Author Topic: Started making artisans, and looking for advice  (Read 4506 times)
Offline alexjd99
  • oozing through the cells of one's own construction
« on: Sun, 08 November 2015, 14:23:48 »
So I've never been really artistic, and I decided I would give sculpting a try. I made these over the past month or so, and any criticism/ advice is more than welcome!
Turtle
My first, and by far my favorite
Random Dinosaur
Random thing (I have no idea what to call it)
Bear
This one I couldn't seem to get right no matter how often I would change it, probably not going to end up making these
Vintage TV
This one still needs some work, but you get the idea
Topre blanks
I have these for control/ caps lock, Arrow clusters, escape, and I may make a WASD cluster
And possible a Danger Zone one
Thanks in advance for the advice!
Offline dutC4
Re: Started making artisans, and looking for advice
« Reply #1 on: Sun, 08 November 2015, 14:29:05 »
 :blank:
« Last Edit: Thu, 22 December 2016, 14:59:42 by dutC4 »
Offline Hexterdude
  • I have a problem when it come to artisans
« Reply #2 on: Sun, 08 November 2015, 14:29:43 »
My body is ready for that turtle
« Reply #3 on: Sun, 08 November 2015, 14:35:03 »
Very nice!
Make some for buckling springs or Alps.
- D Trump 2026-10-24
Offline 1swt2gs
  • DOGE
« Reply #4 on: Sun, 08 November 2015, 14:36:22 »
Caps look awesome!
I love the Random Dinosaur the most!
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline alexjd99
« Reply #5 on: Sun, 08 November 2015, 14:38:56 »
Very nice!
Don't quote me on it, but I do see it as a possibility
(Once I get an Alps and BS board in the near future  ;))
Offline bcredbottle
« Reply #6 on: Sun, 08 November 2015, 14:43:34 »
Are you going to cast these?
« Reply #7 on: Sun, 08 November 2015, 14:44:51 »
Why does that turtle look so good, have you painted the shell?  Easily my favourite too, though the dinosaur is also cool and the blanks look nice and grippy.
As to advice, does the neck hit neighboring caps when on a board?  I also wonder how you're intending to extract it from a mold, unless you are planning to sculpt/paint each one?
Offline alexjd99
« Reply #8 on: Sun, 08 November 2015, 14:50:57 »
No, the white is because I wanted to add the finer details after the clay hardens, and for some reason it turns white.
I made sure when I first made them that they don't interfere with other caps. The turtle is the only one with some problems, if you put it behind another artisan that has a higher profile than most caps it will interfere (I haven't tested with SA though, but all others are fine)
I plan on using a softer silicon, but I don't think I'll have many problems with the turtle, since there isn't anything sticking out too much.
Offline user 18
« Reply #9 on: Sun, 08 November 2015, 14:52:32 »
That turtle looks pretty rad! I'm excited to see where you go from here!
Avatar by ashdenej
Offline DrCr4nK
  • Yeah, man. I dig that.
« Reply #10 on: Sun, 08 November 2015, 16:39:19 »
Great looking caps!  I recently started sculpting.  If you don't mind me asking, what type of clay are you using?   I've been using this stuff called Fimo, but I think I lose detail when I bake it.  Your turtle is killer!
Offline alexjd99
« Reply #11 on: Sun, 08 November 2015, 16:43:00 »
I use some off brand polymer clay I got at Michael's
http://www.michaels.com/craft-smart-polymer-clay-2oz/M10120139.html?dwvar_M10120139_color=White#q=polymer+clay&start=1
I works pretty well, and the temperature that it hardens at is much lower than the temperature that PBT melts (I put them in the toaster oven at about 250 degrees Fahrenheit)
Offline fanpeople
« Reply #12 on: Sun, 08 November 2015, 17:01:33 »
As the owner of turtles I got to say, dam that turtle is awsome
Offline DrCr4nK
« Reply #13 on: Sun, 08 November 2015, 17:36:59 »
Will be trying it out.  Also going to try baking mine at a lower temp.  Thanks!
Offline lashiel
« Reply #14 on: Sun, 08 November 2015, 22:12:12 »
Love that turtle. Very very cool sculpt.
Offline QuickDelat
« Reply #15 on: Mon, 09 November 2015, 06:22:12 »
That turtle is amazing! Look forward to see your progress :)
Offline tigersharkdude
« Reply #16 on: Mon, 09 November 2015, 06:57:37 »
Throws money at screen for Turtle
