Author Topic: Wood 60% case  (Read 6236 times)
Wood 60% case
« on: Tue, 13 October 2015, 20:45:14 »
Still deciding if I want to do MX or Alps in it, but I'm pretty happy with how it turned out.  There are some small flaws, but I was going for proof of concept over perfection.  I couldn't find the cork I usually use in cases, so I tried a new one.  It was definitely a much lower quality cork, but it did the job.  I may still flock it, but I think I like the simple cork only filler.
The wood was sanded to 1000 grit and finished with oil and then a coat of paste wax on top of that.  Normally I would use Deft Danish oil, but it disappeared on me and I had to use the inferior Watco.  A quick wipe down with mineral spirits after it was allowed to soak in some did seem to make it a little less awful.
It's hard to tell, but the integrated palm rest has a curve to it.  It's almost perfectly centered.  This allows me to rest my palms on the case at a more natural slightly angled position.
The foot is a routered piece of purple heart that's glued in place in a shallow dadod channel.  I've toyed with anchoring it with screws from the back side, but it doesn't really affect the case to just have it glued into the channel.  I can't tell you the exact angle it gives the case, but I believe it's around 7 degrees.  The USB hole was drilled and filed to size and shape.
I've noticed in the past that the plain brass standoffs can be problematic, so I decided to try something new.  I found some nylon spacers, bored them out to the right size since they were a little too narrow, then cut them and sanded them down to size.  I slipped them over standoff after I seated it and slipped an o-ring on top of the spacer and around the standoff.  This should give it a nice snug fit against the PCB that should make it more solid feeling while also protecting the PCB.  Edit:  I tested it and it really does make it feel nicer.  It also helps that the rubber can compress so you can "tune" the plate height.
And finished.  FaceW PCB (but the damn Fn key doesn't work) with Krytox lubed MX Clears with AboStudio clear tops, purple switch stickers, and 67g springs, blue (cyanish color) anodized plate, with the Cyan GMK set and one of the GMK Esc caps from Ivan's buy.
« Last Edit: Wed, 14 October 2015, 18:27:22 by nubbinator »
Offline Badwrench
  • ummmm.....I forgot
Re: Wood 60% case
« Reply #1 on: Tue, 13 October 2015, 20:50:15 »
Beautiful.  Really digging the subtle curve on the wrist rest.   :thumb:
Offline mobbo
  • u fk
Re: Wood 60% case
« Reply #2 on: Tue, 13 October 2015, 21:08:43 »
This is really tasteful. Fantastic job.
Quote from: Binge
Re: Wood 60% case
« Reply #3 on: Tue, 13 October 2015, 21:16:22 »
Thanks man.  I really like it.  Next time I think I'll make a little gap between the start of the slope and the caps.
I'm not used to hearing tasteful applied to my combinations, especially when cyan is involved.  I do appreciate it though.
Re: Wood 60% case
« Reply #4 on: Wed, 14 October 2015, 01:16:24 »
First wood kit I want... need even... Matias alps in hhbk configuration on infinity with sp  dcs double shots.
« Last Edit: Wed, 14 October 2015, 18:27:51 by Binge »
Offline Yoe
  • Alps & ISO <3
Re: Wood 60% case
« Reply #5 on: Wed, 14 October 2015, 02:53:11 »
Quickly! Throw me the KBOTM nomination thread for October! I frikkin need it NOW!  :)
Offline ghostjuggernaut
Re: Wood 60% case
« Reply #6 on: Wed, 14 October 2015, 18:16:11 »
Amazing work man. I'm not normally a fan of integrated rests, but this looks phenomenal.
Offline MrRooks
  • Always be knolling
Re: Wood 60% case
« Reply #7 on: Wed, 14 October 2015, 19:09:17 »
Beautiful work!
Offline neverused
Re: Wood 60% case
« Reply #8 on: Fri, 16 October 2015, 19:35:27 »
This is awesome
Offline p1114501510
  • 尴尬癌晚期患者
Re: Wood 60% case
« Reply #9 on: Sat, 17 October 2015, 08:15:54 »
Great job, man. Will you have a group buy?
Re: Wood 60% case
« Reply #10 on: Sat, 17 October 2015, 09:07:07 »
Yeah I'm not entirely convinced the shiny plate and bright caps are a "tasteful" compliment to a classic wood case, but it's a Nubbs creation so wouldn't be right if it was!
It's an amazing looking board either way :)
Offline Pwner
  • soon™
Re: Wood 60% case
« Reply #11 on: Sat, 17 October 2015, 21:05:22 »
That turned out beautiful.  The curve in that rest is such a nice touch.
Offline Jhonan
  • Chicks love duck pics...
Re: Wood 60% case
« Reply #12 on: Sun, 25 October 2015, 16:34:53 »
It really is gorgeous, love that curve and the rounded "foot" at the end.
Offline 1swt2gs
  • DOGE
Re: Wood 60% case
« Reply #13 on: Sun, 25 October 2015, 17:11:30 »
This looks amazing! Thanks for my new wallpaper!
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline gabba-gool
Re: Wood 60% case
« Reply #14 on: Sun, 25 October 2015, 17:24:05 »
Awesome work.
Offline Kad
  • Δ E S T H E T I C S
Re: Wood 60% case
« Reply #15 on: Sun, 25 October 2015, 17:34:09 »
Very interesting and very beautiful! Great job.
[WASD v2 w/ MX Blues]
Offline fliptrik
Re: Wood 60% case
« Reply #16 on: Sun, 25 October 2015, 17:54:39 »
Damn that looks hella snazzy with the Cyan set. Good work, man!
Offline DrCr4nK
  • Yeah, man. I dig that.
Re: Wood 60% case
« Reply #17 on: Sun, 25 October 2015, 20:43:09 »
Holy hell.  I just bought a wood case that I'm very pleased with, but do have another board in considering putting one in.  This is really nice, man! :D
Offline Kola93
Re: Wood 60% case
« Reply #18 on: Sun, 25 October 2015, 23:19:13 »
This is a really cool project!
Do you have plans to maybe make a few extras for sale? ^-^
