Author Topic: Gateron Clear keyboards - What are my options?  (Read 7426 times)
Offline getf
  • In Rod We Trust
« on: Sun, 25 October 2015, 21:23:20 »
I'm looking for a board that comes from the factory with Gateron Clear switches.
So far I've only been able to come across https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1447
A V60 from mk.com
I've heard that Cherry is introducing a linear RGB backlit switch, which is kind of exciting as well, just hoping its as light as the 35g activation point of Gat Clears.
Are there any other boards that I've missed?
Offline Harms
Re: Gateron Clear keyboards - What are my options?
« Reply #1 on: Sun, 25 October 2015, 22:55:03 »
I'm looking for a Standard TKL version myself, no luck though :(
Offline diqkiq
« Reply #2 on: Sun, 25 October 2015, 23:56:14 »
Varmilo va87m. Massdrop has a buy running atm.
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
Offline getf
  • In Rod We Trust
« Reply #3 on: Mon, 26 October 2015, 11:30:33 »
I have the same board in with Gateron Reds, trying to find something without floating keys! :)
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #4 on: Tue, 27 October 2015, 02:48:00 »
Not sure if you're into Ergodoxes, but Falbatech can make them with Gateron Clears
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline azhdar
  • Praise the AZERTY god
« Reply #6 on: Tue, 27 October 2015, 16:58:48 »
Just to be sure, you know that gateron clears are 35g linears?
Azerty Propagandiste
Offline allthumbs
« Reply #7 on: Wed, 28 October 2015, 13:39:58 »
I had the same question. So far we have
  • noppoo choc mini 84
  • Ergodoxes by Falbatech -- although currently I don't see a choice for Gateron Clears .... just Blues and Blacks...
  • Varmilo va87m
  • a V60 from mk.com
Any more?
« Last Edit: Wed, 28 October 2015, 13:44:47 by allthumbs »
Offline meevilsheep
« Reply #8 on: Wed, 28 October 2015, 16:39:43 »
A V60 from mk.com
This is the thread where you can see  that those new switches are between Reds and Blacks as force, about 55g.
https://geekhack.org/index.php?topic=76240.0
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
« Reply #9 on: Wed, 28 October 2015, 16:55:06 »
Can't imagine going lighter than MX Reds, I gotta try these sometime.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
