Author Topic: my mate spilled some pepsi on his keyboard (membrane)  (Read 3132 times)
Offline ANightOnCloudNine
« on: Sat, 17 October 2015, 00:46:53 »
and his keyboard was fine for like 20 minutes but it all of a sudden started ****ting out and started acting weird and messed with his mouse controls, any help?
Offline fanpeople
Re: my mate spilled some pepsi on his keyboard (membrane)
« Reply #1 on: Sat, 17 October 2015, 01:01:17 »
Similar event occurred with me except it was my wife spilling beer on my rubber dome. The solution was to go searching for a new keyboard and end up on this forum with an SSK and HHKB.
« Reply #2 on: Sat, 17 October 2015, 01:14:52 »
well he cant really do that since he doesn't currently wanna drop 100+ dollars on a keyboard i just want a way to make it stop or make it better some way
Offline fanpeople
« Reply #3 on: Sat, 17 October 2015, 01:19:39 »
If it was me I would not have tried using the keyboard straight away. I would open it up and wipe, clean and then dry the parts for a few days. Then reassemble when you are sure that the keyboard's internals are dry. Much like what you could do with older mobile phones.
Offline tararais
  • Forum Justice Warrior
« Reply #4 on: Sat, 17 October 2015, 02:11:08 »
It's a rubber dome, just buy a new one.
Offline Belfong
« Reply #5 on: Sat, 17 October 2015, 03:45:25 »
Yeah. Probably cost $5. Nothing to discuss here in a mech keyboard forum.
Offline beehatch
  • baehatch
« Reply #6 on: Sat, 17 October 2015, 03:54:31 »
toss it in the trash
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Sat, 17 October 2015, 04:44:50 »
Like everyone else said, just throw it away.
Go to a thrift shop and get a better keyboard for $2.
« Reply #8 on: Sat, 17 October 2015, 05:05:27 »
where does it say no membrane talk?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #9 on: Sat, 17 October 2015, 05:09:29 »
It is fine to discuss membranes. But obvious solution is obvious. It isn't worth trying to fix. A bottle of rubbing alcohol is $2.15ish, plus paper towels, qtips, TIME, etc. New kb is cheaper.
« Reply #10 on: Sat, 17 October 2015, 05:12:04 »
he lives far out of town, so i just wanna see if there were any solutions to it.
Offline fanpeople
« Reply #11 on: Sat, 17 October 2015, 05:21:28 »
"A bottle of rubbing alcohol, plus paper towels, qtips, TIME, etc." this is the solution, but it is not guaranteed to work.
Offline BrewCaps
« Reply #12 on: Sat, 17 October 2015, 09:59:49 »
Toss in the dishwasher.
« Reply #13 on: Sun, 18 October 2015, 02:41:05 »
It does indeed say membrane in the forum description - and scissor.  And laser :))
For a membrane keyboard, I wouldn't waste time trying to clean it.  Unless it is a really top quality keyboard, you'll spend a lot of time disassembling it, cleaning it, putting it back together, and maybe it will work, maybe it will still have problems.
If this is a situation that could arise again, one trick is to buy a couple of keyboards at the same time.  Most membrane keyboards are nowhere near the price of a mechanical keyboard, so this is usually a viable option.
I have had many PCs over the years, and each one came with a membrane keyboard.  I kept a lot of them long after the computers died, but I ended up throwing a couple of dozen out (while still keeping a few lying around just in case, although now I have a small mechanical keyboard collection that I use exclusively).
