Author Topic: Blank keycaps for LED keyboards  (Read 4825 times)
Offline grayilya
« on: Mon, 02 November 2015, 15:43:39 »
Hi GH, Im looking for keycaps to use with the ducky zero shine and maybe reuse it when i buy a ducky shine 5.I was planning on the WASD    keycaps but it looks like the LEDs shine through them instead of having a glow underneath.Any recommendations on what type/where to buy?
Offline Ir0n
Re: Blank keycaps for LED keyboards
« Reply #1 on: Mon, 02 November 2015, 16:27:10 »
Find blank doubleshot pbt keycaps. Light don't shine through those in my experience. Look on amazon, or ebay.
Edit: Actually I don't think I had doubleshot I had just blank black PBT keycaps..
http://www.ebay.com/itm/GeekKeys-Black-Blank-Thick-PBT-Full-Keyset-Cherry-MX-Keycaps-/331632219280?hash=item4d36d21490:g:CCwAAOSw7aBVH1V6
« Last Edit: Mon, 02 November 2015, 16:31:37 by Ir0n »
Offline Oobly
« Reply #2 on: Tue, 03 November 2015, 05:38:16 »
Any thick blanks will do. The darker colours tend to have less bleed-through, but lighter colours will reflect more light so you have more underglow.
All SA profile sets that I've tried block LED light completely, but they're mostly doubleshots, not blank. Some of the BSP, Gateron, Leopold and GMK sets (all thick Cherry profile) block the light well, too.
Signature Plastics DCS and DSA profiles let light through, as do the WASD caps.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline gadzkun
« Reply #3 on: Tue, 03 November 2015, 10:30:33 »
if you like glow underneath i think this is suite you best
https://www.massdrop.com/buy/royal-kludge-doubleshot-abs-keycaps
its thick
and its glow underneath
Offline gadzkun
« Reply #4 on: Tue, 03 November 2015, 10:31:03 »
its thick
and cheap  ;D
Offline Kliwon
« Reply #5 on: Tue, 03 November 2015, 19:30:52 »
Varmillo keycaps can be another alternative as well ..
although oem Profile, it looks good as well when the light glow underneath..
Offline pyrolovesmoney
« Reply #6 on: Tue, 03 November 2015, 20:21:10 »
yeah, you should be good with doubleshot. They also have transparent keys too. I think I saw them not too long ago in blue and black.
Offline slushi
« Reply #7 on: Tue, 03 November 2015, 20:24:36 »
I have some blanks from geekkeys passed on to me from a redditor that I had bought a board from and they work really well. No light leak through the caps. I looked at the price of the set and it was pretty reasonable but then again I am pretty new to the scene.
 HHKB Pro 2
Offline lashiel
« Reply #8 on: Wed, 04 November 2015, 14:30:23 »
its thick
I have a set of these, and am pretty satisfied. Price is right, so to speak.
Though the font is a bit weird.
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
« Reply #9 on: Wed, 04 November 2015, 14:47:58 »
I'm with you on that font thing. I thought about getting a set of the white with green legends but I can't get over the font.
    IBM Model M            Fjell 002           Klippe            KC60           Planck
Offline lashiel
« Reply #10 on: Wed, 04 November 2015, 15:01:52 »
Yeah. I think I can deal with it (it's less weird than the Royal Kludge caps they put on their own boards), but it's definetely... noticeable. The subtle underglow is really cool though.
