Author Topic: Need Info on A87U PCB  (Read 2239 times)
Offline Rodgaroon
  • Size matters, just ask my wife.
« on: Sun, 08 November 2015, 01:55:02 »
I have searched everywhere but I cant find anything on the A87U PCB, can anyone point me in the right direction so i can get all the information I would ever need on this PCB. Info on Firmware, Keymaping, Programing, etc. Thanks in advance.
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
Offline dummytim
  • Keyboards = Life
Re: Need Info on A87U PCB
« Reply #1 on: Sun, 08 November 2015, 02:14:33 »
There's some info here http://blog.winkeyless.kr/5
I also currently have an A87 PCB, but for LED changes on mine is hold ESC and hit Caps Lock twice. I found a page earlier about firmware but I can't seem to find it again, I'll keep looking and let you know if I find it.
Offline Steezus
  • Keeper of Facts
« Reply #2 on: Sun, 08 November 2015, 16:12:16 »
An A87 PCB is just a particular layout of pcb. When you hear somebody say it's A87 compatible that just means that any standard 86/87 key layout PCB will work, I suggest double checking though because sometimes the USB port and be flip flopped.
Offline dummytim
  • Keyboards = Life
« Reply #3 on: Mon, 09 November 2015, 16:20:23 »
You might want to check this thread out, it seems to have some discussion about the A.87 https://geekhack.org/index.php?topic=44504.0
