Author Topic: QWERTY -> DVORAK on Filco?  (Read 10830 times)
Offline kencheeto
« on: Thu, 29 October 2009, 21:42:32 »
Hi guys, I purchased a Filco Tenkeyless Cherry Blue keyboard about when they were available at elitekeyboards, and I was curious if there was an easy way to switch the layout from QWERTY to DVORAK?
I searched but couldn't find anything about this specifically. I don't really mind spending a little money, but am mostly curious if someone has already done this or knows comfortably how.
Offline justin
« Reply #1 on: Thu, 29 October 2009, 21:49:02 »
If it has the keylabels, just remove the keys and rearrange them. If it's blank there's nothing to do. Either way, you just switch the layout in your operating system's preferences and you're good to go. It's pretty simple.
Offline Xuan
« Reply #2 on: Thu, 29 October 2009, 23:39:10 »
Quote from: justin;129312
Do Filcos have all keys shaped the same way like BS boards?
Offline timw4mail
    • https://timshomepage.net
« Reply #3 on: Fri, 30 October 2009, 07:24:56 »
Quote from: Xuan;129316
No, they don't. They're sculpted.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
« Reply #4 on: Fri, 30 October 2009, 07:58:15 »
Go blank/"Otaku." That will solve all your problems. I am a much better typist today for it.
Offline kencheeto
« Reply #5 on: Fri, 30 October 2009, 13:17:05 »
Ok, so I could get the replacement Otaku keycaps and change out just the letters.. Or I could just ignore the lettering. That wouldn't be as cool..
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #6 on: Fri, 30 October 2009, 14:02:26 »
Personally, from my experience, it would be easier to learn another layout on a keyboard that feels much different than a normal one with the QWERTY layout. That way, it would be easier to learn something completely new rather than learn how to do that and use the QWERTY ones.
Offline kencheeto
« Reply #7 on: Fri, 30 October 2009, 15:44:25 »
UGH I hate you guys. Now I'll just have to spring for another keyboard :D
Hmm.. Looks like I've got some reading to do into Topre switches.
Offline hyperlinked
« Reply #8 on: Sat, 31 October 2009, 03:00:08 »
Quote from: kencheeto;129441
Wow. It didn't take much to get you to squeal. A couple of lukewarm answers about keycaps and you're gunning for a Topre board. Delete this site from your bookmarks before it's too late!
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline d2v
« Reply #9 on: Sat, 31 October 2009, 06:41:19 »
As Oscar Wilde said :
The only way to get rid of temptation is to yield to it... I can resist everything but temptation.
DSI SMK-88 (Black cherry), TVS Gold, Kensington Expert Mouse, MS NEK 4000, MS NWM 6000
Offline kencheeto
« Reply #10 on: Sat, 31 October 2009, 19:03:51 »
Yeah, it only took about a week of lurking around on the boards to convince me to grab the filco blue cherry tenkeyless. Easily the best computer-related upgrade I've done in a while, so I feel its justified.
Offline kencheeto
« Reply #11 on: Sun, 01 November 2009, 18:30:52 »
Quote from: timw4mail;129343
Wait..
I just ordered the keycap puller from elitekeyboards. I was planning on rearranging the qwerty layout to dvorak- leaving all the non-letter keys in their spots. The letters will be interchangeable, right?
Offline timw4mail
« Reply #12 on: Sun, 01 November 2009, 19:08:46 »
Quote from: kencheeto;129817
Wait..
Only if you want one weirdly bumpy typing experience.
Offline rdh
« Reply #13 on: Sun, 01 November 2009, 19:11:42 »
Sorry, no.  The Filco boards (like most keyboards) use differently-shaped keycaps in each row.
This picture shows a set of blank Filco key caps in their normal order on a flat surface.  The picture doesn't highlight it well, but if you look closely you can see the shape differences:
Look especially at the number key row vs. the Z-row, if you're having trouble seeing it.
You can swap the keys around within the rows without problems, but if you swap between different rows, the tops of the keys will be at different heights and angles.
Try swapping a few keys from different rows to see what you think.  The mismatched feel would annoy me a lot, but you may not mind as much.
Even if you don't end up swapping your caps, the puller will still be useful for situations like when you want to clean the key caps.
at home: IBM "Space Saving" Model M
at work: Topre Realforce 87UKB55
Offline kencheeto
« Reply #14 on: Sun, 01 November 2009, 19:16:08 »
I see. Thanks for the info- I think I'll spring for the blank key replacement set and keep a layout printed until I'm comfortable with dvorak. Also, should I choose to switch between qwerty and dvorak I'll be able to easily.
Offline kencheeto
« Reply #15 on: Sun, 08 November 2009, 18:35:29 »
Well, I've switched to dvorak and so far I'm loving it. Not quite at my previous 120-130 wpm but picking it up faster than expected. Thanks for everyone's input!
Offline DreymaR
  • Colemak forum guy
    • DreymaR's Big Bag of Kbd Tricks
« Reply #16 on: Mon, 09 November 2009, 08:02:10 »
One word for you my friend: Colemak. Where it's at.  :)
Better burden you cannot carry than man-wisdom much ~ Hávamál
Offline AndrewZorn
« Reply #17 on: Mon, 09 November 2009, 10:41:29 »
colemak
Offline DreymaR
  • Colemak forum guy
« Reply #18 on: Mon, 09 November 2009, 11:12:51 »
word  ;)
Offline kencheeto
« Reply #19 on: Mon, 09 November 2009, 23:14:15 »
Alright, I just checked it out.. Read the Colemak forums and haven't read anything super convincing yet. Am I missing some killer feature?
Offline Rajagra
« Reply #20 on: Tue, 10 November 2009, 07:19:46 »
Quote from: kencheeto;131430
Yes. Colemak requires less effort, is easier to learn coming from Qwerty, and keeps keys for important shortcuts in the standard places.
http://mkweb.bcgsc.ca/carpalx/?colemak
Dvorak on the other hand is sometimes easier to setup, and you can buy hardware-based Dvorak keyboards.
Offline AndrewZorn
« Reply #21 on: Tue, 10 November 2009, 07:33:24 »
less effort also meaning higher speed potential, if you are still missing that main point
Offline kencheeto
« Reply #22 on: Tue, 10 November 2009, 15:21:54 »
Awesome; I figured it out. I'll keep you posted :)
« Last Edit: Tue, 10 November 2009, 15:43:51 by kencheeto »
Offline DreymaR
  • Colemak forum guy
« Reply #23 on: Fri, 13 November 2009, 03:22:47 »
Me?  ;p
Offline kencheeto
« Reply #24 on: Wed, 25 November 2009, 03:26:20 »
I've had to do a ton of coding the past week, so I haven't been able to make the switch yet- I've got my blank caps and am ready to rock this winter break 8)
Offline spremino
« Reply #25 on: Wed, 25 November 2009, 03:57:22 »
Quote from: kencheeto;136135
Wise decision. Learning your first alternative layout will be frustrating, the first week at least, therefore it makes sense doing it when you can take a relaxed pace.
A long space bar... what a waste of space!
Offline patrickgeekhack
« Reply #26 on: Fri, 27 November 2009, 22:25:55 »
Quote from: hyperlinked;129507
Good advice, but it usually does not work if the person has already started posting here :-)
Personally, I think most people don't come here just to learn about keyboards in general. In most cases they were just looking for some reviews about a particular keyboard and some just go on to buy the keyboard after they got the reviews they wanted. This was my intention when I was deciding between the Customizer and the Das. But because I have always liked a good keyboard and always like to try a keyboard I have never tried, I continued to visit this forum and ended up with a collection.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline ricercar
  • mostly abides
i like to watch
« Reply #27 on: Mon, 30 November 2009, 17:11:54 »
I came here because I'd never met a keyboard aficionado other than me, and stayed because I realized I'm an amateur. That and I like sparring--and watching people spar--with intelligent people who won't hit me or start crying...
:popcorn:
« Reply #28 on: Mon, 30 November 2009, 17:17:15 »
I don't want to type on a keyboard in that Lego layout!
Offline ricercar
  • mostly abides
« Reply #29 on: Mon, 30 November 2009, 23:17:08 »
Quote from: ripster;137581
You cut me Shrek. You cut me deep.
Offline DreymaR
  • Colemak forum guy
« Reply #30 on: Tue, 01 December 2009, 03:52:47 »
Quote from: microsoft windows;137583
If you were, that line would read:
Quote from: LEGOmsWin
I ON AN O YPE ON A KEYBOAR IN HA LEGO LAYOU
 :D
« Reply #31 on: Wed, 02 December 2009, 19:11:00 »
Quote from: ripster;137592
I fart in your general direction.
Claviers Japonais PFffffffttt!
You missing a keycap there?
Offline kencheeto
« Reply #32 on: Mon, 07 December 2009, 02:15:51 »
10 days until I unleash Colemak.
However, I have another question- Are the keycaps on the HHKB Pro 2 formed uniquely like the Filco tenkeyless? Or would I be able to switch the keys around on the hhkb without getting the blank keycaps or getting it factory customized?
Thanks for putting up with me! I'm considering saving for a hhkb pro 2.
Offline AndrewZorn
« Reply #33 on: Mon, 07 December 2009, 05:01:57 »
the rows are different shapes.  you dont want to rearrange anyway, the nubs are worth more than the lettering.
Offline chimborazo
« Reply #34 on: Fri, 11 February 2011, 01:47:09 »
Quote from: DreymaR;131192
lol if there are any words which would abbreviate in the english language - and justify in the process an unsubstantiated claim such as colemak is where it’s at, and hence is better than dvorak - i cant think of a better one than flatulent conclusion.
i thought the discussion as to which one of the two is better was over with by now or it ought to be, lol but apparently not.
kauffmann and others have turned a blind eye to your theories - posted on the colemak forum - and this in itself should give an everlasting pause to this never ending argument.
but this is not it, there comes rajagra, who months ago was - shall i say - impartial one way or another to the discussion, but now he is a biased colemak user. i do wish colemak the best and i mean it. the problem - if there is one lol - stems from the fact that his color-filled-headache-inducing graph makes me realize that colemak proponents are out there, just like the jehova witnesses, who try to convert non-dvorak and dvorak users alike to their preferred denomination. good luck.
