Author Topic: Home network recommendations?  (Read 1536 times)
Offline trenzafeeds
  • **** off
« on: Mon, 26 October 2015, 11:18:42 »
I want to set up a simple and low-cost home network with a firewall does anyone have recommendations about hardware/operating systems? Right now I'm looking at FreeBSD for the server, but I really want to know how I can do it cheapest.
demik will never leave.
Unless he gets banned.
Offline dgneo
  • Supervillain
Re: Home network recommendations?
« Reply #1 on: Mon, 26 October 2015, 11:20:53 »
https://www.pfsense.org/ is probably your best bet, and not a bad solution either! While I haven't set one up myself, I've a couple of co-workers who've set it up and they swear by it.
Offline trenzafeeds
  • **** off
« Reply #2 on: Mon, 26 October 2015, 11:23:26 »
Looks pretty good. Does it ship with a VPN daemon? If not I'll most likely just use tinc with it. Should work ok.
« Reply #3 on: Tue, 27 October 2015, 04:56:28 »
I had some success with Untangle at work.
http://www.untangle.com/
