Author Topic: What's the worst keyboard you've ever bought? Warnings for keyboard buyers.  (Read 27629 times)
Offline ideus
  • Björkö.
Please report your bad experiences with keyboard, or keyboard parts and accessories. It may help on warning other keyboard buyers about common defects or limitations in the hardware, controllers, software or reliability of particular keyboard models. Please try to be specific, and provide details on serial part numbers, models, year of release or iteration, to allow others get your feedback for potential buys.
All comments are welcome in any form; but, if you want to collaborate making the list simpler to navigate provide:
Brand
Model
Serial
Problem description
« Last Edit: Mon, 02 November 2015, 08:47:17 by ideus »
Offline getf
  • In Rod We Trust
Re: What's the worst keyboard you've ever bought? Warnings for keyboard buyers.
« Reply #1 on: Mon, 02 November 2015, 09:38:00 »
I mentioned this one in another thread - but It could use as a word of warning to others
Royal Glam Wrist Hardwood Wrist rest - https://www.massdrop.com/buy/hardwood-wrist-rests
Pros: is a wooden wrist rest
Cons: Gave me splinters in my wrist due to the roughness of the sanding
the included rubber feet did not hold the wrist rest steady on my desktop (not enough friction - caused wrist rest to slide about )
Dell At101W - http://deskthority.net/wiki/Dell_AT101
Models with Alps SKCM Black Switches
A lot of people try this board because it is a very cheap entry level board to experience ALPS type switches.
However I have never found a at101w with black sliders that feels pleasant to type on.  Every one I have had or used had very mushy and sloppy feeling switches.  Thanks to Matias and KBP there are some other great entry level alps boards available nowadays.
« Last Edit: Tue, 08 December 2015, 19:14:01 by getf »
Offline daerid
    • Rossipedia
« Reply #2 on: Mon, 02 November 2015, 10:04:54 »
Ducky 1087 xm (the one w/ black alps).
Holy crap what a piece of s**t.
« Reply #3 on: Mon, 02 November 2015, 10:06:10 »
HA I was going to say that too. Worst keyboard I've ever owned. The Alps clones that were in that, the black and green ones, were absolute garbage.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Mon, 02 November 2015, 10:12:26 »
Wasn't it like $35 on sale? And people still so mad. It truly must've been the worst. Hah.
« Reply #5 on: Mon, 02 November 2015, 10:14:35 »
I picked it up for $30 and I regret it dearly. There was no good qualities about that board at all. Horrible quality case, a cheap and easily bent plate, a stupid keyboard cover instead of a case top, awfully printed and thin pad-printed caps, and a flimsy PCB. It even smelled horrible.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Mon, 02 November 2015, 10:15:13 »
Smell MUST be added to all keyboard reviews in the future.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #7 on: Mon, 02 November 2015, 10:20:10 »
The most disappointed I've ever been in a keyboard was the Pok3r I bought. The QC was terrible. The damn plate is bigger than the PCB! It doesn't fit in any aftermarket case because of it. Like a dumbass I jammed it in a case to prove a point to someone, and couldn't get it out. I ended up bending the (flimsy) plate in the process of removing it. And I don't know why the hell they had to move the arrow keys away from WASD. I do like the MX Greens though. And that is the main reason I bought it.
Also I bought a WASD CODE with MX Clears and it pings so loudly it is pretty much unusable. I could open it up and work on silencing it, but I don't use full size anymore. Plus I'm lazy as hell.
Both smelled fine though.  ;)
Offline engicoder
« Reply #8 on: Mon, 02 November 2015, 10:24:36 »
I've picked up a couple older boards that absolutely reeked. One smelled of diesel fuel. I don't mind the smell, but it was very strong. Even after thoroughly cleaning the board with warm soapy water, the case still smells of diesel if you give it a whiff. I think it permeated the plastic, if that is possible.
I had another that smelled like cat pee. It cleaned up fine...go figure.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #9 on: Mon, 02 November 2015, 10:50:24 »
Beware of eBay sellers that have Model M keyboards that are pretty much thrashed.
My story is of an M13 Trackpoint II that was so bad, that I considered throwing it in the trash and forgetting about it.
When it arrived, I was shocked at how awful the keyboard felt to type on, even after cleaning it up.
I knew I needed to get a new cord for it, and ordered that around the same time I got it.
This is the original cable.
Anyway, after cleaning it up to the best of my ability, replacing the cord with a new one...
Most of the inside was full of RUST on the components.
A good example is the mouse PS/2 pass-through port....
This is what it looked like after getting it as clean as I could get it....
Of course the Trackpoint buttons would not respond at all, but the pointer did!  *sigh*
I was at a point of being so frustrated with how it felt, that I knew it needed very serious help.  The keys felt awful!  The absolute worst feel of any BS keyboard I ever had!
I knew that I could just throw it away, and be done with it.  But something inside me felt that it would be better to have someone more experienced than me that could fix it.
So I decided to get in touch with Maxx at Phosphorglow.
Long story short, the keyboard was run through a cycle on a dishwasher.  Definitely not a thing to do with a Model M.  It rusted the springs and the membrane needed to be replaced as well as the blanket.
http://phosphorglow.net/2015/05/27/130/
Maxx literally had to rebuild the keyboard! He also fabricated new buttons for the Trackpoint.  Once that was done, he also put the new mylar copper underlay.
It turned out to be a great decision.  The keyboard is splendid now!
It was the best decision I made!  I was very apprehensive because he turned that keyboard into what it originally was meant to be!  Instead of looking good on a display case, it is actually usable and I am proud to have it!
So maybe it was the worst keyboard I ever bought.  I'm glad I made my decision with it.
« Last Edit: Mon, 02 November 2015, 10:52:08 by Snowdog993 »
Offline osi
« Reply #10 on: Mon, 02 November 2015, 11:17:43 »
+1
Offline GL1TCH3D
« Reply #11 on: Mon, 02 November 2015, 11:25:56 »
Brand: Razer
Model: Blackwidow Ultimate 2014 - Razer Greens
Serial: Didn't pay attention
Reason: Self explanatory and in my review but a quick recap
Everything sucked.
Offline Wannabe
  • Independent Adjudicator
« Reply #12 on: Mon, 02 November 2015, 11:46:51 »
I have the full sized version of this with Ducky's Green Alps clone. Definitely my worst mechanical keyboard purchase (though definitely cheapest). Everything about the keyboard screams cheap, especially the incessant rattling while typing.
I liek keyboards
Offline zlittell
    • My Projects
« Reply #13 on: Mon, 02 November 2015, 11:48:29 »
I haven't purchased a lot of keyboards so far, but my 710 takes the cake.  I swear to god if I break another ****ing keycap on this thing I am going to find the logitech CEO and smash this thing over his head.  I just haven't picked out a new set for it yet.  Shouldn't have to though.
Offline Snarfangel
« Reply #14 on: Mon, 02 November 2015, 11:48:40 »
That's the new keyboard smell. Some people pay good money for that.
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #15 on: Mon, 02 November 2015, 11:55:31 »
Offline Tactile
« Reply #16 on: Mon, 02 November 2015, 12:28:46 »
A Cherry model whatever with Cherry MY switches. It's the only working keyboard I've ever thrown away - I didn't even save the keycaps.
REΛLFORCE
Offline Lepidus
« Reply #17 on: Mon, 02 November 2015, 12:58:58 »
Beltron TK-M501C
It uses Ya Sheng buckling springs (http://deskthority.net/photos-f62/buckling-springs-can-5001cw-t2043.html), that is something like a cheap chinese IBM buckling spring copy.
The feel wasnt that bad actually, but switch inconsistency was a pain in the ass. Some would click very loud, some would just do a cherry blue click, some wouldnt click at all.
But the worst part was the Ping. Holy ****, cherry clear ping or model m ping are nothing near this board's ping.
In the end I couldn't even use the keyboard, as I was getting lots of double keypresses (like chattering) on pretty much every key if I did not bottom out hard when typing. Never discovered if it was a controller issue, or just a "switch" design flaw.
I still have it around, its a cool keyboard to have at least.
Mod Edit: Reuploaded images to imgur because of reports of images being blocked by antivirus programs.
« Last Edit: Mon, 16 November 2015, 23:49:42 by infiniti »
Offline BucklingSpring
« Reply #18 on: Mon, 02 November 2015, 14:29:45 »
Anything from iOne itself or rebranded (ie XArmor)
Boards I own, click ->
Offline keyboardia1
« Reply #19 on: Mon, 02 November 2015, 14:46:40 »
my Royal Glam Wrist rest is actually okay. I don't even have a problem with the rubber feet.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #20 on: Mon, 02 November 2015, 15:06:08 »
Amstrad PCW keyboard, models 8256, 8512, and 9512.
Not sure how anyone is going to beat that xD .
Offline FoxWolf1
  • 154
« Reply #21 on: Mon, 02 November 2015, 15:49:07 »
^ My worst mechanical purchase as well, but not my cheapest or even my second cheapest (second cheapest goes to my Model M thanks to used stuff being cheap, and first cheapest goes to a MicroConnectors D07-135, which was $15. If I had the choice between the MicroConnectors keyboard and the Ducky at the same price, I'd take the MicroConnectors).
If you've ever wanted to find a mechanical keyboard that's both worse-built and worse to type on than your typical rubber dome, a Ducky 1008XM will end your search. Its only upside is that it doesn't last very long, so you'll soon be able to move on to something better.
Offline davkol
  •  Post Editing Timeout
« Reply #22 on: Mon, 02 November 2015, 16:00:56 »
I doubt anyone here would deliberately buy it, but for random visitors from search engines: Tesoro Colada. It's an ordinary backlit "gaming" keyboard, with typical horrible soldering on the PCB… and to make things worse, a poorly insulated controller under an aluminium cover, because aluminium is the hype, right? Anyway, the controller was obviously fried, due to the basically non-existent insulation.
Offline ideus
  • Björkö.
« Reply #23 on: Mon, 02 November 2015, 16:42:29 »
thrashette's Noob struggling with chattering/unresponsive keys on new Filco.
Offline mszy52
« Reply #24 on: Mon, 02 November 2015, 16:59:22 »
First mech i bought was an off brand kailh red switch on a e-3lue k272 board i got on massdrop for $65. Not the worst board but its stated as "rgb" when the rows have set led's in them. The feel of the board is not terrible but i finally upgraded to a corsair strafe with Brown's and i would never go back
Offline swimmingbird
  • keyset hoarder
« Reply #25 on: Mon, 02 November 2015, 17:03:48 »
Just got my KC60 and it feels like the most rattly thing ever.
Coming from an HHKB and Gon though I probably have my expectations set way too high
Offline alexjd99
« Reply #26 on: Mon, 02 November 2015, 17:27:29 »
Still waiting on my KC60.
Is it worth waiting for, or should I just cancel now while I still can?
  • keyset hoarder
« Reply #27 on: Mon, 02 November 2015, 17:28:53 »
I don't wanna make the call just yet - I'm gonna solder in zealios tomorrow and put gmk on it and see how it goes
Offline ideus
  • Björkö.
« Reply #28 on: Mon, 02 November 2015, 17:49:02 »
Just be aware of the other Zealios issue.
  • keyset hoarder
« Reply #29 on: Mon, 02 November 2015, 17:51:42 »
Yeah just saw that - wasn't expecting that - how many people have reported it so far?
Offline ideus
  • Björkö.
« Reply #30 on: Mon, 02 November 2015, 17:54:12 »
I dunno, but parts with the defect appears to be over 10% in some cases.
  • keyset hoarder
« Reply #31 on: Mon, 02 November 2015, 17:55:31 »
Is it something that can be tested for with a multimeter or is chatter a problem that is intermittent?
Offline ideus
  • Björkö.
« Reply #32 on: Mon, 02 November 2015, 17:59:59 »
It appears to be related with the plastic's melting point of the transparent base used in the switches, that can be reached when they are soldered, therefore, I think that even if the switches can be tested before hand, they may turn defective after they were installed. I am planning to use some bottoms I have from Cherry and original Gaterons that do no have the issue along with stems and springs from Zealios. I know it is not the more elegant solution, but I do not want to be soldering them many times.
Offline oxchamballs
« Reply #33 on: Mon, 02 November 2015, 18:08:15 »
The Ducky 1008XM was my first mechanical keyboard. The switches felt weird, the keycaps were cheap, and it had a crap ton of cold solder joints. In fact it was so awful, I pretty much found out about this as a hobby, while trying to look for repair guides, lol.
Offline SamirD
« Reply #34 on: Mon, 02 November 2015, 18:08:45 »
Beltron TK-M501C
Interesting board!  Thank you for sharing!
That bad?  I played with a 710 and I thought it was pretty solid.  Have you felt the 710+?  Does it seem like it will be any better?
« Last Edit: Mon, 16 November 2015, 23:51:12 by infiniti »
Offline zlittell
    • My Projects
« Reply #35 on: Mon, 02 November 2015, 22:38:06 »
I actually have a g710+ whoops!  But yeah every so often I just split the part that holds a keycap onto the mx stem.  It just literally breaks half of it off clean and then the cap won't stay on.  Its a hefty ass keyboard so thats not a problem.  Just the keycap set is horrible.  Even keys I don't use as much.  Its more about position from home row.  Function keys break because of the side pressure put on them.  Keys like that.  I have a feeling they will go on clearance for $50ish eventually and that will be a steal.  Snatch em up and put a new set of keys on them.
Offline umeboshi
« Reply #36 on: Tue, 03 November 2015, 00:51:47 »
Apple A1048, the one with the clear case.  Keys feel bad even for a rubber dome, and collects and displays all your trapped hairs and epithelials...
Offline ANightOnCloudNine
« Reply #37 on: Tue, 03 November 2015, 01:49:01 »
Razer deathstalker, **** this ****.
Offline Bartlebum
  • Addict.
« Reply #38 on: Tue, 03 November 2015, 02:17:43 »
Logitech keyboards with that stupid screen on them. Paid through the nose for it, it was absolute **** to use, and didn't even give you relevant info. Worst purchase ever.
Honorable mention: OG Razer Blackwidow
Razer | HHKB | Pok3r | GON
Offline gadzkun
« Reply #39 on: Tue, 03 November 2015, 03:04:43 »
for me razer black*****
reason is...
story starts when im buying a new keycaps for my lovely widow
im trying to pull my old keycaps but then something happen.......
its terrible accident! i said its an accident i swear....
the moment i pulled the caps....
the stem switch got pulled too.... GYAAAA!
what a horrible nightmare i had that day..
Offline hudson0804
« Reply #40 on: Tue, 03 November 2015, 03:26:41 »
Microsoft sidwinder X6
Reason.
Its a POS that broke twice (warranty replacement) within 10 months.
I ultimately rage faced and smashed it to pieces..
Offline SamirD
« Reply #41 on: Tue, 03 November 2015, 11:53:19 »
The Razer Blackwidows seem to be on the hate list fairly often.  It's not too often that I see anything nice about them.
Offline SamirD
« Reply #42 on: Tue, 03 November 2015, 11:54:32 »
That's what I'm waiting for.  Even on craigslist people are still wanting more than that.  And you could have gotten one new at Best Buy for $60 when they had their weekend sale that lasted, well, a weekend.
Offline heedpantsnow
  • Old enough to know better
« Reply #43 on: Tue, 03 November 2015, 12:19:13 »
Noppoo Choc Mini. Crappy printing. Chattering. Whenever you put your hands on it the case creaked like an old man's joints on a cold morning.
I'm back.
Offline dante
« Reply #44 on: Tue, 03 November 2015, 13:10:12 »
WYSE PCE 900866-01.  It's a PS/2 board w/ Vintage MX Blacks.  It exhibits the same symptoms of an M2 (lights come on, does nothing) - perhaps this also suffers from crappy capacitors.  I couldn't figure out what was wrong with it.
Several others have had issues with this particular model as well.  There was a model # 900840-01 (AT connector) but haven't tried it nor heard of anyone who owns one.
Offline Seranite
  • Doesn't know what's going on.
« Reply #45 on: Tue, 03 November 2015, 13:13:05 »
I've gotta laugh because someone who sits literally 10 feet from me at work actually has one of these.
As for the Blackwidow, why do these seem to be on everyone's ****list? I've never owned one but I can only assume it's partly because of the brand itself.
Offline SamirD
« Reply #46 on: Tue, 03 November 2015, 13:58:56 »
I tried a razor (not sure if it was the blackwidow at walmart the same day I treid a 710.  Compared to the 710, it was mushy on the bottom, not as crisp at the actuation point, and had more key wobble.  It was kinda the mech equivalent of a bad rubber dome if you can imagine that, lol.  If that's everyone's experience with them, then I can definitely understand the hate.
Offline davkol
« Reply #47 on: Tue, 03 November 2015, 14:14:20 »
  • marketing full of ****
  • bad quality control
  • layout and gimmicks typical for gaming keyboards
Have I mentioned that their marketing is full of ****?
Offline Seranite
« Reply #48 on: Tue, 03 November 2015, 14:18:58 »
That helps paint a clearer picture...but how do you feel about their marketing?
Offline davkol
« Reply #49 on: Tue, 03 November 2015, 14:20:50 »
Agreed, but at the same time, it was one of the best-bang-for-the-buck keyboards at the time.
The infill fades. Truth. But there are still thick POM keycaps under it.
The switches are at least geniune Cherry (or now with the option of gaterons) and I guess I've been lucky that mine haven't really had chattering problems.
The case creaks indeed. Although, compared to some Rapoo junk, there are no half-broken screws, and it's easy to remove the bendy upper case part and leave the plate exposed, unless you're moving the keyboard around a lot.
