Author Topic: Corsair Backlit FPS keycaps on Tt Esports Poseidon  (Read 1978 times)
Offline ninjoe
« on: Sun, 08 November 2015, 22:17:15 »
Hi everyone, I want to know if someone here has managed to use this http://www.corsair.com/en/fps-backlit-key-caps-keycap-puller-and-palm-rest set on their Poseidon keyboard?http://www.ttesports.com/productPage.aspx?p=122&g=ftr#.VkAdRfmrSUk
Any recommendations will be welcome.
Offline R1N3
Re: Corsair Backlit FPS keycaps on Tt Esports Poseidon
« Reply #1 on: Sun, 08 November 2015, 22:20:19 »
Are you wondering if the keycaps will fit? Yes, they will.
The wrist rest though.. I can't tell if it interacts with the corsair in some particular way. Maybe..
Offline ninjoe
« Reply #2 on: Mon, 09 November 2015, 09:13:13 »
Yeah, wanted to know if they would fit. Thanks for the info, I think I'll order them now.
