Author Topic: Keycap Holder(s)  (Read 26322 times)
Offline Glenmael
Keycap Holder(s)
« on: Sat, 24 October 2015, 19:29:41 »
UPDATE:
Interest check here; https://geekhack.org/index.php?topic=76826.0
Greetings fellow Hack-ians!
I recently received a package from MassDrop and was surprised that it came with a little board holding all the keycaps in place nicely, picture of said board (green in color) is below:
Does anyone have any idea if you can purchase these? If so from who!?
Ps. No idea if this was posted in the correct section :3
PPs. Not at home at the moment, but can certainly take pictures of the one I received when I'm back from work in a week or so.
« Last Edit: Mon, 09 November 2015, 22:08:30 by Glenmael »
Offline WolfTickets
Re: Keycap Holder(s)
« Reply #1 on: Sat, 24 October 2015, 20:01:25 »
How are the caps mounted?  Are the stems attached or does the holder have square cut-outs for the bottom of the keys?
Offline Glenmael
« Reply #2 on: Sat, 24 October 2015, 23:09:34 »
The stems (MX is this case) are attached to the board (?) and cannot be moved/changed, it's literally a keyboard without the electronics :D
« Reply #3 on: Sat, 24 October 2015, 23:18:03 »
You can buy something similar on taobao.
Offline Glenmael
« Reply #4 on: Sun, 25 October 2015, 02:00:38 »
Linky?
I think NKPC do these ones for MD
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #5 on: Sun, 25 October 2015, 02:21:59 »
You just need some more boards to hold caps :D
Offline Glenmael
« Reply #6 on: Sun, 25 October 2015, 05:57:50 »
Hehe, my thoughts exactly  ;D
Offline Jhonan
  • Chicks love duck pics...
« Reply #7 on: Sun, 25 October 2015, 14:06:04 »
I've been thinking about a shadowbox with foam in it to support the caps toward the glass to hang on the wall behind my monitors myself.
Offline Glenmael
« Reply #8 on: Sun, 25 October 2015, 18:22:33 »
This will be a custom/one off project no doubt?
Offline Jhonan
« Reply #9 on: Sun, 25 October 2015, 18:25:37 »
Most likely at first, have to get a good concept down first :)
Offline bjb39
« Reply #10 on: Sun, 25 October 2015, 20:55:28 »
Do you mean the cardboard with holes cut out for the caps? I ordered some KeyCool Gradients from MassDrop and received something like that. It didn't travel very well, and the keycaps were all kind of at the bottom of the box, which was really unfortunate for trying to get the gradient to look right (I still move keycaps around on it from time to time).
Offline Glenmael
« Reply #11 on: Mon, 26 October 2015, 02:46:02 »
Not at all, this is an actual board (plastic) with MX stems that the caps fit into very nicely.
 :thumb:
Offline bjb39
« Reply #12 on: Mon, 26 October 2015, 07:09:07 »
Ohhh that sounds a lot better!
Offline SploogeFactory
  • Vitamin D deficient
« Reply #13 on: Mon, 26 October 2015, 07:12:37 »
Weird, the last keycools I bought had the caps in a big plastic bag with individual key rows holding them in place, this thread has got me keen for that board mount though.
Methylated Spirits, not even once.
Offline CaplockJack
« Reply #14 on: Mon, 26 October 2015, 13:13:13 »
Does it hold Topre too?  Got a better pic of blank board?
« Reply #15 on: Mon, 26 October 2015, 13:17:37 »
No
It basically looks like this
https://geekhack.org/index.php?topic=60045.msg1382018#msg1382018
Offline mogo
« Reply #16 on: Mon, 26 October 2015, 13:22:02 »
This looks like the perfect job for a 3D printer. Can't wait to play with this concept once I get my Tiko in a couple months.
Offline fliptrik
« Reply #17 on: Mon, 26 October 2015, 13:22:43 »
No
That's super nice. I wish there was a grid layout one that I could display artisians on.
Offline Glenmael
« Reply #18 on: Mon, 26 October 2015, 18:08:08 »
Nope, although that would be cool/handy/necessary!
I can take a few pictures this weekend if you are interested.
Offline Glenmael
« Reply #19 on: Mon, 26 October 2015, 18:30:53 »
No
That's the one!
Any luck on that link?
« Reply #20 on: Mon, 26 October 2015, 18:32:32 »
No
That's the one!
The proxy I used doesn't show the order anymore. If I find it I'll post it.
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #21 on: Mon, 26 October 2015, 18:59:55 »
Currently in the process of designing one now. Printed the first stem, came out a little weird.
I can probably have the STL's up tonight, if anyone wants to print them.
Also, if anyone has the exact size of the stems, will they post? I don't have any calipers, and after google and my own measurements, I haven't been able to get the exact measurements
Offline Glenmael
« Reply #22 on: Mon, 26 October 2015, 20:13:45 »
No
That's the one!
Awesome. Thanks  :)
Offline Glenmael
« Reply #23 on: Mon, 26 October 2015, 20:25:41 »
Keycools are a bit different, I also got mine in a plastic bag. These NKPC rainbows (currently on MD) have the board.
« Last Edit: Mon, 26 October 2015, 22:10:53 by Glenmael »
Offline alexjd99
« Reply #24 on: Mon, 26 October 2015, 20:26:57 »
I have it uploaded to Thingiverse now. http://www.thingiverse.com/thing:1094451
Mostly for artisans, since most printers can't print something the size of a 100% board :P
« Reply #25 on: Mon, 26 October 2015, 20:47:08 »
Keycools are a bit different, I also got mine on a plastic bag. These NKPC rainbows (currently on MD) have the board.
That's pretty coincidental, I am in that drop! Wooo.
Offline Butter
« Reply #26 on: Mon, 26 October 2015, 21:35:59 »
If they make one with tkl then I can stop buying keyboard to hold my keycaps :p
Offline Glenmael
« Reply #27 on: Mon, 26 October 2015, 22:22:24 »
Nice!
You should '+1' my comment which says something along the lines of 'where do we get these boards from/can we get a seperate drop for these'. :D
« Reply #28 on: Mon, 26 October 2015, 22:32:50 »
Nice!
Mizz? Done.
Offline Glenmael
« Reply #29 on: Mon, 26 October 2015, 23:18:50 »
Nice!
Mizz? Done.
You got it! cheers.
Offline Glenmael
« Reply #30 on: Sun, 08 November 2015, 03:28:19 »
Hey guys,
Here are some updated pictures.
Let me know what you think, I'll probably just go ahead and setup a Poll on MD as that is what they have informed me to do.
« Reply #31 on: Sun, 08 November 2015, 03:32:31 »
Yeah man, it's cool. Got any idea on the price?
I'm gonna have one of these in a few weeks from another keycap set but it would be heaps more convenient for storage of all the others and keeping them in order!
Offline rm-rf
« Reply #32 on: Sun, 08 November 2015, 03:33:08 »
if these get sourced. I need some.
Offline Glenmael
« Reply #33 on: Sun, 08 November 2015, 03:49:19 »
No idea on price :( unfortuantely I havn't been able to engage the Massdrop folks as much as I would like on this. The best way is to make sure we hit some sort of high interest check numbers so the manufacturer has some idea of how serious we are :)
 :thumb:
Posted on MD; https://www.massdrop.com/vote/Keycap-Holders
Will post in IC sub-forum as well :)
Offline zslane
« Reply #34 on: Sun, 08 November 2015, 12:16:53 »
I voted for it on MD just now. I could really use a bunch of these.
I could also use a similar holder that is just a 10 x 6 grid (for keyset extras).
Offline 3K
« Reply #35 on: Sun, 08 November 2015, 12:27:03 »
Just voted too. Could use some, for WKL too  :)
Offline SamirD
« Reply #36 on: Mon, 09 November 2015, 19:42:33 »
This is a neat concept.  I was thinking it would be neat to have an 'artisan display' that had multi height 'pedestals' for the individual keys--something that held 8-10 of them.  Or I could be completely off here as I don't own a single artisan...
« Reply #37 on: Mon, 09 November 2015, 19:58:36 »
Glenmael gonna need this keycap holder for all the KRAP keys that he got the other day!
Offline Glenmael
« Reply #38 on: Mon, 09 November 2015, 20:07:17 »
w00tw00t :D
Offline Glenmael
« Reply #39 on: Mon, 09 November 2015, 22:09:07 »
Updated with Interest Check information.
Can lock this thread if you wish :)
Offline shibataken
« Reply #40 on: Tue, 10 November 2015, 13:54:53 »
Would be perfect if they were stackable, does something like that exist for those of us with limited space ie NYC apartments
Offline mogo
« Reply #41 on: Tue, 10 November 2015, 14:06:50 »
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=us104_case
Offline zslane
« Reply #42 on: Tue, 10 November 2015, 14:20:50 »
Those would be great if they were, you know, in stock...
« Reply #43 on: Tue, 10 November 2015, 14:21:21 »
These haven't been in stock in neons.
Offline MeltingTeeth
« Reply #44 on: Tue, 10 November 2015, 15:38:24 »
Eons.
Unless you meant more colorful ones.
Offline Glenmael
« Reply #45 on: Tue, 10 November 2015, 15:49:14 »
Eons.
Ok I lol'd :D
or maybe negative-eons!
« Reply #46 on: Tue, 10 November 2015, 16:06:36 »
Eons.
I most certainly meant "neons."  ;)
Offline mogo
« Reply #47 on: Tue, 10 November 2015, 16:50:51 »
Whoops. I didn't notice they were out of stock. Sorry about that   :-X
Offline SamirD
« Reply #48 on: Tue, 10 November 2015, 22:55:18 »
These looks so cheap compared to the nice board style in the first post.  But having a cover is nice too.
Offline zslane
« Reply #49 on: Tue, 10 November 2015, 23:25:23 »
I suppose if it came in a box then it would not only have a cover, it would have an entire enclosure which would be stackable, though they'd take up more space vertically than the clamshell design. It would also be considerably more expensive than $6.
I want something to organize and store my extra keycap sets, not something to display them like jewelry. The $6 clamshell is more practical for my needs, but I might get one of the first kind just to try it out.
