Author Topic: My brothers laptop keyboard is acting weird.  (Read 1440 times)
Offline ANightOnCloudNine
« on: Wed, 14 October 2015, 05:44:50 »
I'm just cleaning his computer by removing bloat ware and stuff but whenever I press the right arrow key it doesn't go right instead it makes a 0 and left arrow makes a p, also if I press the letter p it continues typing behind the p so if I wanted to spell the word Pepsi it would be types esipp, I would appreciate help to make it act normal.
Offline Oobly
Re: My brothers laptop keyboard is acting weird.
« Reply #1 on: Wed, 14 October 2015, 06:09:07 »
Sounds like a damaged membrane. Probably on one column. No real solution to that if it is, except to find a replacement board. Depending on the model you can find some on ebay.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #2 on: Wed, 14 October 2015, 13:43:21 »
Laptop :/
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #3 on: Wed, 14 October 2015, 13:52:18 »
Laptop :/
Laptop keyboards are super easy to replace. Typically pretty cheap too. Don't be afraid! It is like 5 screws tops and 10 minutes of your time. I've done it more times than I can count.
Offline asdfjkl36
  • blue shirt guy
« Reply #4 on: Wed, 14 October 2015, 14:03:28 »
Yea, laptop keyboard are fairly easy depending on the model
Don't be afraid to do it, just take your time.
Or an easy fix, just slap a TKL or 60% on top of the laptop and use that :)
