Author Topic: Kkmoon anyone?  (Read 4834 times)
Offline TalkingTree
    • My projects
Kkmoon anyone?
« on: Fri, 23 October 2015, 07:04:16 »
Has anyone ever heardof Kkmoon mechanical keyboards?
There are two variants on eBay, one TKL and one fullsize.
The TKL's case seems ideal for a paintjob.
Offline Data
Re: Kkmoon anyone?
« Reply #1 on: Fri, 23 October 2015, 07:30:14 »
Those look like partially re-badged E-Element keyboards.  They're available on Massdrop periodically.
I have an RGB fullsize similar to the one you linked, with an identical wrist rest and the same eagle head logo.
Offline TalkingTree
    • My projects
Re: Kkmoon anyone?
« Reply #2 on: Fri, 23 October 2015, 08:47:50 »
More than partially by the look of internet pictures.
Is that any good?
Offline Data
Re: Kkmoon anyone?
« Reply #3 on: Fri, 23 October 2015, 09:55:40 »
Is that any good?
It's decent.  I like the backlighting a lot.  The board was so inexpensive I bought 2.  Still think I got my money's worth, but I don't have a lot of typing time on either of them so I can't speak to their long-term quality.
Offline TalkingTree
    • My projects
Re: Kkmoon anyone?
« Reply #4 on: Fri, 23 October 2015, 10:35:48 »
Gotcha, thanks.
Offline mmm
Re: Kkmoon anyone?
« Reply #5 on: Thu, 25 February 2016, 18:06:43 »
It's decent
I disagree. See my short review:
https://geekhack.org/index.php?topic=80008.msg2072653#msg2072653
Some KB\'s I have: White PLU ML87, black PLU ML87, Chicony KB5181 TDC3100061, fullsized Lexmark/IBM.
