Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
How do you remove the top plate on a Model M?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How do you remove the top plate on a Model M? (Read 1579 times)
ch_123
Exalted Elder
Thread Starter
on:
Mon, 02 November 2009, 12:07:40 »
Title says it all. By plate, I mean that of the keyboard assembly itself - so basically the black plastic part that has all the barrels for the keys on it. Do I need to break off plastic rivets or what?
Logged
itlnstln
Reply #1 on:
Mon, 02 November 2009, 12:13:33 »
I don't know for sure, but IIRC, I do think you have to break the rivets.
Logged
ch_123
Exalted Elder
Thread Starter
Reply #2 on:
Mon, 02 November 2009, 12:25:45 »
Unfortunate. Fortunately I have a defunct Unicomp which I might use for guinea pig practice.
Logged
itlnstln
Reply #3 on:
Mon, 02 November 2009, 16:26:21 »
Of all the cost-cutting measures they could have taken, I wonder why they went the plastic rivet route. They could have used metal rivets and still saved money. That said, if metal rivets broke, they would be a lot harder to fix.
Logged
ch_123
Exalted Elder
Thread Starter
Reply #4 on:
Mon, 02 November 2009, 17:30:01 »
The best route would have been to replace the membrane with a hard PCB mounted on the back plate, and have the two sides of the plate slide together using metal tabs.
Oh wait... that's the Model F... =P
Logged
JBert
Reply #5 on:
Tue, 03 November 2009, 12:43:20 »
Hey, my model F AT still has its foam intact. Also, it doesn't do that much although it might dampen some sounds.
Logged
The storage list:
Currently ignored by: nobody?
[/SIZE]
ch_123
Exalted Elder
Thread Starter
Reply #6 on:
Tue, 03 November 2009, 12:50:48 »
Besides, it's not as if Foam is a scarce and rare material if it needed to be replaced.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
