Author Topic: Help me decide a layout.  (Read 2051 times)
Offline Jixr
« on: Sun, 11 October 2015, 19:17:03 »
Hi all, i'm getting ready to finalize my build, but can't really decide on a layout and figure you guys may can help me decide.
I have a redscarf, and currently I have its layout 'standard'
but I have another one at my office that I use a modified layout with.
I kinda like the second layout a little better, but since that one is pcb mounted, its much easeir to change layouts compared to the plated one in the standard layout. Though I will need to find a 7x spacebar wire somewhere. ( or if someone wants to trade one for a standard wire, or just bend my own )
I should be getting in my keycaps from ivans buy in a month or so ( i hope ) and trying to decide which way to go. The second one has dedicated arrow keys ( the first one I just use the bottom right menu keys as my arrow keys ala pokerX )
My worry is since the PCB on these are incredibly cheap and thin, i don't want to burn out the traces if I decide to desolder everything to change the layout, and then that limits my keycap options quite a bit. I'm also going to solder in LED's, and thats another big hassle.
Any ideas or suggestions?
Offline Wuzadi
Re: Help me decide a layout.
« Reply #1 on: Sun, 11 October 2015, 19:39:23 »
Sorry I'm no help and this is a tad off subject, but I've only just recently heard about redscarfs. The second layout looks pretty amazing, never seen a layout like that yet. Are these desirable because they are so customizable?
You met me at a very strange time in my life.
Offline Jixr
« Reply #2 on: Sun, 11 October 2015, 19:48:30 »
they are just nice because its the cheapest way you can get a compact layout like this without going to a quickfire tk
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Sun, 11 October 2015, 19:52:38 »
I like the second layout, it's good.
My RS96 is set up like that. Well ISO but all the rest is similar.
It's a very comfortable layout.
Any 1800 compatible keyset works with it.
Azerty Propagandiste
Offline Wuzadi
« Reply #4 on: Sun, 11 October 2015, 20:20:58 »
Ahh makes sense. Really digging the second layout.
Offline nevin
« Reply #5 on: Wed, 21 October 2015, 22:23:54 »
originally  i was looking for something similar, grabbed a cheap mk96, liked it, but currently using a 60‰ w/separate 10 key. If you're one that likes the latest greateat keycaps, a standard layout would be better as a lot of keycap sets don't include some of the non-standard keys. But nothing beats having a keyboard layout you love.
Offline 0100010
  • Not Sure
« Reply #6 on: Fri, 23 October 2015, 18:43:56 »
Looks like a lightsaver.  The second layout I like better.
http://www.keyboard-layout-editor.com/#/layouts/b0561f208c10225c3ecd6782badcc687
