Author Topic: Questions about Zelious Switches  (Read 2639 times)
Offline Harms
« on: Wed, 04 November 2015, 19:45:16 »
Hey guys I been hearing a lot about Zelious Switches. I got some questions about then, I'm a total newb ahah. Firstly whats the actuation force of these switches (like MX red being 45g for example). Also I heard there ergo clear. So there like MX clears but lighter? They look super cool though ahah.
Offline alexjd99
  • oozing through the cells of one's own construction
Re: Questions about Zelious Switches
« Reply #1 on: Wed, 04 November 2015, 19:47:44 »
The actuation force depends on what variant you get, but the measurements listed on the website list the bottoming out force.
And that is what an ergo clear is, they were originally clears with springs from a brown/blue/red.
Offline Harms
« Reply #2 on: Wed, 04 November 2015, 19:51:15 »
Thanks a lot :). I went on the site and the lowest I saw was 62g. That means 62g in total to actuate right?
Offline alexjd99
« Reply #3 on: Wed, 04 November 2015, 19:54:21 »
No, it means 62 grams to bottom out. I believe 62g is the closest to using the brown/red/blue springs, but I may be wrong
Offline ika
« Reply #4 on: Wed, 04 November 2015, 19:57:57 »
Cherry/Gateron measure their springs at actuation weight. This means different switches can use the same spring but have different "weights" since the bump or click increases the force necessary to actuate.
Korean springs are measured at bottom-out, since they're bare springs there's no actuation weight available.
Cherry Red/Brown/Blue springs are ~45g actuation, a bit under 60g at bottom out. 62g Ergo Clears are a tiny bit heavier spring-wise but the bump increases the actuation force by roughly 10-15g (IIRC) so they feel even heavier.
Offline Harms
« Reply #5 on: Wed, 04 November 2015, 20:04:03 »
That makes so much sense, thanks a lot bro.
« Last Edit: Wed, 04 November 2015, 20:06:03 by Harms »
Offline gadzkun
« Reply #6 on: Wed, 04 November 2015, 22:41:49 »
you can buy a sampler pack first
http://zealpc.net/collections/accessories/products/zealio-switch-sampler-pack
so you can decide what suit you most
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #7 on: Thu, 05 November 2015, 04:35:54 »
Only messed around some with the 67g Zealio switches and they are pretty close to Mx Clear imo
With the tactile bump slightly closer to the top than Cherry
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline tronbeaver
« Reply #8 on: Thu, 05 November 2015, 09:00:53 »
Zealio, not Zelious.
http://zealpc.net/collections/switches/products/zealio
Offline ideus
  • Björkö.
« Reply #9 on: Mon, 09 November 2015, 22:34:12 »
It would be convenient to make a decision on switches based on a sampler, or even a single switch, or based on others input; I'd say you should try a full board over a reasonable time, let's say a month or so, to decide if that particular type is for you, or not. It is the only way you may actually know if the force needed to type is ok, if the bounce back is quick enough for your typing speed and all that.
Here at GH if you do not like a keyboard you could sell it and move ahead.
