Author Topic: [IC]TGR-Jane CE  (Read 81840 times)
Offline yuktsi
  • Colour my life with the chaos of trouble
[IC]TGR-Jane CE
« on: Tue, 03 November 2015, 08:04:28 »
I will share about the my findings from samples made of different aluminum, i.e. Alcoa Mic 6, 6061 and 7075, some comparisons and why I decided to use 7075 for the next batch, some major improvements over the last run (such as the wrapping issues, the gap, the finishing of the brass, etc.), changes in design, price of the kit and delivery period.
The groupbuy should start next week if nothing goes wrong, in order to have the board delivered before Christmas. Stay tuned!
Material selection
from top: 6061, Mic 6, 7075
6061 is one of the most common aluminum alloys used for Korean keyboard, being economical, reasonably high strength and easy to machine. While 7075 does offer a much better mechanical properties compared to 6061, but many do agree that the additional strength is not needed for the usage of mechanical keyboard case. Alcoa Mic 6 on the hand, is best known for its good stress relieving properties, commonly used to machine parts that require high accuracy.
tl;dr
- stregth
7075 > 6061 > Mic 6
- price
Mic 6 >> 7075 > 6061
To determine the aesthetic appeal of different materials, all 3 materials went through the same process of machining, sandblasting and hard anodizing (35 micron). The major differences in the final products are the color and surface smoothness.
- Color
from left: 7075, Mic 6, 6061
- Surface smoothness
7075
6061
Mic 6
Taking aesthetic appeal, price and strength into consideration, 7075 will be used in the next groupbuy.
Improvements
- Gap
It is much more appealing than round 1. Although no one has made a complain about the gap, but it does bother me a lot.
- Brass finishing
mirror finish
normal buffing
electro nickel plating
The brass for CE will be electro nickel plated. I have not decided on what kind surface to go for thought (sandblast or mirror polish)
- wrapping issue
As you can see form the photos, the top part lies flatly even though it is not screwed to the bottom case.
- Anodize color variation
As much as I want a perfect anodize for CE, unfortunately it is not possible. What I can do is only to minimize the color variation.
mic 6 sample. To give you an idea, the above variation in color is not acceptable.
Changes in design
thinner border
the usb hole
this is something i learnt from the OTD board. The mounting point of the plate. The plated is mounted at an very small angle, to reduce the contract surface with the case for maximum "thock"
Specifications:
  • Full aluminum 7075 case
  • 8 degrees slope
  • Electro nickel coated brass weight
  • Plate material: aluminum
  • Support 84 and 86/87 layout
  • ISO and ANSI
  • A87U PCB
  • Fully Programmable
  • Full LED backlighting
  • Controller parts are pre-soldered
  • Only 25 sets
Color options:
Blue grey, pink, black(hard anodize) and olive green(hard anodize)
blue grey
pink. photo by filphil
olive green
Price:
« Last Edit: Wed, 11 November 2015, 20:54:51 by yuktsi »
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline heedpantsnow
  • Old enough to know better
Re: [IC]TGR-Jane CE
« Reply #1 on: Tue, 03 November 2015, 08:05:00 »
Whoa
I'm back.
Offline Malicium
Re: [IC]TGR-Jane CE
« Reply #2 on: Tue, 03 November 2015, 08:06:51 »
Really nice, but I have no money ^^
Offline whmeltonjr
Re: [IC]TGR-Jane CE
« Reply #3 on: Tue, 03 November 2015, 08:07:33 »
Uh, color me interested depending on price. That is a sexy board.  :eek:
Offline clochette
Re: [IC]TGR-Jane CE
« Reply #4 on: Tue, 03 November 2015, 08:23:19 »
would prefer the floating keys...
and a winkey option  :p
Offline tuantruong
Re: [IC]TGR-Jane CE
« Reply #5 on: Tue, 03 November 2015, 08:29:35 »
it isn't about to buy or not to buy, it's about what color you will go with. :p
RIP wallet. :-X
Offline ntitco1
Re: [IC]TGR-Jane CE
« Reply #6 on: Tue, 03 November 2015, 08:32:13 »
Hype
Offline trees
  • I like bagels.
Re: [IC]TGR-Jane CE
« Reply #7 on: Tue, 03 November 2015, 08:39:41 »
Definitely going to need this, would prefer to get a fun color, like red/blue/pink
« Last Edit: Tue, 03 November 2015, 08:54:56 by trees »
B.Face HHKB - B.mini - Black/Purple Custom
Offline asdfjkl36
  • blue shirt guy
Re: [IC]TGR-Jane CE
« Reply #8 on: Tue, 03 November 2015, 08:43:12 »
Ooooo
Merry Christmas to mee :cool:
Offline HekusuTekusu
Re: [IC]TGR-Jane CE
« Reply #9 on: Tue, 03 November 2015, 08:46:54 »
Would this be the only three colours available for the v2? I saw the picture on the other thread but did not see any confirmation about colour choices
| Das 3 Ult MX BRW | PokerII MX BLK | KUL-ES87 MX CLR | Planck MX GRE | HHKB Pro JP |  CPSQ-1800 GAT BLK | HHKB Pro 2 | NYM96 GAT RED |
Offline mathiasn
Re: [IC]TGR-Jane CE
« Reply #10 on: Tue, 03 November 2015, 08:55:48 »
Will there be an ISO plate this round?
 :thumb: :thumb:
Offline Firebolt1914
  • POM Overlord
Re: [IC]TGR-Jane CE
« Reply #11 on: Tue, 03 November 2015, 09:32:22 »
Definitely going to buy this one.
Offline jbondeson
Re: [IC]TGR-Jane CE
« Reply #12 on: Tue, 03 November 2015, 09:34:48 »
This is begging for an Alps PCB and Plate option!
Offline Delirious
Re: [IC]TGR-Jane CE
« Reply #13 on: Tue, 03 November 2015, 09:46:49 »
I second this sentiment.
If not I'm still interested in cherry board. I would also like to know what's your timeline on with the current Jane GB and how it will interact with this buy?
Offline justnits
Re: [IC]TGR-Jane CE
« Reply #14 on: Tue, 03 November 2015, 10:00:12 »
money 404...all the best in this IC!
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline gadzkun
Re: [IC]TGR-Jane CE
« Reply #15 on: Tue, 03 November 2015, 10:19:54 »
wow this is great..
but dam my wallet already get hacked :(
so many good GB this month
Offline yuktsi
Re: [IC]TGR-Jane CE
« Reply #16 on: Tue, 03 November 2015, 10:26:49 »
the current groupbuy had all been delivered.
except for those who opted for assembly services from Yong
but Yong is finishing his work by week too.
my plan is to have the second round shipped out 2 week before Christmas.
My collection
Offline ika
Re: [IC]TGR-Jane CE
« Reply #17 on: Tue, 03 November 2015, 10:29:08 »
need side profile pictures and color options! That looks great.
Offline zzyjayfree
Re: [IC]TGR-Jane CE
« Reply #18 on: Tue, 03 November 2015, 10:30:06 »
And Jane is back again!
OTD 360 Corsa w/ Nixdorf, OTD 356.2 DGE, Matrix 1.2, Matrix 2.0, Matrix Abel, Skog, Dolphin, EM7, Lynn Pad, Plank, LZ-RE, EqualZ, Orion v2, Octagon v2, Viper v2, Tank, Mira, Mira SE, Moon, Camp 225, Let's Split, HHKB, RealForce, Infinity Ergo, Cherry 3700, DolchPac, Nixdorf, Model M, Filcos.
Offline yuktsi
Re: [IC]TGR-Jane CE
« Reply #19 on: Tue, 03 November 2015, 10:30:13 »
no plan for alps for the coming groupbuy
but we are developing our own pcb
we will offer alps once that is ready  :))
My collection
Re: [IC]TGR-Jane CE
« Reply #20 on: Tue, 03 November 2015, 10:30:32 »
I might have to get in on this. What slant will the case have? Will colours/price be the same as V1? Will we have the same plate options?
« Last Edit: Tue, 03 November 2015, 10:32:47 by Photekq »
Re: [IC]TGR-Jane CE
« Reply #21 on: Tue, 03 November 2015, 10:32:12 »
Damn! Nice! I don't have my board yet, but I hope I don't want this one too much!
Kinda bummed I didn't just wait. Didn't realize the improved version would arrive so fast. Ah, well. At least others can enjoy the board sooner.
yuktsi, do you know if the acrylic layer will be offered this time around? That would probably be the only thing that would make me join Round 2.
« Last Edit: Tue, 03 November 2015, 10:43:28 by romevi »
Offline jbondeson
Re: [IC]TGR-Jane CE
« Reply #22 on: Tue, 03 November 2015, 10:34:39 »
:blank:
:eek:  :cool:
Now the question is: will the future pcb/plate be compatible with this case design?
Offline azhdar
  • Praise the AZERTY god
Re: [IC]TGR-Jane CE
« Reply #23 on: Tue, 03 November 2015, 10:46:26 »
 :thumb: :thumb:
curious about it too.
Azerty Propagandiste
  • POM Overlord
Re: [IC]TGR-Jane CE
« Reply #24 on: Tue, 03 November 2015, 11:04:35 »
How many keyboards are to be sold in this GB?
Offline yuktsi
Re: [IC]TGR-Jane CE
« Reply #25 on: Tue, 03 November 2015, 11:12:58 »
That's something that I will need to talk to the factory tmr. Hopefully 20 or 25 would be great.
With the exchange rate of myr vs usd, I'm hoping the price will be the same as the previous run, but using a better material and harder anodize. I want the brass weight to be sent for surface treatment too.
Let's just hope for the best.
My collection
Offline Steezus
  • Keeper of Facts
Re: [IC]TGR-Jane CE
« Reply #26 on: Tue, 03 November 2015, 11:19:05 »
Sounds great, will there be more anondization color options? I've always loved sky blue but just may need to grab a titanium one if not.
Offline Data
Re: [IC]TGR-Jane CE
« Reply #27 on: Tue, 03 November 2015, 11:46:12 »
Instant buy for me if there was a Winkey/ANSI.125 option.
Offline Armagedda
Re: [IC]TGR-Jane CE
« Reply #28 on: Tue, 03 November 2015, 15:03:11 »
I'll be in for this if I can.
Will be monitoring this space keenly.
If there is an option for pink anodizing then I'll be very happy.
  • POM Overlord
Re: [IC]TGR-Jane CE
« Reply #29 on: Tue, 03 November 2015, 15:06:26 »
Sorry for not putting all my questions in one post, but is there to be off centered spacebar support?
Offline scubaste
Re: [IC]TGR-Jane CE
« Reply #30 on: Tue, 03 November 2015, 15:06:43 »
So interested. I'm also very impressed with the initial group buy.  :thumb:
Offline GL1TCH3D
Re: [IC]TGR-Jane CE
« Reply #31 on: Tue, 03 November 2015, 15:16:48 »
Add an option for a case that fits topre? =O
Offline MEEPhouse
Re: [IC]TGR-Jane CE
« Reply #32 on: Tue, 03 November 2015, 15:17:11 »
Will be keeping a close eye on this. When the group buy opens and my wallet allows I will be in 100%  :thumb:
Re: [IC]TGR-Jane CE
« Reply #33 on: Tue, 03 November 2015, 15:24:29 »
yuktsi, have you considered making an aluminum Realforce case?
Offline saturnotaku
Re: [IC]TGR-Jane CE
« Reply #34 on: Tue, 03 November 2015, 15:58:25 »
Would be interested in this as well.
Offline retrochick
  • goodbye my wallet
Re: [IC]TGR-Jane CE
« Reply #35 on: Tue, 03 November 2015, 16:13:19 »
OMG can't wait.
Re: [IC]TGR-Jane CE
« Reply #36 on: Tue, 03 November 2015, 16:14:14 »
Would this run be close to the v1 run in terms of pricing? Or would the 7075 alu shoot up the pricing considerably?
Edit : I couldn't read properly.
Offline logomachy
Re: [IC]TGR-Jane CE
« Reply #37 on: Tue, 03 November 2015, 16:32:27 »
Super interested. Looks like it will be tight to get in on this with all this anticipation.
Offline asdfjkl36
  • blue shirt guy
Re: [IC]TGR-Jane CE
« Reply #38 on: Tue, 03 November 2015, 16:45:05 »
Was already committed with the price of R1, so i'm pretty sure i'll join R2.
My main interest at the moment is the colors that will be offered.
Offline pr0ximity
Re: [IC]TGR-Jane CE
« Reply #39 on: Tue, 03 November 2015, 19:16:35 »
 7075 and finished brass sounds beyond dreamy. Be still my beating heart.
Offline Dreamre
    • kbdlife
Re: [IC]TGR-Jane CE
« Reply #40 on: Tue, 03 November 2015, 19:23:35 »
Any chance we can have the board with no engraving on top? :).
Offline GhostofHarry
Re: [IC]TGR-Jane CE
« Reply #41 on: Tue, 03 November 2015, 19:43:19 »
The blue grey in then previous drop is pure beauty, hope i can still get one of that
Offline bocahgundul
  • a seal
Re: [IC]TGR-Jane CE
« Reply #42 on: Tue, 03 November 2015, 20:38:23 »
Will surely join this one
Offline just
Re: [IC]TGR-Jane CE
« Reply #43 on: Tue, 03 November 2015, 20:41:53 »
nice set
cc is all
Offline Sed8op8
  • Keyboard Padawan
Re: [IC]TGR-Jane CE
« Reply #44 on: Tue, 03 November 2015, 20:47:18 »
Ahhh hahaha yessssss
Offline csnickba
  • Gateron fanboy and topre lover.
Re: [IC]TGR-Jane CE
« Reply #45 on: Wed, 04 November 2015, 03:38:51 »
More anondized color options would be amazing. Also I finally have the money to get in on something like this, here's to hoping I do if this goes through.
Offline yuktsi
Re: [IC]TGR-Jane CE
« Reply #46 on: Wed, 04 November 2015, 06:31:25 »
 :thumb: :thumb:
 :thumb: :thumb:
ISO will be available
My collection
Offline QuickDelat
Re: [IC]TGR-Jane CE
« Reply #47 on: Wed, 04 November 2015, 06:42:13 »
 :thumb: :thumb:
 :thumb: :thumb:
Sweet, and what about the winkey layout? or only winkeyless?
Offline yuktsi
Re: [IC]TGR-Jane CE
« Reply #48 on: Wed, 04 November 2015, 07:36:23 »
 :thumb: :thumb:
 :thumb: :thumb:
winkey and winkeyless
My collection
Offline Doobalicious
Re: [IC]TGR-Jane CE
« Reply #49 on: Wed, 04 November 2015, 07:39:18 »
Interested! Hope the 7075 won't add considerable cost :thumb:
