Author Topic: What are these??? F-122s with ps/2 connectors??  (Read 3327 times)
Offline Janeiac
Offline jonathanyu
Re: What are these??? F-122s with ps/2 connectors??
« Reply #1 on: Wed, 28 October 2015, 20:27:26 »
iirc, these are model m
Offline SamirD
« Reply #2 on: Wed, 28 October 2015, 20:31:57 »
Model M?  Are they not f122?  I'm confused. :(
« Reply #3 on: Wed, 28 October 2015, 20:45:40 »
Odd.  The cable is coming out of the case in a different place to other F122s.
« Reply #4 on: Wed, 28 October 2015, 21:11:18 »
The 139xxxx are Model M numbers.
There were some PS/2 Model Ms that were programmable and nice. This is a good price if they really are new.
- D Trump 2026-10-24
Offline SamirD
« Reply #5 on: Wed, 28 October 2015, 21:17:50 »
Looks so pretty....
« Reply #6 on: Thu, 29 October 2015, 01:13:42 »
Unless people have really started looking, it seems like there's an insane number of these suddenly appearing.
In a couple of month's time everyone will bemoan not having bought one of these when they were available.
Offline faycheung
  • Noob
« Reply #7 on: Thu, 29 October 2015, 01:21:22 »
M122s are plenty, F122s not so much. Rumour has it there's about to be about 100 or so F122s coming out after Cindy sorts things out on DT (shhhhh).
Offline ander
  • I type, therefore I am
« Reply #8 on: Thu, 29 October 2015, 01:49:24 »
http://pages.ebay.com/link/?nav=item.view&alt=web&id=181724065198&globalID=EBAY-US
I can't find details anywhere on these particular part numbers, but the 139* format does indeed indicate they're Model M's. So I'd say these are M's that were made, for some reason, to resemble Model F's, with stepped modifier keys rather than M-style flat ones.
Unfortunately the seller included no photos of the backs, the only definite way to ID them. (Plastic = M, metal = F, plus they'd probably have labels that said "Model M" or "Model F".)
I wrote the seller and asked if they could send me a back photo or just tell me what the backs said, but they never replied. I don't know if they're too busy, or if they don't consider it worthwhile, or if they're actually trying to pass these off as F's. However, they knew they were 122-key boards, and they included all the info except whether they were M's or F's, so I'll let you draw your own conclusions.
Offline Tactile
« Reply #9 on: Thu, 29 October 2015, 02:05:52 »
I bought one. It's an unusual Model M.
We talked about it here...
https://geekhack.org/index.php?topic=73274.msg1790309#msg1790309
REΛLFORCE
Offline ander
« Reply #10 on: Thu, 29 October 2015, 02:27:07 »
Oh, ha ha, I thought this was that thread.
Plus, of course, these are PS/2, which no Model F would be—so, duh.  :?)
Offline SamirD
« Reply #11 on: Thu, 29 October 2015, 10:03:39 »
Yep, that thread definitely helps a lot!  I think I want one.  I'm sure I could definitely use it as a daily driver.
Offline ander
« Reply #12 on: Sat, 31 October 2015, 05:09:35 »
Well, I dunno... They are unusual boards, but if they're just M's, I don't see what the advantage would be of having the F-style stepped keys. Some people even complain about those here. If they were actually F's, it would be worth the trouble, considering how vastly superior F's are to M's. Okay, I'm just typing that in case Snowdog sees it, so I can get him going.  :?)
Offline SamirD
« Reply #13 on: Sat, 31 October 2015, 10:22:56 »
I'm not a fan of the stepped keys, but it would be something different and intimidating, mwah ha ha ha.
Offline njbair
    • nickbair.net
« Reply #14 on: Sat, 31 October 2015, 11:14:21 »
The Model F feels nicer, but comes with its own compromises. It will be unquestionably superior to the M in every way, if and only if one is produced in a full-size and/or TKL ANSI layout that can be cheaply and easily connected to a modern computer.
My boards:
Offline SamirD
« Reply #15 on: Sat, 31 October 2015, 12:10:43 »
if and only if
The last time I saw this phrase was in mathematical theorums in college, lol.
