for through hole diodes I bought these http://www.ebay.com/itm/500PC-1N4148-Diode-FSC-NXP-PHI-VISHAY-DO-35-1N4148-/400820873745?hash=item5d52c92a11
« Last Edit: Tue, 06 October 2015, 14:39:26 by SpAmRaY »
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #2 on: Tue, 06 October 2015, 14:36:32 »
You can lube them to quiet the rattle noise, if it has any. Plate mount Costar stabs you can get from WASD. Diodes you can get from Mouser, or Digikey, or even Radio Shack sometimes.
Ray is right, if you post in the Simple Questions thread you will get all kinds of good info. :)
Offline Vozella
« Reply #3 on: Tue, 06 October 2015, 14:52:04 »
Thanks. I'll do that from now on.
