Author Topic: hello friends  (Read 1526 times)
Offline mkoop
hello friends
« on: Sat, 24 October 2015, 16:53:14 »
Hello everyone,
Glad to be here.
I just ordered a HHKB pro2 that should arrive Monday.  I have been using primarily Filco TKLs (blue at home, brown at work) for the better part of the last 5 years.  I also picked up a Ducky TKL a few years ago, though it doesn't see much use.
Anyhow the HHKB key layout intrigued me so I decided to try it out.  Seeing as the options for keycaps are more limited I thought it would be a good idea to start looking into artisan / dye options around here.
Offline njbair
    • nickbair.net
Re: hello friends
« Reply #1 on: Sat, 24 October 2015, 18:43:41 »
Welcome. You may be interested to know that there are some MX-compatible Topre sliders bring produced by JTK, which Ctrl-Alt should be selling online soon. That should help open up your HHKB keycap options, although the 6u spacebar will still be kind of hard to find.
My boards:
Re: hello friends
« Reply #2 on: Sat, 24 October 2015, 23:25:05 »
Welcome to Geekhack!
HHKB master race :p (says the HHKB Hapster).
If you haven't seen it, Matt3o is designing a new Topre keycap set that will apparently have HHKB compatible keys included!
https://geekhack.org/index.php?topic=74413.0
Offline mkoop
Re: hello friends
« Reply #3 on: Sun, 25 October 2015, 10:03:16 »
Some very cool stuff, thanks for the heads up.  I didnt realize how deep the rabbit hole went.
Re: hello friends
« Reply #4 on: Wed, 28 October 2015, 05:00:02 »
Most don't.  I didn't.  A keyboard is just something you type on, or so I thought.  When you really get in to it there are just so many options and accessories it's crazy!
