Author Topic: key unresponsive  (Read 1613 times)
Offline kage88
key unresponsive
« on: Sat, 31 October 2015, 00:18:18 »
i am using Ducky shine 3 snake edition
my problem is my "w" key sometimes not responsive
i.e i pressed 10 times, only 8 registered or sometimes its registered 2 times
Offline Bucake
Re: key unresponsive
« Reply #1 on: Sun, 01 November 2015, 08:14:06 »
have you dropped any liquid in there, by any chance?
Offline tronbeaver
« Reply #2 on: Sun, 01 November 2015, 09:33:01 »
You might have to buy a new switch and solder it in.
Offline Kad
  • Δ E S T H E T I C S
« Reply #3 on: Sun, 01 November 2015, 13:15:08 »
If you're comfortable with it I would recommend taking that particular switch apart and putting it back together to see if maybe some dirt or other particle is doing something odd in there. You may need to just replace the switch altogether but this is a good first step before going to all that trouble.
[WASD v2 w/ MX Blues]
